cavarr
Geforce 8800GT 256/512MB
Wiem, wiem.
Gigabyte zawsze może napisać, by wprowadzić korekte. Jak narazie tylko ASUS się zatroszczył. ;]
Ale faktycznie nie ma co głupot wypisywać, w oparciu o PcLola.
Gigabyte nie przewiduje żadnej podkręconej wersji?
Edytowane przez Pussik
Pojawiła się dziś Riva Tuner 2.06 Final LINK
Version 2.06:
Minor bugfixes:
* Fixed DDR2 videomemory detection for G84/G86 graphics processors.
* Minor UI and localization fixes.
What's new:
* Added ForceWare 167.xx and 169.xx drivers families support. Please take a note that 2D/3D performance levels switching is broken in currently broken in these drivers, so adjusting 2D performance level settings (e.g. 2D clocks) via RivaTuner will also change 3D performance level settings and vice versa.
* Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 163.74, 163.75, 163.76, 167.26, 169.01, 169.02 and 169.04.
* Added Catalyst 7.10 drivers detection.
* Updated Catalyst 7.10 certified SoftR9x00 patch script (for Windows 2000/XP drivers only).
* Added ATI RV670 graphics processors family support. Now RivaTuner's low-level features including overclocking, monitoring, diagnostics and fan control are available on ATI RADEON HD 38x0 family. Thanks to Anthony Tam @ HIS for providing ATI RADEON HD 3850 sample for testing.
* Added experimental support for the rest upcoming 55nm ATI RV6xx graphics processors families.
* Improved RV610/RV630 graphics processors families support. The improvements cover wide range of hardware overclocking, diagnostics, fan control and monitoring features.
* Added NVIDIA G92 graphics processors family support. Now RivaTuner's driver-level tuning and low-level features including overclocking, monitoring, diagnostics and fan control are available on NVIDIA 8800GT and other upcoming G92 based NVIDIA products.
* Improved driver-level fan control tab for NVIDIA display adapters:
o Added driver-level fan control tab for NVIDIA Vista drivers. Now RivaTuner is able to control fan on midrange NVIDIA display adapters with integrated fan controller under Vista via the ForceWare's NVAPI interfaces. Please take a note that unlike Windows XP fan control interfaces Vista's NVAPI fan control interfaces do not support independent 2D/3D fan speed adjustment and allow you to use either automatic or direct fixed fan control only. By default NVAPI fan control interfaces are used under Vista or under 167.xx and newer drivers only, however Windows XP owners can also force RivaTuner to use Vista specific fan control interfaces with older driver versions if needed by setting NVAPIUsageBehaviour registry entry to 1. The forcing can be useful to get fan control working on some graphics processors families, having malfunctioning separate 2D/3D fan control implementation in Windows XP driver (e.g. GeForce 8600 family).
o Driver-level fan control tab is now hidden on display adapters supporting binary fan control only (i.e. able either to run fan at full speed or shut it down completely) to avoid confusing beginners. Power users may unlock binary fan control if necessary by setting AllowBinaryFanSpeedControl registry entry to 1.
* Improved low-level overclocking tab for ATI R6xx/RV6xx display adapters:
o Now RivaTuner supports overclocking on ATI RV6xx display adapters using DPM (Dynamic Power Management) clock frequency adjustment.
o Now RivaTuner restores default clocks on ATI R6xx/RV6xx by means of the driver's PowerPlay table reset if possible.
* Improved low-level fan control tab:
o Improved duty cycle generation accuracy for display adapters using LM63, LM64, F75363 and ADT7473 external I2C fan controllers.
o Added low-level fan control support for ATI RV6xx integrated fan controllers.
o Added low-level fan control support for NVIDIA NV3x and newer integrated fan controllers. Please take a note that low-level fan control tab for display adapters using integrated fan controller (e.g. GeForce 6600, 7800GT, 7900GT etc) is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly.
* Improved hardware monitoring module:
o Added ATI RV6xx DPM (Dynamic Power Management) technology support. Now RivaTuner is able to monitor dynamically changing RV6xx clock core and memory clock frequencies adjusted in real-time by DPM depending on the GPU usage.
o Added 'Reference fan duty cycle' graph for ATI RV6xx graphics processors families.
o Added 'Reference fan duty cycle' graph for NVIDIA G80 and newer graphics processors families. Please take a note that some G84 based display adapters use inverted PWM polarity fan control, which means that 'Reference fan duty cycle' displays inverted duty cycle on such display adapters as well as low-level fan control slider is inverted too. Inverted polarity issues can be resolved by adding such display adapters to internal fan controller database represented by [FANPWM] section of RivaTuner.cfg file. PWM polarity for such display adapters can be forcibly inverted by adding the entry identifying such display adapter to the database and specifying PWM controller ID with forced negative PWM polarity for it (84h).
