radiergummi Posted July 10, 2012 Report post Posted July 10, 2012 (edited) BenQ GW2450 Review: http://www.tftcentra...nq_gw2450hm.htm Edited July 10, 2012 by radiergummi Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 10, 2012 Report post Posted July 10, 2012 (edited) BenQ GW2450 Review: http://www.tftcentra...nq_gw2450hm.htm Dla ostudzenia: http://mva.pl/viewto....php?f=26&t=608 Edited July 10, 2012 by Tom01 Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 10, 2012 Report post Posted July 10, 2012 (edited) Osobiscie juz wole o niebo Eizo FS2331 wprawdzie droższy od tego Benka ale to inna klasa, gdyby nie 16:9 już by u mnie stal na biurku. Cos sie nie moge przełamać do 16:9, ale miałoby to tez zaletę bym sobie zklonowal obraz razem z TV bez żadnych pasków jak przy Dellu 16:10. Edited July 10, 2012 by PeterMac Quote Share this post Link to post Share on other sites More sharing options...
toms83 Posted July 12, 2012 Report post Posted July 12, 2012 23" 16:9 to maleństwo. Niższe to to niż mój pierwszy 19" 5:4. :( Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 12, 2012 Report post Posted July 12, 2012 (edited) za duzy nie jest fakt http://www.displaywa...s-24-inch-16x10 btw. kurcze czemu w tym S2433W nie ma HDMI tylko dali tam DisplayPort ktore jest praktycznie bezużyteczne. Edited July 12, 2012 by PeterMac Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 12, 2012 Report post Posted July 12, 2012 Jak nie ma? DVI i HDMI to to samo. Wystarczy przejściówka za 9 zł. Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 12, 2012 Report post Posted July 12, 2012 (edited) to ja wiem naturalnie, ale DVI zajęte przez podpięty komputer, a teraz jak podpiąć konsole, player sieciowy, tuner sat czy cokolwiek innego z wyjściem sygnału HDMI nie mając wejścia HDMI w monitorze które powinno być standardem uważam tym bardziej jakby nie patrzeć w drogim monitorze, na dodatek mającym tylko jedno wejście DVI. Jedynie ratuje zakup b.drogiej przejściówki aktywnej HDMI > Displayport koszt 200-300zł i na dodatek kolejny zasilacz i kabel idący od tego . Wiesz może czy przyjmuje ten model audio po DVI jesli mówimy o przejściówce DVI - HDMI ? Edited July 12, 2012 by PeterMac Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 12, 2012 Report post Posted July 12, 2012 A jest jakiś problem w podłączeniu karty i monitora DP? To juz nie egzotyka. Podobno, choć nie próbowałem, mozna w ustawieniu karty graficznej wpuścić dźwięk w DVI i monitor będzie grał. Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 12, 2012 Report post Posted July 12, 2012 (edited) Jeśli karta graficzna ma wyjścia tylko DVI to jak chcesz podpiąć w łatwy sposób pod DP w monitorze nie stosując aktywnej drogiej przejściówki tego typu ? http://www.misco.co....ctive-Converter (tylko ponad 60 funtów) Z tym dźwiękiem z komputera po DVI to fakt można, nie problem ale to z komputera, z takiego tunera sat, czy z innych urządzeń zazwyczaj jest to nie możliwe, ale wtedy w sumie to juz nie zależne od monitora Edited July 12, 2012 by PeterMac Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 12, 2012 Report post Posted July 12, 2012 Chodziło mi o kartę z wyjsciem DP. Taniej niż stosowanie często niedziałających przejściówek. Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 12, 2012 Report post Posted July 12, 2012 Wiesz jak ktoś ma mocną kartę pokroju GTX570 czy coś podobnego to przecież nie bedzie zmieniał tylko dlatego ze brakuje tam DP, a jest np 2xDVI, 1xminiHDMI. Quote Share this post Link to post Share on other sites More sharing options...
