SpiderMAN
Radeon 9500 ---> Radeon 9700 - to działa!!!
dosyc dokladne wyjasnienie niestety po angielsku
Exactly. It's the usual ixbt bull s&^%%. The early prototype 9500's were built on the 9700 PCB. The actual 9500's are built on another PCB which uses traces only for a 128-bit bus (people commonly make the mistake of thinking there's something different about the ram used in a 128-bit bus card and a 256-bit bus card--there's not--it's the design of the bus on the PCB which is different.) *chuckle* There's no way to turn a 128-bit 9500 into a 256-bit 9700, unless you have a prototype board--or a very early 9500--which was manufactured using the 9700 PCB.
It's amazing to me how in the dark Ixbt can be at times. Aren't they aware that the 9500's are no longer being built on the 9700 PCB? The differences are clear and obvious, and the fact that ATI changed the 9500 PCB prior to shipping in quantity was well covered on the Internet weeks ago--you can tell the PCBs apart merely looking at pictures of them--it's that obvious. In a 256-bit bus card you can see bus traces on all four sides of the ram chip. In the 128-bit bus PCBs you can see traces only on two sides of the ram chip. There is absolutely no way that anyone can change *that* with a resistor. *chuckle* It'll be interesting to see if they have the guts to run this article in english.
Good grief. Tell the truth, I'm surprised Rage3D dignified the story by carrying it.
Serwis Overclockers.ru zamieścił artykuł pokazujący, jak najtańszą wersję kart Radeon 9500 128MB "zamienić" na Radeon 9700, poprzez przemieszczenie jednego rezystora na układzie graficznym. W sieci zrobiło się gorąco i wiele osób bardzo mocno nastawiło się na zakup kart graficznych Radeon 9500 128MB oraz ręczną zamianę na kartę z ośmioma (zamiast czterech) potokami pikseli oraz 256-bitową (zamiast 128-bitowej, co niestety wbrew Overclockers.ru, nie jest prawdą) magistrali pamięci. Tymczasem, niestety serwis Overclockers.ru nie przedstawił całej prawdy i nie przestrzegł potencjalnych "modderów" przed niebezpieczeństwem, którego raczej mało kto by się spodziewał. Mianowicie karty Radeon 9500 128MB, które udało się zamienić na Radeon 9700 to tak naprawdę tylko wczesne konstrukcje kart Radeon 9500 128MB, wyprodukowane na płytkach PCB, dokładnie takich samych jak Radeon 9700/9700 PRO. Karty te już nie są produkowane i zastąpione zostały nowymi, na zmienionych płytkach PCB, których NIE DA SIĘ przerobić tak, jak wszyscy się tego spodziewają ! Nowe karty Radeon 9500 128MB już są ponoć na rynku (nikt tego nie chce potwierdzić, chyba ze względu na fakt iż wiele osób wycofałoby zamówienia) i z pewnością tylko w niektórych sklepach między nimi, w magazynach mogą zalegać "te poprzednie". Dodatkowo, głównie firma Sapphire, wprowadziła na rynek karty Radeon 9500 128MB na płytkach PCB Radeon 9700/9700 PRO. W dodatku są to tylko wczesne wersje testowe, które posiadają 256-bitową magistralę pamięci już w standardzie (bez modyfikacji!) ! Najprawdopodobniej, "prawdziwe" karty Radeon 9500 128MB są produkowane na PCB Radeon 9500 PRO. Będzie je można (prawdopodobnie) także przerobić, ale tylko uaktywniając cztery, zablokowane potoki pikseli. Tak zmodyfikowana karta będzie co najwyżej kopią Radeon 9500 PRO, jednak czy to się opłaci ? Chyba absolutnie nie, gdy różnice w cenach pomiędzy Radeon 9500 128MB a Radeon 9500 PRO 128MB są znikome. W tym drugim przypadku dodatkowo nie ryzykujemy i co najważniejsze, nie tracimy gwarancji gdyż nie potrzebne są modyfikacje.
