Siergiej89
Wymiana e8400 i dysku
Witam!
Czas na wymianę najsłabszych komponentów w moim PC. A są nimi (chyba) procek i dysk.
Było już  kilka podobnych wątków, ale są trochę stare. Proszę o pomoc.
portfel: MAX 500zł + to co ze sprzedaży
Wklejam fragmenty logów:
zasilacz corsair vx450w
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E8400
Codename Wolfdale
Specification Intel® Core2 Duo CPU     E8400  @ 3.00GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping C0
Technology 45 nm
TDP Limit 65 Watts
Core Speed 3779.9 MHz
Multiplier x Bus Speed 9.0 x 420.0 MHz
Rated Bus speed 1680.0 MHz
Stock frequency 3000 MHz
Chipset
Northbridge Intel P45/P43/G45/G43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4 GBytes
Channels Dual, (Symmetric)
Memory Frequency 420.0 MHz (1:1)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Row Refresh Cycle Time (tRFC) 42
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Kingston (7F98000000000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number KTC1G-UDIMM
Serial number 6B38EC9D
Manufacturing date Week 25/Year 08
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-18-23 @ 400 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 1024 MBytes
Serial number 67382C94
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
AMP no
DIMM # 3
SMBus address 0x52
Memory type DDR2
Size 1024 MBytes
Serial number 662E6487
Manufacturing date Week 11/Year 08
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
AMP no
DIMM # 4
SMBus address 0x53
Memory type DDR2
Size 1024 MBytes
Serial number 662E6687
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
AMP no
Mainboard Model P5Q (0x000000D6 - 0x0000056C)
Hardware monitor Winbond W83667HG
Voltage 0 1.34 Volts [0xA8] (CPU VCORE)
Voltage 1 12.04 Volts [0xD8] (+12V)
Voltage 2 3.26 Volts [0xCC] (AVCC)
Voltage 3 3.25 Volts [0xCB] (+3.3V)
Voltage 4 4.94 Volts [0xCE] (+5V)
Voltage 6 1.39 Volts [0xAE] (DRAM)
Temperature 0 41°C (105°F) [0x29] (System)
Temperature 1 38°C (99°F) [0x4B] (CPU)
Temperature 2 20°C (68°F) [0x28] (AUX)
Fan 0 1029 RPM [0xA4] (SYSFANIN)
Fan 1 1430 RPM [0x3B] (CPU)
Storage
Drive 0
Device Path \\?\scsi#disk&ven_&prod_st3500320as#4&5ecf4f&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name ST3500320AS
Capacity 465.8 GB
SMART Support Yes
Drive 1
Device Path \\?\ide#diskst3400620a______________________________3.aae___#6&3ad9c15f&0&0.1.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name ST3400620A
Capacity 372.6 GB
SMART Support Yes
Display Adapters
Display adapter 0
Name Radeon HD 6850
Codename Barts
Technology 40 nm
Memory size 1024 MB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x174B)
Model ID 0x6739 (0xE174)
Performance Level 0
Core clock 100.0 MHz
Memory clock 150.0 MHz
Performance Level 1
Core clock 600.0 MHz
Memory clock 1000.0 MHz
Performance Level 2
Core clock 775.0 MHz
Win32_VideoController AdapterRAM = 0x40000000 (1073741824)
Win32_VideoController DriverVersion = 13.251.0.0
Win32_VideoController DriverDate = 12/06/2013
500 zł to trochę mało , w dodatku masz starą platformę .
Jak chcesz zostać w jej obrębie to Q6600/Q9450 + OC ew. jakiś Xeon S771 i także OC .
Np. ten Xeon E5430 za 130 zł , procek to odpowiednik Q9450 .
Do tego zmodyfikowane biosy do płyt
Jak płyta na to pozwoli .
E8400 wart jest jakieś 100 zł , 600 zł na zmianę platformy to trochę mało .
Zależy co chcesz dokładnie wymienić .
Przy całkowitej wymianie kompa ( procek , płyta , ram , dysk i napęd oraz zasilacz czy buda ale bez karty ) musiał byś mieć jakieś 1 100 zł .
Jak masz dysk i napęd SATA ( wąskie złącze ) i markową obudowę i zasilacz to potrzeba mniej - 600-700 zł powinno wystarczyć .
Z tego co widzę to dysk jest SATA , z jakiego powodu chcesz go wymienić - źle działa czy coś innego ?
Karta nie będzie wąskim gardłem .
Edytowane przez reyden
Obudowa jest przedpotopowa, ale jest cały czas otwarta.
Zasilacz dopiero co wymieniałem, 450W nie starczy? (Corsair vx 450W). Podobnie grafa (hd6850) była niedawno wymieniana. Generalnie co rok/pół roku coś modyfikuję.
Rozumiem że ramy na ddr3? tylko jakie i ile?
Dysk już myślałem...żeby system postawić na ssd...podobno to duuuuzo daje, prawda?
No i kwestia płyty i procka.
600 + to co ze sprzedaży by wystarczyło?
Zasilacz może być .
Co do części to proponuję na razie coś takiego :
CPU : Pentium G3220 - 199 zł
MB : Asrock H81M - 189 zł
RAM : Goodram 4GB DDR3 1 600 mhz CL9 PLAY - 155 zł
Razem : 543 zł , ceny z morele.net .
Procek nieco szybszy niż E8400 , ale dużo od niego chłodniejszy i w razie czego ma zintegrowaną grafikę .
Potem jak będziesz miał kasę to tego Pentium zmienisz na jakiegoś I5 i masz całkiem niezłego kompa .
Chyba że chcesz od razu I5 i 8 GB ramu - tyle że byś musiał dołożyć ~650 zł , za samego I5 4460 zapłacisz obecnie 480 zł więcej .
Albo inna opcja - zamiast ww. procka i płyty brać Pentium G3258 + Asus H81M-E - wyjdzie jakieś 40 zł drożej a procka można podkręcić w przeciwieństwie do G3220 / G34xx czy innych procków non-K .
Może być .
Tyle że to używki i prawdopodobnie nie mają już gwarancji , do tego cena będzie chyba wyższa - nie liczyłeś kosztów przesyłki , chyba że całość bierzesz od jednej osoby i zostanie to wysłane w jednej paczce .