Conti Posted July 14, 2012 Report post Posted July 14, 2012 A czy ktoś już przetestował Eizo FS2333 ?? Filmik z gier wygląda pozytywnie, ale oprócz gier są jeszcze inne potrzeby .... Aczkolwiek Diablo mnie wessało jak żadna inna gra od wielu lat. Quote Share this post Link to post Share on other sites More sharing options...
Koen Posted July 14, 2012 Report post Posted July 14, 2012 (edited) Witam, mam pytanie dotyczące głównie monitora Eizo s2233w, ponieważ jest szeroko-gamutowy i nie ma efektywnego trybu sRGB. Jak uciążliwe jest używanie na takim monitorze aplikacji nie posiadających profili Color Management? W kilku zakątkach internetu natrafiłem na pokrywające się opinie że bez CM monitor może łapać czerwony zafarb a takie coś było by dla mnie nie do zaakceptowania. Czy dysponuje ktoś przykładami pokazującymi jak dany obraz sRGB zostanie przekoloryzowany na szerokogamutowym monitorze? Zastanawiam się czy w tym wypadku nie lepszym wyborem będzie wąsko-gamutowy monitor IPS, np. HP ZR2440W lub jego poprzednik ZR24. Tylko ta czerń... ale rzadko pracuję na czarnym tle, więc może świecące narożniki nie będą problemem. Od 6 lat używam Eizo S1931 i S2233w wydaje się naturalnym następcą, tylko ten szeroki gamut... Edited July 14, 2012 by Koen Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 14, 2012 Report post Posted July 14, 2012 Do zastosowań gdzie kolor nie jest istotny, czyli przede wszystkim rozrywka, można posłużyć sie wbudowanym "trybem" sRGB. Quote Share this post Link to post Share on other sites More sharing options...
Koen Posted July 15, 2012 Report post Posted July 15, 2012 Tylko po co się nim posługiwać skoro w monitorach serii S w praktyce tryb sRGB zupełnie nic nie daje i dobrze Pan o tym wie. Po przeczytaniu tego tematu jestem już dość mocno zniechęcony do Eizo bo o ile większość czasu spędzam w programach graficznych, to chciałbym aby monitor wyświetlił poprawnie też gry i filmy (poprawnie tzn. bez męczących dla oczu, przejaskrawionych kolorów). Najgorsze jest tylko to że o ile nie chcemy wydać 3000zł na 22-calowy monitor, to musimy się godzić albo na przejaskrawione kolory w grach i filmach, albo na świecącą czerń w matrycach IPS. I to po 6 czy 7 latach od wyjścia monitora który nie miał żadnej z tych wad (s1931). Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 15, 2012 Report post Posted July 15, 2012 (edited) W jakim kontekście "nic nie daje"? Nie jest to symulacja gamutu, to oczywiste, ale mówimy o monitorach amatorskich-uniwersalnych, które nie powstały z myślą o kontroli koloru. W zastosowaniach do jakich ów sprzęt jest przeznaczony, przycięcie wysterowania kanałów załatwia problem przejaskrawionego koloru w grach i filmach. Ewentualnie do filmów można użyć odtwarzacza z CMS. Drugie wyjście to monitor uniwersalny na sterydach, czyli EIZO SX2262W, CG223W, CG241W z kalibracją gamutu. Rodzaj matrycy, wspomniany IPS, nie ma żadnego związku z gamutem. Wręcz przeciwnie, wszystkie obecnie produkowane IPS-y są szerokogamutowe, przy czym montowane w monitorach z 3DLUT umożliwiającym przycięcie gamutu. To sprzet graficzny i nie ma kompletnie nic wspólnego z tym co Pan zapewne ma na myśli, czyli agresywnie reklamowanymi eIPS-ami z elektroniką z masówki. Edited July 15, 2012 by Tom01 Quote Share this post Link to post Share on other sites More sharing options...
