Bolo8888
Abit Ip35-e, Ip35 "dark Rider", Ip35-pro "snake"
Abit IP35-E
Dołączona grafika
Info IP35-E - Strona producenta
# CPU Support Intel® Core™ 2 Extreme/Duo/Quad processors with 1333/1066/800MHz FSB
# Support Intel® Core™ 2 Extreme/Quad/Duo & Pentium® Dual Core Processors
# Chipset Intel® P35 Express / ICH9 Chipset
# Memory 4 X 240-pin DIMM sockets support max. memory capacity 8GB
· Supports Dual channel DDR2 800/667/533 un-buffered non-ECC memory
# LAN Onboard Gigabit LAN controller supports 10/100/1000M Ethernet
# Audio On board 7.1 CH HD Audio CODEC
# Supports auto jack sensing and optical S/PDIF Out
# HDMI ready header (SPDIF header)
# Expansion Slots 1 x PCI-E X16, 2 x PCI-E X1, 3 x PCI
# Internal I/O 1 x Floppy Port supports up to 2.88 MB
# 1 x ATA 133/100/66/3 IDE connector
# 4 x SATA 3Gb/s connector
# 4 x USB header (support 8 ports)
# 1 x FP-Audio
# Back Panel I/O 1 x PS/2 Keyboard, 1 x PS/2 Mouse
# 1 x S/P DIF Out
# 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
# 4 x USB 2.0
# 1 x RJ-45 LAN connector
# Serial ATA 4 x SATA 3Gb/s through Intel® ICH9
# Form Factor ATX form factor 305 x 245mm
# PCB Color: Blue
# RoHS 100% lead-free process and RoHS compliant
abit Engineered
abit Engineered abit SoftMenu™
The original jumperless motherboard design allows for CPU setting changes completely through the BIOS. For GigaOverclocking! Boost your PC's Performance by up to 50%. Convenient and easy-to-use fine tuning from within a self-explanatory BIOS menu.
Abit IP35
Dołączona grafika
Info IP35 - Strona producenta
# Chipset Intel® P35 Express / ICH9R Chipset
# Supports Dual channel DDR2 800/667/533 un-buffered Non-ECC memory
# Supports auto jack sensing and optical S/PDIF In/Out
# 6 x SATA 3Gb/s connector
# 2 x IEEE1394, 4 x USB header (support 8 ports)
# 1 x FP-Audio
# abit Silent OTES™
# 1 x S/P DIF In, 1 x S/P DIF Out
# 4 x USB 2.0
# Serial ATA 6 x SATA 3Gb/s offer by Intel® ICH8R support Intel® Matrix Storage Tech(AHCI & RAID0/1/5/10)
# IEEE 1394 Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate.
# PCB Color: Blue
# abit Engineered abit Silent OTES™ Technology
# Japanese made Low ESR and high ripple conductive polymer aluminum solid state capacitor around the CPU socket
# 100% Japanese made capacitor
abit Engineered
abit Engineered abit Silent OTES™abit-Engineered
abit's Silent OTES™ heatpipe technology dissipates heat from the chipset and conducts it to a highly effective heatsink. This fanless solution keeps your motherboard cool and quiet.
Abit IP35 Pro
Dołączona grafika
Info IP35 Pro - Strona producenta
# Supports Dual channel DDR2 800/667/533 Un-buffered Non-ECC memory
# LAN On board Dual Gigabit LAN controller supports 10/100/1000M Ethernet
# Expansion Slots 1 x PCI-E X16, 1 x PCI-E X16 (x4 bandwidth), 1 x PCI-E X1, 3 x PCI
# 2 x IEEE1394, 3 x USB header (support 6 ports)
# 1 x FP-Audio
# abit Silent OTES™
# 2 x eSATA
# 4 x USB 2.0
# EZ CCMOS Switch
# 2 x eSATA 3Gb/s through JMicron® JMB363 support 0,1JBOD RAID function
# PCB Color: Blue
# abit Engineered abit µGuru™ Technology
# abit Silent OTES™ Technology
# 100% Japanese made Low ESR and high ripple conductive polymer aluminum solid state capacitor
# 100% Japanese Capacitor
# EZ for CCMOS
abit Engineered
With abit's unique µGuru technology now even the most novice users can fully monitor and control their system including voltages, fans and temperatures; it's all just a click away. The more advanced you become, the more you will appreciate the multitude of fine tuning features abit's µGuru technology holds for you.
abit Engineered OC Guru - AutoDrive™
By enabling AutoDrive, you can automatically apply different overclocking settings for different applications.
abit Engineered
Hardware Monitoring
Monitor temperatures, voltages and fan settings in real time and with zero CPU usage.
abit Engineered Dedicated fan control
Keep control over your hardware. abit Fan EQ™ helps you keep an eye on your motherboard fans.
abit Engineered One Click BIOS Update
With abit's BIOS flash utility you can easily update your motherboard BIOS online or offline.
abit Engineered Auto-Detect Hardware Info
The abit BlackBox auto-detects hardware info for quick communication between users and abit Tech support.
abit Engineered abit CPU ThermalGuard™
The abit CPU ThermalGuard™ technology prevents the CPU from overheating and burning up in the case of any hardware cooling malfunction. This hardware thermal protection automatically shuts down your system when the CPU temperature reaches a certain threshold.
