HeatheN Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Graj tak jak lubisz, jeśli ci się podoba. Brak pvp nie ma się co spuszczać. Na normalu przechodzisz grę solo, i każda postać daje radę. Wyżej solo nie ma sensu, a 90% sukcesu to gear. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
KHOT Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) Z wypowiedzi niebieskich: Multi-Player Hell and Inferno I can clear all of Hell by myself, easily, where as it takes 3-4x longer to kill most monsters when you're in a group of four players My guess would be that you're geared ok and doing decent damage, and the rest of your party is not. and their drops are much worse if you're in a game with other players. Drops don't change based on party size. RNG, man. RNG. Hell Mode Too Hard Go back to the end of Nightmare and farm items for a bit. You'll be surprised what some upgrades can help you do. It's not always going to be a linear progression. You will need to look around or craft some better gear to continue progressing. Also, of course, try out some new builds! You might find something that works a bit better. Nobody wants to farm the 2nd difficulty, nobody. That shouldnt even be an option. It's... the game. It's not just an option, it's the entire game. The entire game is killing demons over and over for small chances at item upgrades to make your character stronger. If you're not strong enough, guess what you should do? Under-Geared Players By players do you mean a few under-geared people trying to race to the end? Yes, if you're not spending time gearing up but instead trying to avoid fighting things, you're probably going to die a lot. Please enjoy. Mówiąc krótko: gear, gear, GEAR! Sprzęt w tej grze jest wszystkim, a polowanie na niego celem samej gry. Przy okazji patrzcie też na zaawansowane statystyki, a nie tylko na te trzy wyświetlone przy podglądzie przedmiotu, np. int odpowiada u barbarzyńcy za odporności, a te grają dużą rolę na wyższych poziomach trudności... Edytowane 21 Maja 2012 przez KHOT Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
HeatheN Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 90% gear 9% taktyka 1% luck... W przytoczonym przez ciebie tekście, idealnie podsumowano moje problemy z grą:) Jak dostawałem baty=>AH życie x2 , dmg x2 i już batów nie ma;) No i taktyka...kilkukrotnie nie zmieniłem skilli na bosa.... przez co nie miałem najmniejszych szans... Ta gra jest piękna, ciągle trzeba kombinować:D (lvl 45mam) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Aquarium Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Na amazon.co.uk się pojawiły po 35 funtów - darmowa wysyłka do Polski. Zamówiłem, zobaczymy. 2 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Dziobak Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Na amazon.co.uk się pojawiły po 35 funtów - darmowa wysyłka do Polski. Zamówiłem, zobaczymy. Ile może trwać taka przesyłka do Polski? Chodzi mi o realny czas, a nie to co oni podają... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
slavok Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Sekretny poziom w Diablo III odnaleziony - Whimsyshire! | PurePC.pl WTF ? :blink: Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Michaelius Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) 3-4 dni zazwyczaj. Jak zamowisz teraz to masz spokojnie z 90% szans na to , ze bedzie przed weekendem. Jak uzbrajac czarodziejke ? Coś z dużym dmg by walić mocniej ze skilli czy attack speed też ważny do nawalania zwykłym pociskiem ? Acha no i czy warto rozkladac niebieskie itemki na materialy juz na normalu ? Edytowane 21 Maja 2012 przez Michaelius Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
borsuczy_król Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Ile może trwać taka przesyłka do Polski? Chodzi mi o realny czas, a nie to co oni podają... Około tygodnia. Przykładowo, w poniedziałek niby wysłali mi Diablo 3 i dojdzie dzisiaj, na weekend się nie załapałem. Dokładnie Ci nikt nie powie, czasem będzie krócej, czasem dłużej niż tydzień. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