Koen Posted July 15, 2012 Report post Posted July 15, 2012 Pisząc "nic nie daje" odnosiłem się do poniższego cytatu oraz do powtarzających się opinii osób które po włączeniu trybu sRGB nie zauważają żadnej poprawy w aplikacjach nie posiadających Color Management: "Monitor S2233 ma przestrzeń kolorów Adobe RGB ale nie potrafi sprzętowo robić konwersji do sRGB. Ustawianie w monitorze trybu sRGB koryguje do tego standardu tylko punkt bieli i gammę." źródło Przy okazji odkryłem że odtwarzacz którego używam (MPC) ma obsługę profili koloru więc problem jaskrawych kolorów nieco zbladł ;) A co z aplikacjami flash? Czy CM w Firefoksie obejmuje też wideo (youtube, live streamy, gry flash i inne)? Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 15, 2012 Report post Posted July 15, 2012 Pisząc "nic nie daje" odnosiłem się do poniższego cytatu oraz do powtarzających się opinii osób które po włączeniu trybu sRGB nie zauważają żadnej poprawy w aplikacjach nie posiadających Color Management: "Monitor S2233 ma przestrzeń kolorów Adobe RGB ale nie potrafi sprzętowo robić konwersji do sRGB. Ustawianie w monitorze trybu sRGB koryguje do tego standardu tylko punkt bieli i gammę." "Nie zauważają żadnej poprawy" i "nie potrafi robić sprzętowo konwersji do sRGB" to zupełnie inne wypowiedzi. A co z aplikacjami flash? Czy CM w Firefoksie obejmuje też wideo (youtube, live streamy, gry flash i inne)? FF z przestawionym CM w tryb 1 wszystkie elementy graficzne traktuje jako sRGB. Czyli problemu nie ma. Quote Share this post Link to post Share on other sites More sharing options...
Grimlock Posted July 15, 2012 Report post Posted July 15, 2012 Co sądzicie o tym monitorze: Eizo EV2335 http://www.morele.net/monitor-led-eizo-flexscan-ev2335w-gb-gwarancja-5lat-475867/ ? Nie rozważam innych marek. Od 6 lat korzystam z Eizo S1901 domu i S1931/32 w pracy. Zależy mi na tym aby monitor był lekki (będzie stał na obudowie Lian Li PC-C37) i miał niskie zużycie energii. Te warunki EV2335 spełnia, ale jak ma się sprawa z jakością obrazu (IPS vs. PVA) i szybkością wyświetlania oraz "efektem wypalania oczu" po 10h pracy? Nie zajmuję się grafiką i fotografią - za to głównie "pracą biurową z wieloma oknami", od czasu do czasu jakiś film czy gra. Z praktycznych obserwacji widzę wyraźną różnicę w prędkości między S1901 (TN) i S1931 (PVA), a jak to będzie wyglądało z EV2335 (IPS)? Quote Share this post Link to post Share on other sites More sharing options...
OCM4n14k Posted July 15, 2012 Report post Posted July 15, 2012 (edited) Panowie, szybkie pytanie. Jaki monitor 16:10 na IPS do 1600zł? Edited July 15, 2012 by OCM4n14k Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 15, 2012 Report post Posted July 15, 2012 Co sądzicie o tym monitorze: Eizo EV2335 (...) 6 lat korzystam z Eizo S1901 domu i S1931/32 w pracy. Następcą S1931/32 jest S2233W i S2243W. EV 2335 nie ma matrycy IPS tylko eIPS. Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 15, 2012 Report post Posted July 15, 2012 (edited) Panowie, szybkie pytanie. Jaki monitor 16:10 na IPS do 1600zł? chyba Dell U2410 albo HP ZR440W Edited July 15, 2012 by PeterMac Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 15, 2012 Report post Posted July 15, 2012 (edited) Panowie, szybkie pytanie. Jaki monitor 16:10 na IPS do 1600zł? chyba Dell U2410 albo HP ZR440W He, he... pytanie i odpowiedź w stylu: - Panowie, szybkie pytanie. Jaki pojazd z dieslem do x kwoty. - Chyba koparka albo działo samobieżne. Aby cokolwiek doradzić, lepiej dopytać po to co, do czego ma służyć, w jakich warunkach ma pracować? Edited July 15, 2012 by Tom01 Quote Share this post Link to post Share on other sites More sharing options...