Mnie osobiście też zastanawiało, dlaczego tylko Radeon 9500 PRO bazuje na innej konstrukcji PCB, skoro podobnie jak Radeon 9500 posiada 128-bitową magistralę pamięci... Teraz należy bardzo uważać przy zakupie i na nadzieje w nim pokładane.
cytuje przedmówce
Dla mnie głupota jak może mieć 256bit jeżeli w testach wypada tak samo jak normalna karta z pamiecia 128bitów
Zastanówcie sie nad tym ktoś tu coś kręci :)
PS:to i tak wina micrsraftu hehehe
CZYLI JAK KUPOWAĆ R9500 128MB TO TYLKO TERAZ!!!. PS. A WY SIE JESZCZE ZASTANAWIACIE CZEMU TAK TRUDNO DOSTAC WERSJE Z 128MB :) poprostu juz ich nie ma :) szczesciaze sprzedawcy ktorzy zamówili :). Teraz nowa partia w sklepach juz pewno bedze na PCB od 9500Pro :)
  Cytat
  Cytat
Qurde mogli by cos wymysleć z 9500Pro 128MB, fajnie by było
sadze ze u Ciebie po prostu zmiana polaryzacji tej nozki (przlutowanie opornika) powinna otworzyc zablokowane 128bit szyny dla memorkow bo potokow masz 8 waerto sprobowac
Czyli 9500 Pro przerabia się tak samo jak 9500 bez pro??
teraz sprawa sei zmienila
ale wszystko jest zalezne od jedna wersja
karta ma wygladac jak radek 9700
nowych nie da sie przerobic bo mimo powiedzmy tesh 128Mb ati pamieci ustawia jako 2x64bit (128) a nie jak dotychczas (8x32)
i tylko potoki da sie odblokowac
ale kart na starym laminacie byly sa i beda
  Cytat
Szyt! Szyt! Szyt! Akurat w piatek kupilem R 9700 PRO... wprawdzie za cene golego 9700, ale to i tak 500zl drozej od tego rzekomego 9500 "Pro"  :D
Juz sobie pluje w brode, ktorej nie mam  :!:
nie masz co żałować zawsze ty możesz pokazać, że masz lepsza wystarczy zę 9700pro przetaktujesz :) ale i tak wole 9700 pro niż przeróbkę jak by to było takie proste i na 100% nie wpływające na żywotność karty to była by głupota ze strony ATI ale myślę, że chyba ATI śmieje się z co niektórych co modowali i zaciera ręce bo karta padnie szybciej a ludziska kupią następną :) taka może być prawda o modyfikacji R9500
  Cytat
wiesz Ndx bede mial kase a nei bedzie kart w polsce (mysle ze do tego nie dojdzie) to bedzie trzeba kombinowac tylko zeja od razu 2 biore dla siebie i brata sciagniemy sobie to nas i tak sporo taniej ewyjdziee
grzybo wiecej ze sporo Taniej !! wyjdzie was w cenie 9500 ! a bedziecie mieli 3 lata gwaranacji itd hmm wysylka 2 karta z kanady poczta ubezpieczona bo wlasnie slslaem 2 x 9700 40zł po 7 dniach byla u klijenta cla i bezpieczna :-) :D
Interpoler jakie znajomosci szuaksz sklepu <span style="color:red;">ORT: ORT: ORT: ORT: ORT: ORT: ktury</span> wysyla do polski a albo zglaszaz sie odmnei ja zakupuje i wysylam :D !!
  Cytat
  Cytat
ja juz sie nacialem dwa razy na zakupy internetowe, dlatego wole sobie kuic lokalnie, mam w dwoch sklepach znajomych, gdzie zawsze dostane po cenie hurtowej + vat, przynajmniej widze co kupuje ;)
  Cytat
  Cytat
  Cytat
jasna sprawa ktos sie boi to escrow pozatym jak ja sprzedaje to mam znajomych wyslam tam do danego miasta gdzie kto mieszk ai przy odbiorze sprawdza !! ale przewag asklepow w necie lepsze ceny niz real nawet hurt !!