o Heavily optimized low-level I2C bus access algorithms for NVIDIA G80 and newer graphics processors families. Now the bus is accessed via new dedicated I2C registers instead of traditional I2C CRTC ports. Dedicated I2C access drastically reduces CPU time consumed by each I2C transaction (up to 5x - 7x times faster on certain hardware configurations). The effect of the optimization is the most visible in conjunction with MMIO mode when any device connected to I2C bus (e.g. ADT7473 thermal / fan controller) is being frequently polled. Power users may activate the previously available I2C access mode for performance comparison by setting NVI2CAccessModeG8x registry entry to 0.
o Now hardware monitoring graph renderer flushes bitmap caches after each display mode change to help display driver to render the graphs in optimal way. By default flushing is performed within a period of time defined by PostDisplayChangeBitmapFlushPeriod registry entry, the period can be changed by redefining it or the flushing can be disabled completely by setting the period to 0.
* Improved diagnostic report module:
o Improved navigation via the list of diagnostic report categories. Now report preview window is positioned on desired category more accurately when double clicking it in the list of diagnostic report categories.
o Improved PowerPlay table flags decoding in 'ATI VGA BIOS information' diagnostic report category.
* Now RivaTuner also uses Vista specific NVAPI interfaces for driver-level thermal monitoring, overclocking and fan control under Windows XP for the ForceWare 167.xx and newer drivers. NVAPI usage can be either completely restricted by setting NVAPIUsageBehaviour registry entry to 0 or alternately NVAPI usage can be partially restricted just for some driver-level tasks with NVAPIThermalControl, NVAPIClockControl and NVAPIFanControl registry entries.
* Added MMIO protection fallback support. Now RivaTuner automatically disables MMIO protection, notifies the user and starts in unprotected mode if the protective system is unable to allocate required protected MMIO range aperture (e.g. due to fragmented or limited kernel address space).
* Added #opt tag support to driver files database parser to allow including optional driver files in the database. This token was exclusively added to provide detection of ATI's ramdomly named OpenGL ICD drivers.
* Now RivaTuner uses %RTFolder% macro name when saving a path to external resources (e.g. databases or hardware monitoring log files) stored in the application folder. Power users can disable this feature by setting AllowRelativePathsEncoding registry entry to 0.
* Minor UI changes and improvements.
w Komputroniku powiedzieli ze prawdopodobnie w drugim tygodniu br. miesiaca nie powinno byc problemu z dostepnoscia a ceny powinny spasc, tak sobie mysle ale to tylko domysly ze po 15 listopada za 900 zł kupie jakiegos gigabyte ale poczekam na Palita choc skoro na gigabyte mozna uzyskac te 750 MHz to czy rzeczywiscie to 3-fazowe zasilanie w Palicie poza zmniejszeniem temperatury i stabilnoscia zaowocuje lepszym tj. wyzszym OC, jakos nie wydaje mi sie, ale trzeba poczekac,
nic te 2 tygodnie jakos wyciekna przez palce szybko mam nadzieje,
Też to zauważyłem ze narazie GB świetnie sie krecą (3 testowane karty i każda powyżej 750 na gpu). Kurcze mogłem zamawiać ;p. A tak btw jak narazie cicho o innej wersji galaxy niż referent :? (Palit ogłosił ze bedzie sonic+). Teraz nie wiadomo na co czekać.
Ten GB ze standardowym OC nieźle wygladą tylko pewnie też nieźle kosztuje :|.
Mam zamiar zamówić 8800GT jak tylko pojawi sie w sklepach. Tyle że mam zasilacz chyba za słaby nigdzie nie piszą jaki powinien wystarczyć. Napiszcie czy nie bede miał problemów. Sprzet jak w sygnaturze a zasilacz Tagan 430W
Minimum 26A na lini 12V - zerknij na tabliczke znamionową ale powinien wystarczyć. Zależy też jaka reszta komp i czy coś po OC.
Ying Chi launched the first non-public version of HDMI 8800GT
Dołączona grafika
Dołączona grafika
Dołączona grafika
Ying Chi 8800 GT and NVIDIA using the same version of the core, memory isolated power supply design, the core of three-phase power supply using rare design, but with a more than solid Sanyo OSCON confined inductance and capacitance, as well as PWM IC. At the same time, card uses two external power auxiliary power supply to ensure the stability of graphics work. This design also makes cards for overclocking greater overclocking performance NVIDIA completely beyond the public version. Moreover, the frequency of the products manufactured in the former OC had already been at the core of the default / Shader / memory frequency is 630/1600/1800 MHz, than the version has improved.