OCM4n14k Posted July 15, 2012 Report post Posted July 15, 2012 Programowanie, gry, internet, filmy, wszystko :P. Nie ma ograniczonej specjalizacji dotyczącej monitora, obecnie używam starego HP p1130 i już sprzęt dogorywa. W sumie pasował mi do większości zastosowań, troche denerwowało programowanie jak musiałem zmieniać co chwile okienka, ale nie było tak źle. Właśnie z powodu mojego wiekowego monitora wypadłem z obiegu i to po drukarkach jest moja najbardziej kulejąca dziedzina wiedzy w informatyce :D. Pytanie w rzeczy samej proste, najlepszy monitor 16:10 na IPS do 1600zł, to tak samo jakby zapytać jaką kupić kartę graficzną do 1000zł ;). Quote Share this post Link to post Share on other sites More sharing options...
Polar Posted July 15, 2012 Report post Posted July 15, 2012 Za tysiaka najlepszy 16:10 to DELL u2412m. Za 1600 jest w ogóle taki ? Bo kilka miesięcy temu od 2 tysięcy zaczynało się coś lepszego w formacie 16:10. Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 15, 2012 Report post Posted July 15, 2012 (edited) Jako sprzęt uniwersalny, IPS to nie jest dobre wyjście. Chyba że lubi Pan nierówne podświetlenie, plamy, świecące narożniki i wszystko co ciemne. O niebo bardziej uniwersalne są monitory z PVA. Do ok 1600 zł ma Pan do wyboru EIZO FS2331 (tyle że 16x9) i NEC P221W (16x10). Edited July 15, 2012 by Tom01 Quote Share this post Link to post Share on other sites More sharing options...
OCM4n14k Posted July 15, 2012 Report post Posted July 15, 2012 (edited) EIZO może i byłby dobry, ale brakuje mu rozdzielczości w pionie. Potrzebuje monitora, który chociaż dorówna mojemu staremu CRT pod tym względem, dlatego wybrałem 16:10 (dokładniej chodzi mi o rozdzielczość 1920x1200). Moja obecna rozdzielczość to 1800x1440 i szczerze mówiąc bardzo się przyzwyczaiłem do tak dużego pionu. Ewentualnie moge wydać te 2000zł jeśli w tej cenie znalazłbym coś lepszego. IPS dlatego, że siedząc kilkanaście lat na CRT jestem przyzwyczajony do szerokich kątów i monitory LCD, na których przyszło mi pracować niesamowicie mnie irytują pod tym względem. Ewentualnie może być coś na PVA jeśli kąty nie będą takie tragiczne. Jakby trafił się jeszcze monitor z funkcją PIVOT to byłbym zadowolony, przydaje się w niektórych przypadkach . Edited July 15, 2012 by OCM4n14k Quote Share this post Link to post Share on other sites More sharing options...
Tom01 Posted July 15, 2012 Report post Posted July 15, 2012 (edited) Kąty kątom nie równe. Jeśli na warsztatach stawiam kilku ludzi przez dwoma identycznymi monitorami PVA i IPS wszyscy pokazują na PVA jako ten z lepszymi kątami. Dlatego że nie maleje tak bardzo kontrast pod kątem. NA IPS pod kątem nie zmienia się tylko gamma, a to nieistotne w zastosowaniach uniwersalnych. Ogólnie LCD to nie kineskop ani plazma, i zawsze pod kątem jest różnica. Kwestia aby nie przeszkadzały. 1920x1200 w cenie nieco przekraczającej 2 tys zł to EIZO S2243W. Nic lepszego nie ma. Edited July 15, 2012 by Tom01 Quote Share this post Link to post Share on other sites More sharing options...
