lisekx Napisano 5 Grudnia 2017 Zgłoś Napisano 5 Grudnia 2017 Witam, od wczoraj mam problem z samoistnym resetem kompa i bluescreen'em. Nie instalowałem od miesiąca żadnych nowych programów.Komp:Windows 7Procesor: Intel Core i3 540, 3066 MHzPłyta główna: Gigabyte GA-P55-US3L ver.2.0Grafika: Gigabyte HD 7770 ver. 2.0Pamięć: Crucial 2x4GB DDR3-1600Dyski: SSD 250GB Crucial 250MX WDC 500GB WD5000AACS-00ZUB0 WDC 500GB WD5001AALS-00LWTA0Zasilacz: CHIEFTEC 450W GPS-450AA-101ABędę wdzięczny za pomoc. W pliku z raportem błędu mam coś takiego: Microsoft (R) Windows Debugger Version 6.11.0001.402 X86 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\BLUE\Desktop\120517-11154-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: *** Invalid *** **************************************************************************** * Symbol loading may be unreliable without a symbol search path. * * Use .symfix to have the debugger choose a symbol path. * * After setting your symbol path, use .reload to refresh symbol locations. * **************************************************************************** Executable search path is: ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2 *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.23864.amd64fre.win7sp1_ldr.170707-0600 Machine Name: Kernel base = 0xfffff800`03014000 PsLoadedModuleList = 0xfffff800`03256750 Debug session time: Tue Dec 5 18:24:56.410 2017 (GMT+1) System Uptime: 0 days 0:19:08.752 ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2 *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Loading Kernel Symbols ............................................................... ................................................................ ................................................ Loading User Symbols Loading unloaded module list ........... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 1E, {0, 0, 0, 0} ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Probably caused by : ntoskrnl.exe ( nt+6f950 ) Followup: MachineOwner ---------Jeśli jeszcze jest coś potrzebne do zdiagnozowania problemu to dajcie znać Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
a602820922 Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 (edytowane) Zasilacz do wymiany bo z czarnej listy jest. Pamiętasz kod tego BSOD? Sent from my SM-N9200 using Tapatalk Edytowane 6 Grudnia 2017 przez a602820922 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
lisekx Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 chyba taki 0x0000001E Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Klaus Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 Zasilacz do wymiany bo z czarnej listy jest. Powaga? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
lisekx Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 Microsoft (R) Windows Debugger Version 6.11.0001.402 X86 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\BLUE\Desktop\120617-13494-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.23864.amd64fre.win7sp1_ldr.170707-0600 Machine Name: Kernel base = 0xfffff800`0301d000 PsLoadedModuleList = 0xfffff800`0325f750 Debug session time: Wed Dec 6 01:33:30.170 2017 (GMT+1) System Uptime: 0 days 7:07:31.138 Loading Kernel Symbols ............................................................... ................................................................ ................................................ Loading User Symbols Loading unloaded module list ............ ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 1E, {0, 0, 0, 0} Unable to load image \SystemRoot\system32\DRIVERS\klbackupdisk.sys, Win32 error 0n2 *** WARNING: Unable to verify timestamp for klbackupdisk.sys *** ERROR: Module load completed but symbols could not be loaded for klbackupdisk.sys Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
a602820922 Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 Tak wszyscy zalecają, może on uszkodzić inne podzespoły również. Sent from my SM-N9200 using Tapatalk Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Setnik Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 Masz Kasperski Antywirus? Jeśli tak to MS zaleca odinstalowanie oraz pełne update systemu. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
a602820922 Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 Wrzuć tutaj pliki minidump Sent from my SM-N9200 using Tapatalk Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
lisekx Napisano 6 Grudnia 2017 Zgłoś Napisano 6 Grudnia 2017 Tak mam Kaspeskiego, już go odinstalowałem, zainstaluje starszą wersję - teraz wiem, dlaczego program fiddler wywalał mi błędy i odnosił się też do Kasperskiego plik minidump: http://www110.zippyshare.com/v/RQ3PQuIX/file.html Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
