elmo123 Opublikowano 10 Września 2006 Zgłoś Opublikowano 10 Września 2006 zakłorzyłem wczoraj domene na dyndns ..i wszystko grało ...a dziś rano kicha ...wchpodze na swoje konto i w właśniwości mojej domeny a tam zamiast info o IP mam taki list : "Your host, mk123.blogdns.com is currently blocked for abuse. The abuse system automatically blocks any hostname that repeatedly tries to update a hostname from the same IP. This is done to conserve bandwidth and prevent computers from updating every 5 minutes, regardless of whether or not their IP address had changed. Updates should only be performed when your IP address has changed, regardless of interval. The only exception to this rule is if your IP address has not changed in the past 28 days and you want to prevent your hostname from expiring. This is the only way to ensure that your host will not become blocked for update abuse. Hosts which remain blocked for update abuse for a period of 7 days or more are automatically deleted from our systems and an e-mail notification will be sent. If this happens, the host can simply be re-created, but you should re-examine your update procedure to ensure that abusive updates do not occur in the future. Most blocks are due to client applications automatically sending updates at timed intervals, or at system startup without checking if the IP address has actually changed. If your client doesn't support only sending updates when your IP address has actually changed, please look at our client listing for one that does. " O co chodzi P.S. Nie mam zainstalownaego programu tylko moj router obsługuje "Dynamic dns" i tam am skonfigurowane na aktualizacjre Ip Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
sajmon Opublikowano 10 Września 2006 Zgłoś Opublikowano 10 Września 2006 Twoj router za czesto uaktualnial domene, masz moze w nim co ile ma byc wysylana informacja o adresie ip ? albo opcje dzieki ktorej bedzie wysylal informacje do dyndns tylko po zmianie ip? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
elmo123 Opublikowano 10 Września 2006 Zgłoś Opublikowano 10 Września 2006 (edytowane) Niestety nic takiego nie ma ....w zakładce Dynamic DNS Client ..jest tylko Enable ... Status: DDNS Client started Dynamic DNS Provider .... Hostname .... Username .... Password .... i to wszystko.... jest na to jakieś lekarstwo ?? moze jakiś inny usługodawca ...ktory sie o to nie pluje czy router USR 9107A .... ma taka funkcje ?? Edytowane 10 Września 2006 przez elmo123 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
sajmon Opublikowano 12 Września 2006 Zgłoś Opublikowano 12 Września 2006 Poszukaj aplikacji ktora bedziesz mogl uruchomic na swoim kompie, i ktora bedzie wysylala twoj WAN IP do dyndns.org. Programy klienckie maja wieksze mozliwosc konfiguracji (np. odstepy czasowe w jakich maja byc wysylane informacjie o ip). Jedna wada ze domena nie bedzie uaktualniania gdy wylanczysz swoj komputer. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
elmo123 Opublikowano 12 Września 2006 Zgłoś Opublikowano 12 Września 2006 właśnie nie moze być zaden program ..po do sieci nie ma podłączonego kompa/...router +rejestrator(taka skrzynka która bierze sygnał z kamer przemysłowych towrzy u soebie serwer Http i publikuje wideo z tych kamer live)...ale znalazłem tradycyjną metoda (licz tylko na siebie )...uslugodawce changeip.com chodzi juz przez 2 dni i jak narazie spoko Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
