slitzer
Xeon W3520 - problem z OC
Jak narazie udało mi się uruchomić na tych ustawieniach 3.04GHz, do 4 jeszcze daleko :/
Druga sprawa sprawdziłem RAM i jednak mam:
1x 2GB F3-12800CL9-2GBRL
2x 2GB F3-12800CL9-2GBXL
Według strony producenta różnią się tylko wielkością radiatora, ale CPU-Z pokazuje, że jedna ma Max Bandwitch 667MHz (2GBRL) reszta (2GBXL) Max Bandwitch 800MHz. Błąd CPU-Z ?
Edytowane przez slitzer
Memory SPD
DIMM #	1
    	SMBus address	0x50
    	Memory type	DDR3
    	Module format	UDIMM
    	Manufacturer (ID)	G.Skill (7F7F7F7FCD0000000000)
    	Size	2048 MBytes
    	Max bandwidth	PC3-10700 (667 MHz)
    	Part number	F3-12800CL9-2GBRL
    	Number of banks	8
    	Nominal Voltage	1.50 Volts
    	EPP	no
    	XMP	yes
    	XMP revision	0.0
    	AMP	no
JEDEC timings table	CL-tRCD-tRP-tRAS-tRC @ frequency
    	JEDEC #1	6.0-6-6-17-23 @ 457 MHz
    	JEDEC #2	7.0-7-7-20-27 @ 533 MHz
    	JEDEC #3	8.0-8-8-22-31 @ 609 MHz
    	JEDEC #4	9.0-9-9-24-33 @ 666 MHz
XMP profile	XMP-1600
    	Specification	PC3-12800
    	Voltage level	1.500 Volts
    	Min Cycle time	1.250 ns (800 MHz)
    	Max CL	9.0
    	Min tRP	11.00 ns
    	Min tRCD	11.00 ns
    	Min tWR	15.00 ns
    	Min tRAS	30.00 ns
    	Min tRC	49.00 ns
    	Min tRFC	110.00 ns
    	Min tRTP	7.50 ns
    	Min tRRD	6.00 ns
    	Command Rate	2T
XMP timings table	CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
    	XMP #1	9.0-9-9-24-40-2T @ 800 MHz (1.500 Volts)
DIMM #	2
    	SMBus address	0x52
    	Memory type	DDR3
    	Module format	UDIMM
    	Size	2048 MBytes
    	Max bandwidth	PC3-12800H (800 MHz)
    	Part number	F3-12800CL9-2GBXL
    	Number of banks	8
    	EPP	no
    	XMP	yes
    	XMP revision	1.2
    	AMP	no
    	JEDEC #1	7.0-7-7-22-29 @ 622 MHz
    	JEDEC #2	8.0-8-8-25-33 @ 711 MHz
    	JEDEC #3	9.0-9-9-28-37 @ 800 MHz
    	Specification	PC3-12800H
    	Max CL	9.0
    	Min tRP	11.25 ns
    	Min tRCD	11.25 ns
    	Min tWR	12.50 ns
    	Min tRAS	30.00 ns
    	Min tRC	42.50 ns
    	Min tRFC	137.50 ns
    	Min tRTP	7.50 ns
    	Min tRRD	7.50 ns
    	Command Rate	1T
    	XMP #1	9.0-9-9-24-34-1T @ 800 MHz (1.500 Volts)
DIMM #	3
    	SMBus address	0x54
    	Memory type	DDR3
    	Module format	UDIMM
    	Size	2048 MBytes
    	Number of banks	8
    	EPP	no
    	XMP	yes
    	XMP revision	1.2
    	AMP	no
    	Max CL	9.0
    	Min tRP	11.25 ns
    	Min tRCD	11.25 ns
    	Min tWR	12.50 ns
    	Min tRAS	30.00 ns
    	Min tRC	42.50 ns
    	Min tRFC	137.50 ns
    	Min tRTP	7.50 ns
    	Min tRRD	7.50 ns
    	Command Rate	1T
Mam dwa dni wolne od pracy zobaczę jak będzie bez tej jednej kości.