  Cytat
w te "newsy" z frazira nie uwierze jak mi nikt nie przedstawi linkow do zagraniczych stron z taka sama rewelacja.
Co do wielkosci opornika i "jakosci" lutow:
Dołączona grafika
Dołączona grafika
Dołączona grafika
mam GF4Ti 4200 i w 3dMarku mam 11280bez podkręcania karty także wątpie żebym się pokusił na zmiane karty wole zaczekać do lutego na premiere nowego dziecka nvidii
  Cytat
kupilismy go dzisiaj na gieldzie komp. w Wawie za 920 zl.
Ktos prosil o 3DMarka 2001
Najwazniejsze - taktowanie karty 275/275 czyli mniej niz 9700Pro
Komp:
P4 1,6 o/c 2,4
512DDR300MHz
Windows 2000 SP3
Catalyst 2,5, DX9.0
Dołączona grafika
Total 12964
Game 1 low 176,5
Game 1 high 58,4
Game 2 low 249,8
Game 2 high 131
Game 3 low 168,3
Game 3 high 73,1
Game 4 - 88,5
Fillrate single 1547,9
Fillrate multi 2179,4
Highpoligon count 1 light 61,5
-\\- 8 lights 12,8
EVMB 178
DOT3 179,9
Vertex shader 164,7
Pixel shader 168,1
Adv -\\- 173,1
Point spirites 33,9
dziwi mnie jedno zobaczcie moją rozpiskę i mam mniej niż on
3DMark Score
(3D marks) 12724
Game 1 - Car Chase - Low Detail
(FPS) 158.5
Game 1 - Car Chase - High Detail
(FPS) 52.5
Game 2 - Dragothic - Low Detail
(FPS) 250.2
Game 2 - Dragothic - High Detail
(FPS) 131.7
Game 3 - Lobby - Low Detail
(FPS) 150.8
Game 3 - Lobby - High Detail
(FPS) 66.1
Game 4 - Nature
(FPS) 106.2
Fill Rate (Single-Texturing)
(MTexels/s) 1743.9
Fill Rate (Multi-Texturing)
(MTexels/s) 2520.6
High Polygon Count (1 light)
(MTriangels/s) 60.3
High Polygon Count (8 lights)
(MTriangels/s) 13.7
Environment Bump Mapping
(FPS) 213.5
DOT3 Bump Mapping
(FPS) 232.6
Vertex Shader
(FPS) 166.7
Pixel Shader
(FPS) 214.3
Advanced Pixel Shader
(FPS) 200.2
Point Sprite Speed
(MSprites/s) 38.7
No ale oczywiście mam gorszy procek od niego wiec co sie mogę spodziewać :) dajcie mi P4 to zobaczycie co 9700 potrafi zaznaczę że karta nie była jeszcze podkręcana firmowy bios !
  Cytat
he he nie kumam was zrąbiecie nową korte a potem będą posty komp mi sie wisza POMOCY lub zjarany Radeon 9500 MOD :) już widzę te błagane posty jak któś wywali w kosz 900 zł
co ty chlopie tak przezywasz jak ktos moze zaoszczedzic 500zl i sie nieboi to daj mu ..... . cie stac na to zeby zapodac 9700 no i masz po klopocie . chociasz niemusisz miec sokolego wzroku i dobrej lutownicy;)
Thorn - w 3dmarku licza sie tylko pierwsze testy. Chocbys mialw pozostalych 2x wieksza przewage to i tak nie bedziesz mial lepszego wyniku od karty, ktora ma wiecej fps w pierwszych testach (grach). 3dmark byla napisany w 2000 roku i chodzilo tylko o pkt na w miare dobrych kartach dzisiaj, a w tamtych czasach na wypasach, ktore ledwo obsluguja pixele.
  Cytat
orientujesz sie moze jaka moze byc roznica w punktach jak sie zrobi cały test w porownaniu do tylko 4 pierwzsytch ?
