Jump to content
Caleb
Geforce 8800 GTX / GTS
Recommended Posts
Ustawiasz na sztywno w ustawieniu sterownika , i musisz zmienic nazwę pliku exe na R6Vegas_game.exe i AA działa super :)
pozdrawiam.....
thx za info, ustawilem tak jak napisales ale jakis ten AA malo wydajny w Airbonie w menu gry przy ustawieniu AAx16 nadal na krawędziach skrzydeł samolotów są male ząbki troche tylko złagodzone :) a moze to tylko w menu tak jest
Tak ustawiam w sterkach
http://img383.imageshack.us/img383/4365/46425040ez0.png
menu gry z AAx16 ? czy oby napewno aa jest załączone bo juz sam nie wiem
http://img486.imageshack.us/img486/2839/90499385gz6.png
Edited by PeterMac
Share this post
Link to post
Share on other sites
Problemy z podkręcaniem wyjaśnia Unwinder w TYM, wątku.
"...with the past driver families the ForceWare automatically overclocked G80 shader domain synchronicallly with ROP domain using BIOS defined Shader/ROP clock ratio. Starting from 163.67 drivers internal ForceWare overclocking interfaces no longer scale shader domain clock when ROP clock is adjusted and the driver now provides completely independent shader clock adjustment interface. It means that starting from ForceWare 163.67 all overclocking tools like RivaTuner, nTune, PowerStrip or ATITool will adjust ROP clock only..."
"The driver’s clock programming routine is optimized and it causes unwanted effects when you’re trying to change shader domain clock only. Currently the driver uses just ROP domain clock only to see if clock generator programming have to be performed or not. For example, if your 8800GTX ROP clock is set to 612MHz and you need to change shader domain clock only (directly or via specifying custom or shader/ROP clock ratio) without changing current ROP clock, the driver will optimize clock frequency programming seeing that ROP clock is not changed and it simply won’t change the clocks, even if requested shader domain clock has been changed. The workaround is pretty simple: when you change shader clock always combine it with ROP clock change (for example, if your 8800GTX ROP clock is set to 612MHz and you’ve changed shader clock, simply reset ROP clock to default 576MHz, apply it, then return it to 612MHz again to get new shader clock applied). I hope that this unwanted optimization will be removed in future ForceWare, and now please just keep it in mind while playing with shader clock programming using RT 2.04 and 163.67.
2) Currently Vista driver puts some limitations on ROP/shader domain clocks ratio you’re allowed to set. Most likely they are hardware clock generator architecture related and hardware simply cannot work (or cannot work stable) when domain clocks are too asynchronous. For example, on my 8800GTX the driver simply refuses to set the clocks with shader/ROP ratio within 1.0 – 2.0 range (default ratio is 1350/575 = 2.34), but it accepts the clocks programmed with ratio within 2.3 – 2.5 range. Considering that the driver no longer changes domain clocks synchronically and all o/c tools (RT 2.03, ATITool, nTuner, PowerStrip) currently change ROP clock only, that results in rather interesting effect: you won’t be able to adjust ROP clock as high as before. Once it gets too far from (or too close to) shader clock and shader/ROP clock ratio is out of range – the driver refuses to set such clock. Many of you already noticed this effect, seeing that the driver simply stops increasing ROP clock after a certain dead point with 163.67
Share this post
Link to post
moze troszke noobowskie pytanie...Ale mozliwosci OC mojego asusa konczą się na 621/950, myslicie ze zmiana biosu karty moze pomoc i czy więcej z tej karty wyciagne?
mało prawdopodobne .....
Tak jest tylko w menu w gierce jest juz ok......
Share this post
Link to post
Mam takie pytanie - zróbcie sobie test DirectX dot. Direct3D (te kręcące się kostki) i czy u was też na 8800GTS dziwnie zachwuja się cienie? Grafika jest OK ale ścianka która podczas obrotu kostki staje sie nie widoczna nagle robi sie ciemna....a powinno byc płynne przejście, nie jest to jakiś efekt bardzo widoczny ale po kilku probach widac to. Pytam o to gdyż mam problem z grafiką np. w TR Anniversary (migają cienie, złe odbicia np. w mieszkaniu lary w posadzce - są tylko na jakims obszarze) ale np. w Bioshock czy MOH:A jest wszystko OK. Bledy sa na sterach oficjalnych jak i betach ale tych przed ostatnich. Proszę o sprawdzenie waszych testów direct3d. pozdro.
Share this post
Link to post
Bardzo wątpię. Z tego co widzę to takie osiągi na asusie to niemal standard. Wiatrak mam na ustawieniu auto i dla uzyskania pełnej stabilności w nieograniczonym czasie musiałem zjechać do 612. Powyżej tej wartości szedł do 20 ale po jakimś czasie trybu 3D aplikacja wywala się do pulpitu a vista obwieszcza błąd sterownika graficznego. Artefaktów przy 950 dla pamięci nie miałem ale "dla bezpieczeństwa i stabilności" zjechałem do 928.
Share this post
Link to post
Te ostatnie bety ogólnie mają jakiś feler z pamiętaniem (ewentualnie specjalnie tak zostały skonstruowane) choć u mnie objawia się to gubieniem ustawień systemu koloru dla TV. Po każdym uruchomieniu muszę przestawiać się ręcznie na Pal. Za to zegary pamiętają, aż do momentu ewentualnego błędu sterownika graficznego - wtedy ustawiają wartości taktowania dla rdzenia domyślne i to na sztywno - niczym sie nie da zmienić. Po restarcie i ponownym ustawieniu już jest ok i to akurat pamięta aż do następnego błędu sterownika.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
