kupaszmalu Opublikowano 8 Sierpnia 2022 Zgłoś Opublikowano 8 Sierpnia 2022 Gdy wypuścili Total Commander w wersji 10.50 to myślałem że zniknie błąd z zawieszaniem ale nadal jest. Naprawili jakieś pierdoły zamiast to co trzeba 07.07.22 Release Total Commander 10.50 final (silent update) 07.07.22 Fixed: Find files: Searching with "Everything" could find files in the base directory of the search but report them in a lower directory (32/64) 06.07.22 Release Total Commander 10.50 final 06.07.22 Fixed: Dark mode: Comboboxes in Commands-Search-Plugins not high enough for larger fonts (32) 05.07.22 Fixed: F2 in compare by content (edit mode): When using CompareF2Mode=1, searching for the next difference could get stuck at empty lines (32/64) 05.07.22 Fixed: Find files: Searching with "Everything" could fail in Windows 7 in a virtual machine (64) 04.07.22 Fixed: F2 in compare by content (edit mode): When using CompareF2Mode=2, don't jump to different line if current line doesn't contain any differences (32/64) 04.07.22 Fixed: Lister/Quick view panel: Viewing an image with the built-in viewer (no plugins) didn't always use the configured background color (32) 04.07.22 Fixed: Thumbnail view: Resource leak when displaying icons with a size of 256x256 pixels from some (e.g. .exe) files (32764) 03.07.22 Fixed: Compare by content: F2 didn't jump to zero length differences: positions where text was added to the other file (32/64) 03.07.22 Fixed: Thumbnails view: Reduce flickering when displaying freshly loaded icons and/or thumbnails (32/64) 30.06.22 Fixed: Find files: Searching for *|*\ didn't return the same results with and without "Everything" (32/64) 29.06.22 Fixed: Switching from normal to dark mode or starting the program directly in dark mode lost the menu translation (64) Gdy w Total Commanderze bezpośrednio na jakiejś partycji albo pendriwie obojętnie kliknie się prawym przyciskiem na białe pole żeby rozwinąć menu kontekstowe to wtedy się zawiesi Total Commander. Żeby się nie zaciął to trzeba najechać na jakiś folder albo plik i wtedy rozwinąć menu kontekstowe albo w jakimś folderze rozwinąć menu kontekstowe prawym przyciskiem myszy. Dotyczy to 32 i 64 bitowej wersji Total Commandera. Napiszcie do producentów Total Commandera o naprawienie tego błędu. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
Zeniu Opublikowano 8 Sierpnia 2022 Zgłoś Opublikowano 8 Sierpnia 2022 u mnie działa Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
masin Opublikowano 9 Sierpnia 2022 Zgłoś Opublikowano 9 Sierpnia 2022 też nie mam z tym problemu Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
