did3k Opublikowano 3 Stycznia 2016 Zgłoś Opublikowano 3 Stycznia 2016 ---- Minecraft Crash Report ----// Oh - I know what I did wrong!Time: 03.01.16 14:35Description: Initializing gameorg.lwjgl.LWJGLException: Pixel format not accelerated at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method) at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52) at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252) at org.lwjgl.opengl.Display.createWindow(Display.java:306) at org.lwjgl.opengl.Display.create(Display.java:848) at org.lwjgl.opengl.Display.create(Display.java:757) at org.lwjgl.opengl.Display.create(Display.java:739) at bsu.am(SourceFile:523) at bsu.aj(SourceFile:352) at bsu.a(SourceFile:299) at net.minecraft.client.main.Main.main(SourceFile:120)A detailed walkthrough of the error, its code path and all known details is as follows:----------------------------------------------------------------------------------------- Head --Stacktrace: at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method) at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52) at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252) at org.lwjgl.opengl.Display.createWindow(Display.java:306) at org.lwjgl.opengl.Display.create(Display.java:848) at org.lwjgl.opengl.Display.create(Display.java:757) at org.lwjgl.opengl.Display.create(Display.java:739) at bsu.am(SourceFile:523) at bsu.aj(SourceFile:352)-- Initialization --Details:Stacktrace: at bsu.a(SourceFile:299) at net.minecraft.client.main.Main.main(SourceFile:120)-- System Details --Details: Minecraft Version: 1.8 Operating System: Windows 10 (x86) version 10.0 Java Version: 1.8.0_66, Oracle Corporation Java VM Version: Java HotSpot Client VM (mixed mode), Oracle Corporation Memory: 31633272 bytes (30 MB) / 93233152 bytes (88 MB) up to 518979584 bytes (494 MB) JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0 Launched Version: 1.8 LWJGL: 2.9.1 OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread. GL Caps: Using VBOs: No Is Modded: Probably not. Jar signature remains and client brand is untouched. Type: Client (map_client.txt) Resource Packs: [] Current Language: ~~ERROR~~ NullPointerException: null Profiler Position: N/A (disabled) Po uruchomieniu launchera wyskakuje mi taki komunikat czy ktoś może mi pomóc? Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
reyden Opublikowano 3 Stycznia 2016 Zgłoś Opublikowano 3 Stycznia 2016 Jaki sprzęt - karta graficzna szczególnie . Z tego co wiem to MC dzała na kartach z obsługą OpenGL 2.1 i wyżej , jak masz kartę z obsługą starszego OpenGL to MC nie będzie działał . Ew. to problem z softem - OS , Javą lub sterownikami karty . Podaj dokładnie jaki masz system . Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
did3k Opublikowano 3 Stycznia 2016 Zgłoś Opublikowano 3 Stycznia 2016 (edytowane) Jaki sprzęt - karta graficzna szczególnie . Z tego co wiem to MC dzała na kartach z obsługą OpenGL 2.1 i wyżej , jak masz kartę z obsługą starszego OpenGL to MC nie będzie działał . Ew. to problem z softem - OS , Javą lub sterownikami karty . Podaj dokładnie jaki masz system . Windows 10 Home Edytowane 3 Stycznia 2016 przez did3k Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
reyden Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 Napisz jaki masz sprzęt , bez tego ani rusz . Najbardziej interesuje mnie jaką masz kartę graficzną . Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
did3k Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 (edytowane) Karta graficzna: Intel® HD Graphics Procesor: Intel Core M370 I3 2.4GHz Ram: 3GB Sterowniki do karty graficznej mam już zupdatowane na najnowsze pobrałem jave 8 i dalej nie działa :/ Niedawno minecraft mi jeszcze działał teraz już wyskakuje ten błąd. Edytowane 4 Stycznia 2016 przez did3k Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
reyden Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 (edytowane) A wcześniej jaki system miałeś ? Sterowniki pobrane przez M$ WU czy ze strony Intela ? Spróbuj też ze starszymi sterownikami do karty . Ew. oryginalny MC lub Java gryzą sie z Win 10 , z tego co widzę to dla W10 istnieje osobna wersja tej gry napisana w C++ . Edytowane 4 Stycznia 2016 przez reyden Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
did3k Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 (edytowane) A wcześniej jaki system miałeś ? Sterowniki pobrane przez M$ WU czy ze strony Intela ? Spróbuj też ze starszymi sterownikami do karty . Ew. oryginalny MC lub Java gryzą sie z Win 10 , z tego co widzę to dla W10 istnieje osobna wersja tej gry napisana w C++ . Wczesniej a dokladnie miesiac temu mialem win 7 ale zmienilem bo lagowalo mi mocno kompa. Sterowniki ze strony Intela. Probowalem juz z inna wersja sterownikow. Moglbys mi podeslac stronke z ta osobna wersja dla win10? Edytowane 4 Stycznia 2016 przez did3k Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
reyden Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 MC dla Win 10 powinien być w sklepie MS , jak masz oryginalnego MC to na stronie z kontem powineneś dostać klucz do wersji W10 , normalnie koszt tej wersji to jakieś 10 $ . Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
did3k Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 MC dla Win 10 powinien być w sklepie MS , jak masz oryginalnego MC to na stronie z kontem powineneś dostać klucz do wersji W10 , normalnie koszt tej wersji to jakieś 10 $ . A nie da sie go znalesc na necie w tej wersji? Bo niezbyt teraz mam kase :/ Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
reyden Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 Nie wiem , nie interesuję się MC , zresztą podanie linków do wersji legalnych inaczej podpada pod regulamin forum . Natomiast jak wcześniej miałeś oryginalnego MC to wersję dla Win 10 możesz zdobyć tutaj za free . Wymagana choćby podstawowa znajomość angielskiego i konto w M$ . Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
Klaus Opublikowano 4 Stycznia 2016 Zgłoś Opublikowano 4 Stycznia 2016 Temat uważam za wyczerpany. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
