cavarr
Xbox 360
Myliles sie :) Ja gram na orginalach tylko dlatego ze zbanowali mi juz 1 konsole i boje sie awarii. Jak na zlosc awaryjnosc konsol wychodzi microsoftowi na dobre :D
o boze.. o boze.. oh OH
v
Edytowane przez umcacz
Info
[2007-11-21 06:17:51] <c4eva> new live log uploaded to http://www.xbins.org/xblive no indication of any new checks , all same as before
[2007-11-21 06:20:23] <c4eva> it is pointing to backups that are not the same as retail
[2007-11-21 06:23:39] <c4eva> fw is doing its job, it cant check everything or know if the game has bad/different data
[2007-11-21 06:24:57] <c4eva> anything that has different pfi/dmi data but still valid would be suspect
[2007-11-21 06:26:14] <c4eva> these scene releases need to be validated against a known retail copy
[2007-11-21 06:28:20] <c4eva> fw is not been detected, it is the discs, as before
[2007-11-21 06:31:31] <c4eva> game can be stealthed , but have slight data change somewhere, especially DMI, or early copies may be marked, hence check against know retail copy
Więc chłopaki jak robicie kopie swoich oryginalnych gier to róbcie to dobrze :D
Dołączona grafika
Replace Keyvault Unbans Xbox 360 *update* :gitarzysta: :blurp:
>> Legueux of gx-mod.com informed us that Zouzzz managed to unban his Xbox 360 console from LIVE on their forums by swapping the keyvault of his banned Xbox360 with the keyvault of another (not banned) Xbox 360.
However it's not something that everyone out there can do (yet) as you'll need your CPU key (via Hypervisor Exploit and if you got banned it means you're on the latest kernel so you'll need to perform the 'Timing Attack' to downgrade first). You'll also need all the tools to read/flash your Xbox 360 NAND (with the Infectus chip for example).
Here are the things he tried:
* downgrade banned 5787 PAL to 4532 NTSC U, updated again to 5787 via HD. Still banned.
* downgrade banned 5787 PAL to 1888 PAL, updated again to 5787 via HD. Still banned.
* Patched his original 1888 PAL dump with the last number of the Xbox 360 serial in the keyvault (location A0 to AB) changed. Still banned.
* Patched his original 1888 PAL dump with the all the numbers of the Xbox 360 serial in the keyvault changed. Still banned.
* Replaced the full keyvault in his original 1888 PAL dump of the banned console with a keyvault of an unbanned console. Connected to LIVE OK, updated to latest kernel online OK, still connects fine to LIVE.
*update* Zouzzz posted a video showing his banned console and how it'll connect fine to LIVE again after he flashes the console with his 1888 dump with patched keyvault of an unbanned console.
http://video.google.fr/videoplay?docid=-40...48249&hl=fr
Panowie jest szansa dla utraconych dusz :D
Edytowane przez cavarr
Ja nie moge....
Chyba zrezygnuje z kupna drugiego pada ;p
Konsola premium -1200zl + adapter 230zl + live gold 12 (150zl) = 1580zl ... I do tego jeszcze gre dokupic (rise of a ninja 200zl :P + pgr 4 100zl) ~~1900zl :(
Mam pytanko czemu nie che dzialac mi net w xbox 360?? Mam podlaczony kabel ethernat do kompa ale caly czas podczas testu polaczenia nie wykrywa mi Adresu IP a jak wykryje to net dziala ale przez jakies 10 minut.
Od ofert sprzedaży jest dział Giełda / maSTHa212
Edytowane przez maSTHa212
No w zasadzie tak, bo adapter z ang. oznacza adapter/przejściówkę,
natomiast adaptor to kontroler/karta, więc w tym wypadku bardziej pasuje adaptor :) .
Wracając do tematu to ostatnio widziałem je na allegro po 210zł, chyba nawet od tego samego sprzedającego...
A zdjęcie raczej oryginału :)
