spox5
Problem Z Ac'97
Witam mam problem przy instalacji dźwięku Ac'97 na płycie EPoX
Wszystko robię jak w artykule dostępnym na stronie tutaj lecz problem ciągle się powtarza po wpisaniu komendy make a wygląda to tak
MUSIAŁEM OBCIĄĆ DOSYĆ SPORO BO SIE NIE MIEŚCIŁ KOD
/usr/include/linux/version.h:3:2: #error "You should not include /usr/include/{linux,asm}/ header"/usr/include/linux/version.h:4:2: #error "files directly for the compilation of kernel modules."/usr/include/linux/version.h:5:2: #error ""/usr/include/linux/version.h:6:2: #error "glibc now uses kernel header files from a well-defined"/usr/include/linux/version.h:7:2: #error "working kernel version (as recommended by Linus Torvalds)"/usr/include/linux/version.h:8:2: #error "These files are glibc internal and may not match the"/usr/include/linux/version.h:9:2: #error "currently running kernel. They should only be"/usr/include/linux/version.h:10:2: #error "included via other system header files - user space"/usr/include/linux/version.h:11:2: #error "programs should not directly include <linux/*.h> or"/usr/include/linux/version.h:12:2: #error "<asm/*.h> as well."/usr/include/linux/version.h:13:2: #error ""/usr/include/linux/version.h:14:2: #error "To build kernel modules please do the following:"/usr/include/linux/version.h:15:2: #error ""/usr/include/linux/version.h:16:2: #error " o Have the kernel sources installed"/usr/include/linux/version.h:17:2: #error ""/usr/include/linux/version.h:18:2: #error " o Make sure that the symbolic link"/usr/include/linux/version.h:19:2: #error "   /lib/modules/`uname -r`/build exists and points to"/usr/include/linux/version.h:20:2: #error "   the matching kernel source directory"/usr/include/linux/version.h:21:2: #error ""/usr/include/linux/version.h:22:2: #error " o Now copy /boot/vmlinuz.version.h to"/usr/include/linux/version.h:23:2: #error "   /lib/modules/`uname -r`/build/include/linux/version.h"/usr/include/linux/version.h:24:2: #error ""/usr/include/linux/version.h:25:2: #error " o When compiling, make sure to use the following"/usr/include/linux/version.h:26:2: #error "   compiler option to use the correct include files:"/usr/include/linux/version.h:27:2: #error ""/usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/include"/usr/include/linux/version.h:29:2: #error ""/usr/include/linux/version.h:30:2: #error "   instead of"/usr/include/linux/version.h:31:2: #error ""/usr/include/linux/version.h:32:2: #error "   -I/usr/include/linux"/usr/include/linux/version.h:33:2: #error ""/usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordingly."/usr/include/linux/version.h:35:2: #error "======================================================="seq32.c:4:40: missing binary operator before '('seq32.c:8:67: missing binary operator before '('In file included from /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:25,                 from /usr/src/alsa/alsa-driver-1.0.8/include/sound/driver.h:42,                 from ../../alsa-kernel/core/ioctl32/seq32.c:21,                 from seq32.c:16:/usr/include/linux/version.h:2:2: #error "======================================================="/usr/include/linux/version.h:3:2: #error "You should not include /usr/include/{linux,asm}/ header"/usr/include/linux/version.h:4:2: #error "files directly for the compilation of kernel modules."/usr/include/linux/version.h:5:2: #error ""/usr/include/linux/version.h:6:2: #error "glibc now uses kernel header files from a well-defined"/usr/include/linux/version.h:7:2: #error "working kernel version (as recommended by Linus Torvalds)"/usr/include/linux/version.h:8:2: #error "These files are glibc internal and may not match the"/usr/include/linux/version.h:9:2: #error "currently running kernel. They should only be"/usr/include/linux/version.h:10:2: #error "included via other system header files - user space"/usr/include/linux/version.h:11:2: #error "programs should not directly include <linux/*.h> or"/usr/include/linux/version.h:12:2: #error "<asm/*.h> as well."/usr/include/linux/version.h:13:2: #error ""/usr/include/linux/version.h:14:2: #error "To build kernel modules please do the following:"/usr/include/linux/version.h:15:2: #error ""/usr/include/linux/version.h:16:2: #error " o Have the kernel sources installed"/usr/include/linux/version.h:17:2: #error ""/usr/include/linux/version.h:18:2: #error " o Make sure that the symbolic link"/usr/include/linux/version.h:19:2: #error "   /lib/modules/`uname -r`/build exists and points to"/usr/include/linux/version.h:20:2: #error "   the matching kernel source directory"/usr/include/linux/version.h:21:2: #error ""/usr/include/linux/version.h:22:2: #error " o Now copy /boot/vmlinuz.version.h to"/usr/include/linux/version.h:23:2: #error "   /lib/modules/`uname -r`/build/include/linux/version.h"/usr/include/linux/version.h:24:2: #error ""/usr/include/linux/version.h:25:2: #error " o When compiling, make sure to use the following"/usr/include/linux/version.h:26:2: #error "   compiler option to use the correct include files:"/usr/include/linux/version.h:27:2: #error ""/usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/include"/usr/include/linux/version.h:29:2: #error ""/usr/include/linux/version.h:30:2: #error "   instead of"/usr/include/linux/version.h:31:2: #error ""/usr/include/linux/version.h:32:2: #error "   -I/usr/include/linux"/usr/include/linux/version.h:33:2: #error ""/usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordingly."/usr/include/linux/version.h:35:2: #error "======================================================="In file included from /usr/src/alsa/alsa-driver-1.0.8/include/sound/driver.h:42,                 from ../../alsa-kernel/core/ioctl32/seq32.c:21,                 from seq32.c:16:/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:27:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:30:41: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:35:43: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:39:63: missing binary operator before '('In file included from /usr/include/linux/module.h:297,                 from /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:51,                 from /usr/src/alsa/alsa-driver-1.0.8/include/sound/driver.h:42,                 from ../../alsa-kernel/core/ioctl32/seq32.c:21,                 from seq32.c:16:/usr/include/linux/version.h:2:2: #error "======================================================="/usr/include/linux/version.h:3:2: #error "You should not include /usr/include/{linux,asm}/ header"/usr/include/linux/version.h:4:2: #error "files directly for the compilation of kernel modules."/usr/include/linux/version.h:5:2: #error ""/usr/include/linux/version.h:6:2: #error "glibc now uses kernel header files from a well-defined"/usr/include/linux/version.h:7:2: #error "working kernel version (as recommended by Linus Torvalds)"/usr/include/linux/version.h:8:2: #error "These files are glibc internal and may not match the"/usr/include/linux/version.h:9:2: #error "currently running kernel. They should only be"/usr/include/linux/version.h:10:2: #error "included via other system header files - user space"/usr/include/linux/version.h:11:2: #error "programs should not directly include <linux/*.h> or"/usr/include/linux/version.h:12:2: #error "<asm/*.h> as well."/usr/include/linux/version.h:13:2: #error ""/usr/include/linux/version.h:14:2: #error "To build kernel modules please do the following:"/usr/include/linux/version.h:15:2: #error ""/usr/include/linux/version.h:16:2: #error " o Have the kernel sources installed"/usr/include/linux/version.h:17:2: #error ""/usr/include/linux/version.h:18:2: #error " o Make sure that the symbolic link"/usr/include/linux/version.h:19:2: #error "   /lib/modules/`uname -r`/build exists and points to"/usr/include/linux/version.h:20:2: #error "   the matching kernel source directory"/usr/include/linux/version.h:21:2: #error ""/usr/include/linux/version.h:22:2: #error " o Now copy /boot/vmlinuz.version.h to"/usr/include/linux/version.h:23:2: #error "   /lib/modules/`uname -r`/build/include/linux/version.h"/usr/include/linux/version.h:24:2: #error ""/usr/include/linux/version.h:25:2: #error " o When compiling, make sure to use the following"/usr/include/linux/version.h:26:2: #error "   compiler option to use the correct include files:"/usr/include/linux/version.h:27:2: #error ""/usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/include"/usr/include/linux/version.h:29:2: #error ""/usr/include/linux/version.h:30:2: #error "   instead of"/usr/include/linux/version.h:31:2: #error ""/usr/include/linux/version.h:32:2: #error "   -I/usr/include/linux"/usr/include/linux/version.h:33:2: #error ""/usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordingly."/usr/include/linux/version.h:35:2: #error "======================================================="In file included from /usr/src/alsa/alsa-driver-1.0.8/include/sound/driver.h:42,                 from ../../alsa-kernel/core/ioctl32/seq32.c:21,                 from seq32.c:16:/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:60:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:70:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:187:41: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:258:62: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:270:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:306:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:431:41: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:450:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:474:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:484:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:499:41: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:509:41: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:524:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:531:42: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:536:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:540:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:547:40: missing binary operator before '('/usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:559:42: missing binary operator before '('make[3]: *** [fastdep] Bł±d 1make[3]: Leaving directory `/usr/src/alsa/alsa-driver-1.0.8/acore/ioctl32'make[2]: *** [_sfdep_ioctl32] Bł±d 2make[2]: Leaving directory `/usr/src/alsa/alsa-driver-1.0.8/acore'make[1]: *** [dep] Bł±d 1make[1]: Leaving directory `/usr/src/alsa/alsa-driver-1.0.8'make: *** [include/sndversions.h] Bł±d 2[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:20:2: #error "   the matching kernel source directory"bash: /usr/include/linux/version.h:20:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:21:2: #error ""bash: /usr/include/linux/version.h:21:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:22:2: #error " o Now copy /boot/vmlinuz.version.h to"bash: /usr/include/linux/version.h:22:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:23:2: #error "   /lib/modules/`uname -r`/build/include/linux/version.h"bash: /usr/include/linux/version.h:23:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:24:2: #error ""bash: /usr/include/linux/version.h:24:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:25:2: #error " o When compiling, make sure to use the following"bash: /usr/include/linux/version.h:25:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:26:2: #error "   compiler option to use the correct include files:"bash: /usr/include/linux/version.h:26:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:27:2: #error ""bash: /usr/include/linux/version.h:27:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/include"bash: /usr/include/linux/version.h:28:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:29:2: #error ""bash: /usr/include/linux/version.h:29:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:30:2: #error "   instead of"bash: /usr/include/linux/version.h:30:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:31:2: #error ""bash: /usr/include/linux/version.h:31:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:32:2: #error "   -I/usr/include/linux"bash: /usr/include/linux/version.h:32:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:33:2: #error ""bash: /usr/include/linux/version.h:33:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordingly."bash: /usr/include/linux/version.h:34:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:35:2: #error "======================================================="bash: /usr/include/linux/version.h:35:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# In file included from /usr/src/alsa/alsa-driver-1.0.8/include/sound/driver.h:42,bash: In: command not found[root@localhost alsa-driver-1.0.8]#                  from ../../alsa-kernel/core/ioctl32/hwdep32.c:21,bash: from: command not found[root@localhost alsa-driver-1.0.8]#                  from hwdep32.c:16:bash: from: command not found[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:60:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:60:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:70:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:70:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:187:41: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:187:41:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:258:62: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:258:62:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:270:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:270:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:306:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:306:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:431:41: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:431:41:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:450:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:450:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:474:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:474:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:484:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:484:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:499:41: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:499:41:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:509:41: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:509:41:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:524:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:524:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:531:42: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:531:42:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:536:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:536:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:540:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:540:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:547:40: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:547:40:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:559:42: missing binary operator before '('bash: /usr/src/alsa/alsa-driver-1.0.8/include/adriver.h:559:42:: No such file or directory[root@localhost alsa-driver-1.0.8]# In file included from seq32.c:3:bash: In: command not found[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:2:2: #error "======================================================="bash: /usr/include/linux/version.h:2:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:3:2: #error "You should not include /usr/include/{linux,asm}/ header"bash: /usr/include/linux/version.h:3:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:4:2: #error "files directly for the compilation of kernel modules."bash: /usr/include/linux/version.h:4:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:5:2: #error ""bash: /usr/include/linux/version.h:5:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:6:2: #error "glibc now uses kernel header files from a well-defined"bash: /usr/include/linux/version.h:6:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:7:2: #error "working kernel version (as recommended by Linus Torvalds)"bash: /usr/include/linux/version.h:7:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:8:2: #error "These files are glibc internal and may not match the"bash: /usr/include/linux/version.h:8:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:9:2: #error "currently running kernel. They should only be"bash: /usr/include/linux/version.h:9:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:10:2: #error "included via other system header files - user space"bash: /usr/include/linux/version.h:10:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:11:2: #error "programs should not directly include <linux/*.h> or"bash: /usr/include/linux/version.h:11:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:12:2: #error "<asm/*.h> as well."bash: /usr/include/linux/version.h:12:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:13:2: #error ""bash: /usr/include/linux/version.h:13:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:14:2: #error "To build kernel modules please do the following:"bash: /usr/include/linux/version.h:14:2:: No such file or directory[root@localhost alsa-driver-1.0.8]# /usr/include/linux/version.h:15:2: #error ""bash: /usr/include/linux/version.h:15:2:: No such file or directory[root@localhost alsa-driver-1.0.8]#
ratujcie bo nie chcę się rozstawać z moją mandarynką 9.1 bez dźwięku nie da się żyć. Jakby coś to pomogła to wersja jądra jest taka
2.4.21-0.13mdk i nadodatek napewno postępuję po kolei więc prosze nie pisać tekstów typu: sprawdz czy wszystko dobrze przepisujesz kub popatrz na kolejność !!
PS. Zaznaczam że jestem początkującym użytkownikiem mandrake i musze mieć wytłumaczone to łopatologicznie czyli na prosty chłopski
Zrodla jadra zawieraja drivery alsy. Dla wbudowanych kart dzwiekowych zazwyczaj wystarcza to, co jest w jadrze. Najprostsza droga bedzie kompilacja modulow do jadra po uprzednim jego skonfigurowaniu. Poza tym ten artykul wyglada na jakis stary. Ja na 2.6.10 nie mam zadnego problemu z uzyskaniem dzwieku przez alse z mojego wbudowanego odidżi ;-) AC97.
1303852[/snapback]
Może nie zauważyłeś ale on ma jądro z serii 2.4.x a tam jeszcze nie było alsy w jądrze tylko trzeba ją było oddzielnie instalować.
-with-kernel=/usr <- ja kompilowalem alse na moim starym kernelu 2.4.x bez tego
ten log o bledach wyglada jakby wypisywal komentarze z tego *.h :blink: cos tam musisz robic nie tak, ew brak jest znaczka komentarza w tym pliku "/* */", ale to chyba niemozliwe
najlepsza opcja w tym momencie to skompilowanie jadra 2.6.10, albo powrot do windowsa :wink:
Edytowane przez dondexterro
dobra to ja zainstaluję najpierw nowe jądro 2.6.10 słyszałem że ono jest już w w miarę stabilne i dam odpowiedź co i jaka poszło
ODP dla Paranoika: ja nie wiem co to jest ale coś takiego mi sie wyświetliło a to była tylko końcówka tego co było napisane :unsure:
1306604[/snapback]
Z założenia jądro 2.6 jest w gałęzi stable ;]
Co do tego co napisałem: po prostu wziąłeś loga ze schowka i wrzuciłeś na konsolę ;]
J tam używam OSS w Linuxie ;)
1306695[/snapback]
Przestarzałe ;]
Hmm... jakoś z alsą nie mam żadnych problemów przy dwóch kartach dźwiękowych. Pewnie czegoś nie wkompilowałeś ;>
1309478[/snapback]
nawet mnie nie denerwuj :] kompilowalem (testowalem) od 2.6.7 do 2.6.10.... kazde kompilowalem po 3x, szukalem po guglach jak skompilowac zeby mi karta dzialala i kupa (epox 8rda+, nvidia Nforce2) niby wszystko dobrze, a jednak nie... a pod 2.6.2 jak kompilowalem to wszystko ladnie dziala (tez sprawdzalem), teraz mam 2.6.8.1 i jade na OSS.
a probowales nie wkompilowac w jadro alsy i sobie samemu ja kompilowac ?
i zauwaz ze najnowy kernel to 2.6.11
ooooo masz plyte na nforce2 =D
przeczytaj http://forum.purepc.pl/index.php?showtopic=116223