Jestem ciekaw co te plytki potrafia :):):).
Gość Harry Lloyd
Niezwykle podoba mi sie layout dwóch tańszych modeli, jest prawie idealny, chyba najlepszy jaki widziałem do tej pory.
Chyba jedyną dla mnie wadą jest brak LPT, który mi jest potrzebny do drukarki. No i gniazda SATA też by mogły być przewrócone jak w Pro, ale to aż tak nie przeszkadza.
Jeśli płytki okażą się udane to sobie pewnie taką sprawię pod Penryna.
Edytowane przez Harry Lloyd
Gość Harry Lloyd
Mam 14-letnią drukarke HP (300 dpi), drukuje z raz na miesiąc jedną strone i szkoda mi kupować nową.
Są jakieś przejściówki LPT->USB, ale ponoć nie zawsze to działa.
Gość Firekage
W sklepach??
A sklepy skad maja wziac te plytki??
Po drodze sa hurtownie, dystrybutorzy itd....
Po drodze sa i co z tego skoro sklepy nie chca do nich zagladac. Przedstawicielstwo Abita jest u mnie w miescie. Ze swieca szukaj ich mobasow. Durnego P6N SLI FI nie ma i nie chca sprowadzac.
A co do Abitow. Tam nic nie ma o 45nm procach :blink:
Abit i padaka :blink: :-P
A nie, juz nie raz robili takie plyty ze szkoda gadac, chodz ostatnio abit powoli zaczyna wracac z konkretnymi mobasami.
Edytowane przez Bolo8888
Wiem Bolo [; ale teraz płyty Abita są bardzo dobre, Ab9 Quad GT, AW9D, KN9 .
Mam nadzieję że Abit nie spocznie na laurach bo płyty z wyglądu są fajne, nieprzekombinowane, oby dobrze spisywały się też przy OC.
Abit IP35-Pro w preorderze na yoyotech za +/- 532 zlocisze
http://www.yoyotech.co.uk/product_info.php?cPath=20_47&products_id=4323&osCsid=8dc984cbff630e79a0302a9d9854c7b7
Dostepny od 5 czerwca :)
Gość Harry Lloyd
Pewnie bedzie lekki Vdrop, no i z Quadami może być gorzej, ale wątpie żeby ktoś Quada do takiej płytki chciał.
Cena powinna być u nas podobna, większość sprzętu w Anglii jest w podobnych cenach, było by to dość niedrogo, pewnie za pare miesięcy poniżej 500 zł Pro zejdzie i będzie to ciekawy zakup. Te lepsze kondensatory też mogą się okazać istotne przy mocnym OC na dłuższą metę. Zobaczymy, pewnie niedługo jakieś testy.
IP35-E jest poprostu piękna, taka prosta i 3xPCI nie blokowane prze chłodzenie grafiki to jest to. W abicie wkurza mnie że nie robią już LPT/COM.
No trzymam kciuki za Abita powracającego do formy.
:rolleyes:
No i są wyniczki podkręcania QX6700 i E6700 na IP35 PRO - link, chyba nie jest żle jak na dzień dobry = FSB na poziomie 580 MHz
A następca QuadGT ma być na X38, ma obsługiwać DDR2 (na szczęście) i nazywać się IX38 QuadGT - niusik (nie wiem czy już gdzieś był) :P
PS.
Poza tym ma byc jeszcze IX38-MAX - tyle, że na fotkach wygląda jakby miał sloty na DDR3 - link
Chyba jeszcze na polskich portalach nie ma niusów o tych plytach. :unsure: :razz:
Gość Harry Lloyd
W tym miesiącu na pewno, powinny na dniach (po Computexie pewnie). Mowa o serii IP35 oczywiście.
Hmm ślicznie wygląda :D IP35 Pro 580FSB a IP35?? Różnią sie czymś jeszcze oprócz tego że ,,pro,, ma cyfrowy wyświetlacz i dodatkowy HP??? Głównie chodzi mi czy IP35 w jakiś sposób robi mniejsze FSB
IMO nie będzie tak źle. W tym www.yoyotech.co.uk cena za IP35 wynosi ~89 Funtów, tyle samo kosztuje E4400, więc na oko IP35 powinno kosztować <500zł (trzeba doliczyć różnicę VAT 17%/19% w UK, a 22% u nas)
IP35-E to 67 Funtów, ponad 10 mniej od MSI P35 Noe-F, wiec Abita sie może za <400zł wyrwie.
IP35Pro to 120 Funtów tyle samo co E6420, a to 650-700zł.