kelcior Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) Do jutra :lol: Mozesz rozwinac? Bo jesli pijesz do tego ze barbem na Inferno nie dam rady (az sie porzadnie nie ubiore) to Ameryki nie odkryles, bo kazda klasa ma przechlapane poza magiem ze zbugowanym buildem, wiec? Takze podsumowujac twoj argument jest inwalidą. Edytowane 21 Maja 2012 przez kelcior Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
c45per Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 o co kaman z tym bugiem? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Shadoweye Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 ...Mozesz rozwinac?... Chodziło mu chyba o fakt że tylko raz zginołeś :P od jutra to się zmieni :P [ja dopiero normala przechodzę wiec nic nie będę się wypowiadał w tej kwestii :D ] ale słyszałęm że cieżko zaczyna się robić od 3 aktu :P [zweryfikuje dziś pewnie :P , dopiero 3 akt zaczolem] Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
bender83 Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Szybkie pytanko: Gram sobie na GP Szamanem a.k.a. Witch Doctor i generalnie bardzo mi pasuje ta postać, jednakże mam pytanie - jak się sprawdza w dalszej grze? :) Ciapie nim ktoś ? Tak obserwując do nim ugrałem do 13 lvl wydaje mi się całkiem mocną postką, która ma chyba najbardziej pokręcone skille ze wszystkich. Jednakże solo to chyba niebardzo, co? :) Dużo INT i VIT i 3 akt na Nightmare przechodzę z uśmiechem na ustach ;). Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
dbq Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Chodziło mu chyba o fakt że tylko raz zginołeś :P od jutra to się zmieni :P [ja dopiero normala przechodzę wiec nic nie będę się wypowiadał w tej kwestii :D ] ale słyszałęm że cieżko zaczyna się robić od 3 aktu :P [zweryfikuje dziś pewnie :P , dopiero 3 akt zaczolem] 3 akt jest dosyć ciekawy, aczkolwiek wchodząc coraz głębiej do pierwszej wieży dochodzisz do jej serca, skąd przechodzisz do poziomu 1 drugiej wieży itd. mi się troszke to dłużyło już :P to chyba jedyny moment, w którym chwilowo nie chciało mi się po prostu. normalnie to sie oderwać nie można, dalej dalej dalej.. wciąga ;) no ale to już za mną, spotka mnie to dopiero na następnym poziomie trudności, więc chwilowo spokój ;) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
oliwer21 Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Dużo INT i VIT i 3 akt na Nightmare przechodzę z uśmiechem na ustach ;). Buildem miałeś się pochwalić :wink: W NM pieski poszły w odstawkę, goryl pozostał. Jednak przy spotkaniu kilku "niebieskich" mobków zaczyna mi brakować many... trzeba coś pokombinować z itemkami :rolleyes: Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
demon92 Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Przyłączam się do pytania o co chodzi z tym bugiem u Czarodzieja?? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
kkNd! Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) na górze jest gdzieś podlinkowany filmik jak na inferno leje butchera melee i regeneruje się szybciej niż traci życie... Edytowane 21 Maja 2012 przez kkNd! Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
grz3choo Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 A tutaj ten sam Butcher pada w 20 sek na inferno za sprawą DH : Solo Inferno butcher sub 20 seconds. - Demon Hunter: The Dreadlands - Diablo Discussion and Community Forums - DiabloFans.com Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
thuGG Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) Czy mi się wydaje, czy nie widziałem jeszcze fotki z zalegającymi kolekcjonerkami na półkach, obiecanej przez czullo? Edytowane 21 Maja 2012 przez thuGG Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Spisaczek Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 A ja zachwalam sobie AH, gdyż jeśli dobrze poszukamy to możemy dostać porządny przedmiot za śmieciową kasę. No i imo bardziej się opłaca sprzedawać na AH niż u handlarza z czym, że na kasę z AH trzeba czekać no i nie zawsze trafi się chodliwy towar :) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
BLANTMEN Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Tak, ale nie zawsze towar sprzeda się na AH ;-) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Dziobak Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Około tygodnia. Przykładowo, w poniedziałek niby wysłali mi Diablo 3 i dojdzie dzisiaj, na weekend się nie załapałem. Dokładnie Ci nikt nie powie, czasem będzie krócej, czasem dłużej niż tydzień. Heh, nie zdążyłem... już jest po 48 GBP. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
