angie27
Aktualizacja Biosu Fujitsu Siemens Amilo pro
Witam,
Chciałam zaktualizowac BIOS na laptopie Fujitsu Siemens Amilo Pro na Winowsie XP. Ściagnęłam sterownik z Upgradem BIOSU ze strony http://ts.fujitsu.com/support/downloads.html. W instrkcji pisze:
Flash - BIOS - Flash - BIOS - AMILO Pro V7010
Tytuł:
BIOS DOS Flash (Disc-Image) - AMILO Pro V7010
Data:
28.12.2004
Wielkość:
1,25 MB
Wersja:
1.10
Producent:
Fujitsu Siemens Computers
Status:
Wydano dlaAMILO Pro V7010
Opis instalacji:
* BIOS Flash-update for Fujitsu Siemens *
* AMILO Pro V7010 *
* S26391-K149-V325, S26391-K149-V518 *
* S26391-K149-V519, S26391-K149-V330 *
After running PEF5V110.EXE the floppy disk should contain following files:
flash.bat
BF3C21.exe
readme.bat
readme.txt (this file)
To flash your BIOS boot in DOS-mode and run flash.bat from the floppy disk.
!! Connect AC adapter befor flashing !!
!! Be sure that the Battery is full loaded !!
current BIOS V1.10:
Solved Problems:
- In WinXP environment, sometimes KB and mouse have no response after resuming from S3.
- The system does not support 2x 1GB memory modules from Samsung.
Known errors, problems and restrictions:
- The master password for a HDD might not work after updating the BIOS. This problem was
seen very rarely. To avoid this, the PW should be cleared before flashing the new BIOS.
- The system hangs very sporadically in S4 (Hibernate) status.
- Some mice might work only after a reboot when a Y-cable is used at the port replicator.
- After pressing the power button it last about 10s until the BIOS POST screen appears.
- The [Quick boot] feature in BIOS setup has no influence on the boot time, as the
ATI chipset does the memory handling in a different way (compared e.g. to Intel chip sets).
- In some special cases the external monitor might not work properly. This is e.g. when both
monitors are set to primary monitor or during the boot period, if the user has enabled
[LCD and CRT] setting in the BIOS setup.
- Charging the battery to 100% is only possible when the capacity is below 90%.
- If a dial up connection via internal modem is established,
the insertion of a memory card could causes a blue screen.
Additional Information:
- Deskflash is not yet implemented.
- Disable the Hyperthreading feature in BIOS if system runs with OS WIN2k.
- LAN controller can only be disabled or enabled, there is no “Auto” function available.
- The BIOS is mandatory for Prescott EO stettping.
- The reboot of the system starts automatically after BIOS update.
Zrobiłam obraz iso płyty i dałam rozruch z BIOSU jednak laptop nie uruchamia płytki tylko startuje widnows, podobnie było jak nie robiłam obrazu płyty tylko wkopiowaąłm wszytskie pliki flash.bat
BF3C21.exe
readme.bat
readme.txt (this file) na cd i równiez nie uruchomiło najpierw cd tylko windows. Co mozna jeszcze zrobic? czy to musi byc jakis inny obraz? prosze o pomoc
Obraz płyty jest na 100% dobry. Mam na myśli plik "FTS_BIOSFlashISOCDImageAMILOPROV7010__1003400.ISO". Jeżeli w BIOSie jako pierwszy ustawisz napęd CD to płyta powinna się zbootować. Wtedy wystarczy wpisać
flash
Oczywiście płyta powinna być nagrana z obrazu ISO.
Edytowane przez kfgz
Nazwa pliku nie ma znaczenia, ale... nie możesz nagrać tego pliku na płytę, tylko wypalić z niego obraz. Instrukcja: Poradnik jak nagrać obraz płyty ISO na nośnik CD/DVD W twoim konkretnym przypadku po wypaleniu płyta powinna być czysta. W tym sensie, że nie będzie na niej żadnych plików i/lub katalogów. Oczywiście płyta będzie tylko z pozoru czysta.