PeterMac Posted July 16, 2012 Report post Posted July 16, 2012 (edited) He, he... pytanie i odpowiedź w stylu: - Panowie, szybkie pytanie. Jaki pojazd z dieslem do x kwoty. - Chyba koparka albo działo samobieżne. Aby cokolwiek doradzić, lepiej dopytać po to co, do czego ma służyć, w jakich warunkach ma pracować? Jako sprzęt uniwersalny, IPS to nie jest dobre wyjście. Chyba że lubi Pan nierówne podświetlenie, plamy, świecące narożniki i wszystko co ciemne. O niebo bardziej uniwersalne są monitory z PVA. Do ok 1600 zł ma Pan do wyboru EIZO FS2331 (tyle że 16x9) i NEC P221W (16x10). Szybkie pytanie szybka odpowiedz, pytanie dotyczyło konkretnych sprecyzowanych już wymogów cena do 1600zł, 16:10, IPS. Oba modele które wymieniłem spełniają wszystkie kryteria. Nie istnieje tylko Eizo nie przesadzajmy choć jest top class wiadomo jesli chodzi o jakość obrazu, ale poza tym 22'' w NEC P221W i 1920x1200 to dla mnie zbyt mały ekran do takiej rozdzielczości i cena ponad 2300 za Eizo S2243W na dodatek brak HDMI w obu modelach. (NEC P221W jedno wejście cyfrowe sygnałowe DVI - kpina, przepraszam jest jeszcze analogowy d-sub ) Znowu 16:9 tez niezbyt mi sie widzi jak na monitor, choć nie ukrywam gdyby nie te 16:9 to FS2331 juz by stał u mnie na biurku. Btw. ktoś mi powie czy to Eizo nie przesadza, mają fajny model w atrakcyjnej cenie ok 1350zł za tego wlasnie FS2331 na SPVA tyle ze te nieszczęsne 16:9, z kolei model FX2431 z tej samej serii Foris tyle ze juz 24'' 16:10 i trochę bogatszy w ilość wejść (podobnie jak w Dell'ach, HDMI, DP, Component itp) to juz koszt ponad 4500zł, pytam się za co ? i skąd taka ogromna różnica w cenie, nie powie mi ktoś ze koszt wyprodukowania matrycy 23'' a 24'' to takie różnice, po za tym siedzą tam matryce Samsunga te same co w takim np.Dell'u 2408WFP. Z kolei mój faworyt jak do tej pory Eizo S2433W wszystko pięknie ale z powodu braku HDMI skreśliłem go z listy zakupów definitywnie, nie mam zamiaru bawić sie w aktywne przejściówki HDMI > DisplayPort kosztujące ponad 300zł jesli bym chciał podpiąć np. konsole, tunersat itp. urządzenia, samym kompem sie nie żyje mając taki monitor tym bardziej ze jest to monitor stricte uniwersalny nie czysto dla grafików. Niech sie Eizo opamięta i wyda nowszą rewizje tego modelu z przynajmniej jednym wejściem HDMI, albo juz jak nie chcą płacić za licencje to niech dadzą tam 2x DVI, muszę do nich napisać Zmiana karty graficznej tez nie wchodzi w gre, obecnie GTX570 i nawet jakbym zmieniał na nowszą nvidie coś pokroju GTX'a 670 które tez nie posiadają DP, Radeonów nie chce. Edited July 17, 2012 by PeterMac Quote Share this post Link to post Share on other sites More sharing options...
radiergummi Posted July 17, 2012 Report post Posted July 17, 2012 Japońska recka myślę wyczekiwanego przez wielu gejmingowego monitora EIZO FS2333 http://translate.google.pl/translate?sl=auto&tl=en&js=n&prev=_t&hl=pl&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fbbs.kakaku.com%2Fbbs%2FK0000391085%2FSortID%3D14800817%2F Coś tam da się wyczytać po przepuszczeniu przez tłumacza :) Cena podana w przeliczeniu to nieco ponad 1,5K przy czym nie wiem jak to wygląda u nich z podatkami na taki sprzęt. Pewnie u nas będzie w granicach 2k co powinno być do przełknięcia dla kogoś poszukującego dobrego monitora...pod warunkiem, że ten Eizo takim w praktyce się okaże. Quote Share this post Link to post Share on other sites More sharing options...