HeatheN Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Tak, ale nie zawsze towar sprzeda się na AH ;-) No i to jest qpa...gdy 10 itemów wystawię i potem 2 dni czekam...:D by je sprzedać normalnie u kowala... Można jakoś aukcje odwoływać? Wycofywać inaczej niż przez 5 min? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Spisaczek Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 No i to jest qpa...gdy 10 itemów wystawię i potem 2 dni czekam...:D by je sprzedać normalnie u kowala... Można jakoś aukcje odwoływać? Wycofywać inaczej niż przez 5 min? Możesz zawsze poprosić zaufanego kumpla, żeby wykupił i oddał Ci w grze, ale to ostateczność dlatego powinno się patrzyć co wystawia :) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
blasphemy Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 No i to jest qpa...gdy 10 itemów wystawię i potem 2 dni czekam...:D by je sprzedać normalnie u kowala... Można jakoś aukcje odwoływać? Wycofywać inaczej niż przez 5 min? Nie, to zabezpieczenie przed spamowaniem AH bezuzytecznymi (lub zbyt drogimi) śmieciami. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
KaszaWspraju Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) Nie przypominam sobie gorszego "softu" to ściągnięcia i instalacji gry, a to przecież legendarny blizzard. Darmowe gry mają lepsze oprogramowanie do tego celu. Tylko 26 godzin ściągania, rozpakowywania i kolejna godzinka na instalacje. :mur:. Po za tym granie z pingiem 1400 w ciągu dnia w europie, w tryb dla pojedynczego gracza ? Po tym koszmarze, gra się całkiem przyjemnie, ale tyle kasy za "cztery na cztery" razy to samo, tylko na innym poziomie trudności i innych itemkach, to ja dziękuję. Dziękuję użytkownikowi Bartolomius za GP. Edytowane 21 Maja 2012 przez KaszaWspraju 1 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Spisaczek Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Nie przypominam sobie gorszego "softu" to ściągnięcia i instalacji gry, a to przecież legendarny blizzard. Darmowe gry mają lepsze oprogramowanie do tego celu. Tylko 26 godzin ściągania, rozpakowywania i kolejna godzinka na instalacje. :mur:. EEE chyba przesadzasz :) Ja zapuściłem nowy instalator, pobierał grę i na bieżąco instalował. Mało tego po ściągnięciu/zainstalowaniu jakiś 40% mogłem już odpalić pierwszy akt i normalnie grać :) Całość trwała jakieś 6-7h może troszkę dłużej (a mam 2 megówkę ), zapuściłem na noc i włala :) BTW Można przecież też zainstalować z płyty jeśli ktoś posiada wersję box. IMO zarzuty są ostro na wyrost, bo tutaj moim zdaniem soft był wzorowy (no może po za tymi błędami przy instalacji w pierwszej wersji instalatora). Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
demon92 Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 Macie coś pecha, mi tam ładnie 250kb/s(full łącze) leciało i więcej, żadnych problemów nie miałem, raz tylko miałem problem z kumplem wbić przez pół godziny, a tak to bezproblemowo jak na razie. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
grzegrz Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 (edytowane) W downloaderze Blizza od razu zalecam wyłączenie połączenia peer-to-peer. Mi z ~400kb/s skoczyło do 1,9mb/s Edytowane 21 Maja 2012 przez grzegrz Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
costi Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 W downloaderze Blizza od razu zalecam wyłączenie połączenia peer-to-peer. Mi z ~400kb/s skoczyło do 1,9mb/s U mnie to samo - z peer-to-peer sie meczyl i meczyl, a jak tylko to wylaczylem, to zaczal ciagnac max lacza i w niecala godzine skonczyl. Wysyłane z mojego HTC Vision za pomocą Tapatalk 2 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
BLANTMEN Napisano 21 Maja 2012 Zgłoś Napisano 21 Maja 2012 No i to jest qpa...gdy 10 itemów wystawię i potem 2 dni czekam...:D by je sprzedać normalnie u kowala... Można jakoś aukcje odwoływać? Wycofywać inaczej niż przez 5 min? Wiesz. Zależy za ile i co wystawisz. Ja (nie znając rynku low lvl itemów) wyciągam średnio po 2500 za sztukę. U kowala i tak więcej nie dostanę :-P Jak się coś nie sprzeda to przerabiam je na surowce. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
