Slayer
X-Box 2- niezły ciągnik ;-)
UK Gossip shows XBOX 2 Specs
"Here we go again. According to some rather paranoid sources, here's what developers in the UK have been told to work towards by Microsoft
18:33 Following an intense round of rumour in the past 24 hours, a set of specs has emerged which apparently relates to Xbox 2.
Sources have leaked the figures, but have made clear that this is not a look at final hardware, but merely a guideline to certain developers - such as Rare and Lionhead - for the construction of their next-generation Xbox games.
Read more...
According to sources, Xbox 2 games about to go into development are looking at the following specs as a guide:
2.8Ghz Pentium 4 central processor
512MB of RAM
NV30 graphics chip
. "People are very edgy about this due to some serious NDAs [Non-Disclosure Agreements - Ed]," said one insider under conditions of strict anonymity. "But you have to understand that this is simply Microsoft getting ready for the next round of development. These specs are pretty widely known in the development community right now."
It's worth noting that nVidia's NV30 chip will be seriously under-powered come 2004; the chip releases later this year. But the mere fact the chip is made by nVidia throws up yet more questions; nVidia, following a legal spat with Microsoft earlier this year about earnings and sales projections, is now widely tipped to be out of the running to supply Xbox 2's GPU.
Both these points clearly show that these specs are merely telling developers to work at a far higher end than current Xbox hardware allows. Even for the dev kits, these are not final specs by any means.
The news emerges as those close to Rare, Lionhead and Microsoft confirm that preliminary rounds of talks regarding Xbox have already got under way in the UK.
So there you go. Xbox 2 games will run faster and look prettier than Xbox games. That's entertainment.
Source: Patrick Garrat, computerandvideogames.com
tekst z www.m3dzone.com 8)
hmm... ale i tak sony ze swoim PSX3 pokona x-pudło 2 (chyba) tak jak była sytuacja z x-box'em vs psx2 i co... x-box mimo że miła kąsolka zprzedaje się mizernie ponieważ ma słabsze gierki a jak wiadomo jeżeli konsolka ma słabe gierki to nie ma prawa bytu w dzisiejszych czasach.
Nie no chociaż na x-box'a DoA3 i Halo są rulezzzzzzz.
O ja pie***le, nawet nie jestem wstanie sobie wyobrazić jak będą wyglądały giery, w porównaniu do tych z pierwszego klocka, bo specyfikacja zabija jak na konsole
Ja tam nie wiem ale chodzą dziwne plotki że PS3 Sony ma być 200x, szybsze od PS2, 16 procesorów on chip i takie tam;) Ciekawe co z tego wyjdzie.
Jeżeli myślicie że po włożeniu do kompa nv30 i zaje**ście szybkiego proca + 2gb ramu, i gry będą lepiej chodzić niż na klocku 2, to się mylicie, proponuje zapoznać się z takimi tytułami jak DOA3, HALO, PROJECT GOTHAM, itp. i ruszyć wyobraźnią co będzie na klocku2
aplikacje na konsole są bardzo dobrze zoptymalizowane ze wglądu na to że będą chodzić wszędzie na takim samym sprzęcie. Dlatego nawet na słabszym procku grafie będzie na płynniejsza i ładniejsza grafika. W konstrukcji Pcetów nie da sie tego zrobić gdyż gierka chodziła by dobrze na jednym rodzaju sprzętu a na innym mogła by być całkowita klapa, robione są wiec tak aby działały wolniej ale na każdej konfiguracji (co i tak nie zawsze sie udaje :wink: )
ale są gierki których nigdy nie będzie na PC a dla których warto koopić konsole
No tak ale dobrych gier na konsole nie jest zbyt duzo, imho wielokrotnie mniej niz na PC, a moze ja jestem wymagajacy...coz konsole to inny typ gier...i styl ich robienia.
Ale nie bierzecie pod uwagę jednej rzeczy, że gry na konsole mają niesamowitą dawkę miodu, ja mam teraz full wypas gier na pc, każdą jaką tylko chcę to mam, sprzęcik wyje**ny w kosmos ( no może trochę przesadziłem, ale nie narzekam :) ) i co z tego jeżeli gram w 3, może 4 tytuły, te gry na konsoli to są tytuły przy których można spędzić 100, 200 a nawet 300 godzin, pamiętam jak męczyłem FF7 na playaku pierwszym, miałem wygrane kilkaset godzin, zdobyłem wszystko co można było zdobyć, i jeszcze mi się nie znudziła, aktualnie nie mam żadnej konsoli :( (studia i takie tam) ale jak tylko będę mógł to zaopatrzę się w porządny sprzęt do giercowania jakim jest konsola, widziałem u qmpli na klocku i pes dwójce kilka gierek, pograłem trochę i powiem jedno, mało która gra na piecyku jest wstanie mnie przyciągnąć z taką siłą, a grałem w niejedną, polecam obczajenie kilku gierek na konsoli, a zrozumiecie o czym piszę
jedno co mi najbardziej brakuje po przejściu na kompa to te piękne pady
zaczynam powoli żałować że sprzedałem psx'a  :(
Do PCeta można podłączyć również pady od PSXa, tylko z użyciem przelotki.
Gry na konsolki są fajne, zwłaszcza na PS2 (mordobicia), ale nie ma na nie wielu gier, które są na PCeta. Najlepeij jest mieć zarówno konsole jak i PC, ale w Polsce jest to rzadkością. Jeżeli trzeba wybierać pomiędzy gierkami na PC i konsole, to chyba wolę kompa.
Co do gier na PC, to producenci wcale nie robią gierek z wysokimi wymagaganiam, żeby chodziły na każdym sprzęcie, tylko dlatego, że im się nie chce męczyć. Inna sprawa - gierki na kosolach chodzą w niższych rozdzielczościach i maja okrojone detale w stosunku do PCetowych. Jak się producenci postarają, to gry chodzą ok. Jako przykład mogę podac dwie gierki, które wygladają prawie tak samo - War Gods i Mortal Kombat 3 - ta pierwsza chodziła w 1024/768 na P120 bez problemu, a ta była jak pokaz slajdów.
juz zaczyna padac np. halo tylko na x-box-a a mial byc na pc , sierra wydawala tylko gry na pc a teraz wkroczyla na polepko konsol , tworca B&W twozy juz tylko na konsole , a quake 4 moze byc tylko na x-box-a jeszcze nie potwierdzone
rynek gier pecetowych zdechnie ? mial to juz robic dawno. A tu tylko nowosci, ciagle nowe pomysly. Pc nie upadnie. To nie Amiga.
Rynek gier PC zmniejsza sie coraz bardziej i to jest fakt, wystarczy zobaczyc co dzieje sie na targach gier. Nowosci sa zawsze :) ale nowe pomysly? hmmm tych jak na lekarstwo imo...A Amiga robi dalej komputery, ostatnio pare nowych modeli sie pojawilo.