Ludzie poczekajcie parę tygodni z zakupem, a nie zachowujecie się jak małpy :lol2: sklepiki takie jak gral tylko czekają na takich.
dokladnie najlepiej poczekac z 2 tygodnie jezeli sie bardzo nie spieszy i poczekac na ciekawsze wersje tych kart zawsze to wiekszy wybor sam mam x1950pro jak do tej pory starczal w rozdzielczosci 1650x1080 ale po odpaleniu demka crysisa jednak bede karte wymienial, tak szy siak poczekam jeszcze z 2tyg. i zobacze jaka bedzie sytuacja ;) puki co nie usmiech a mi sie wydawac ponad 1k za ta karte.
Edytowane przez Bosek
Ta karta wygląda przepięknie.
A przede wszystkim ta część która odpowiada za zasilanie... :wink:
Jestem troszkę mało obcykany jeśli chodzi o architekturę budowy faz zasilania więc pytam - w czym ma pomóc i w jakim stopniu odbije się
na właściwościach dla nas najważniejszych czyli OC. Wiem że im stabilniejsze napięcie tym lepsze jest oc ze względu na stałe nie zmienne napięcie. Ale czy w tym przypadku to nie będzie tylko marketing? Wszak jak na razie OC to coś koło 100 Hz na rdzeniu, może to być już maksymalna wartość... A te dodatkowe zasilanie to tylko zwyczajowy "pic na wodę"
Poprawcie mnie jeśli się mylę :rolleyes:
Odpowiedź na to pytanie uzyskamy po pierwszych testach. Stawiam na to, że karta nie przekroczy 750MHz na rdzeniu. Obecnie wiele modeli z wentylkiem na 100% osiąga 700-720MHz. Jestem ciekaw co potrafi Palit z tym żelastwem na plecach, z resztą OC samego rdzenia nie czyni automatycznie najwyższej wydajności. 1050MHz (2100) na memkach też by się przydało :wink:
Oj przydało by się, przydało
Wersja palita to jest ta na którą osobiście liczę. Ponoć jest tam zamontowane trójfazowe zasilanie a ten sporej wielkości radiatorek z wentylatorkiem napawa człowieka wielkimi nadziejami. Ale jedno mnie interesuje - wydajność tych "płytek położonych na pamiątkach (tak to ze zdjęć wygląda) mogą się okazać piętą Achillesową w odprowadzaniu ciepła.
Co do chłodzenia od "palita" to chyba nie jest tak najgorzej...??
Edytowane przez mato22
To , że różne firmy zastosowały trzy fazy w zasilaniu gpu nie oznacza mocniejszego układu zasilania. Mogli zastosować słabsze i o wiele tańsze oraz bardziej dostępne mosfety niż te , które zastosowała nvidia w refencyjnej karcie.
Edytowane przez sideband
Alez sytuacja popieprzona, niby ceny innych kart NV powinny spasc (kilka postow wyzej ktos mowil, ze 7900GS to max 200zl, 512MB 250zl) a tutaj pytam typa na allegro ile za 7900GS 256MB DDR3 Zalman 1,2ns a on, ze 400zl, hahaha, za tyle to ja w sklepie kupie. Wracajac do tematu to na allegro bardzo widac spadek cen 8800GTS 320MB co jest chyba pocieszajace.
Cena zależy od popytu. Kilka dni temu tego GSa (Zalman) za 420pln sprzedałem, a następnego ktoś inny za 460pln ...
W sklepie juz 7900GS raczej nie kupisz.. 250zł to moze bedzie kosztowal ale za pol roku...
Jest to nada karta porównywalna a nawet lepsza od 8600GT a tu cena nic sie nie zmieni wiec naglych obnizek nie ma co sie spodziewac.
8800GT wypełnił tylko luke pomiedzy 8600GTS a 8800GTS(nowym). Stary 8800GTS trafi na rynek wtórny a jego cena pewnie bedzie kształtowala sie w okolicach 8800GT.
PITer, w Gralu moze nie ale sa takze inne sklepy, no offence ;) Jest troche sklepow, ktore sprzedaja 7900GS za 400zl.
Sorki, że w temacie o 8800GT robię OT (w sumie połowa wątku to OT :wink: )
Pokaż mi takie sklepy które sprzedają 7900GS 1.2ns Zalman 540/1500 za 400 pln :)
Ciekawe czy to ten palit ze swoim chłodzeniem
http://www.ulubiony.pl/palit_xpertvision_g...hdt_177760.html
Kupowalem w tym sklepie miesiac temu Palita 8600GT Sonic+ i jesli ktos chce czekac dlugo na odbior to polecam :) JA czekalem niemal 12 dni aby odebrac swoja karte osobiscie ...
a wystarczy ruszyc głowa,jakby 7900GS był sprzedawany po 200zł :lol2: to 7300GT musiałby kosztowac ok 50zł a co zreszta kart z nizszej pólki,chyba musiałyby kosztowac 10zł :D , albo byc rozdawane za darmoche Edytowane przez naxt
