lukasz85ha Opublikowano Poniedziałek o 11:17 Zgłoś Opublikowano Poniedziałek o 11:17 (edytowane) Witam chcialbym sie doradzic w rozbudowie komputera a zwlaszcza chodzi o procesor jaki by pasowal do tego pc CPU Intel Core i3 4170 @ 3.70GHz 33 °C Haswell 22nm Technology RAM 8,00GB Single-Channel DDR3 @ 798MHz (11-11-11-28) Motherboard LENOVO SHARKBAY (SOCKET 0) 28 °C Graphics PHL 223V5 (1920x1080@60Hz) 2047MB NVIDIA GeForce GT 730 (Unknown) 32 °C Storage 931GB Seagate ST1000DX001-SSHD-8GB (SATA ) 30 °C Optical Drives PLDS DVD-RW DH16AFSH Audio Realtek High Definition Audio --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Intel Core i3 4170 Cores 2 Threads 4 Name Intel Core i3 4170 Code Name Haswell Package Socket 1150 LGA Technology 22nm Specification Intel Core i3-4170 CPU @ 3.70GHz Family 6 Extended Family 6 Model C Extended Model 3C Stepping 3 Revision C0 Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, VMX, AES, AVX, AVX2, FMA3 Virtualization Supported, Enabled Hyperthreading Supported, Enabled Fan Speed 587 RPM Bus Speed 99.8 MHz Stock Core Speed 3700 MHz Stock Bus Speed 100 MHz Average Temperature 33 °C Caches L1 Data Cache Size 2 x 32 KBytes L1 Instructions Cache Size 2 x 32 KBytes L2 Unified Cache Size 2 x 256 KBytes L3 Unified Cache Size 3072 KBytes Cores --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Motherboard Manufacturer LENOVO Model SHARKBAY (SOCKET 0) Version SDK0J40700 WIN Chipset Vendor Intel Chipset Model Haswell Chipset Revision 06 Southbridge Vendor Intel Southbridge Model H81 Southbridge Revision C2 System Temperature 28 °C BIOS Brand LENOVO Version IEKT33AUS Date 08.06.2015 Voltage CPU CORE 2.960 V MEMORY CONTROLLER 2.960 V +3.3V 2.720 V +5V 4.570 V -5V -10.368 V +5V HIGH THRESHOLD 3.736 V CMOS BATTERY 2.128 V PCI Data Slot PCI-E Slot Type PCI-E Slot Usage In Use Data lanes x16 Slot Designation J6B2 Characteristics 3.3V, Shared, PME Slot Number 0 Slot PCI-E Slot Type PCI-E Slot Usage In Use Data lanes x1 Slot Designation J6B1 Characteristics 3.3V, Shared, PME Slot Number 1 Slot PCI-E Slot Type PCI-E Slot Usage In Use Data lanes x1 Slot Designation J6D1 Characteristics 3.3V, Shared, PME Slot Number 2 Slot PCI-E Slot Type PCI-E Slot Usage In Use Data lanes x1 Slot Designation J7B1 Characteristics 3.3V, Shared, PME Slot Number 3 Slot PCI-E Slot Type PCI-E Slot Usage In Use Data lanes x1 Slot Designation J8B4 Characteristics 3.3V, Shared, PME Slot Number 4 --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Graphics Monitor Name PHL 223V5 on NVIDIA GeForce GT 730 Current Resolution 1920x1080 pixels Work Resolution 1920x1040 pixels State Enabled, Primary Monitor Width 1920 Monitor Height 1080 Monitor BPP 32 bits per pixel Monitor Frequency 60 Hz Device \\.\DISPLAY1\Monitor0 NVIDIA GeForce GT 730 Manufacturer NVIDIA Model GeForce GT 730 Device ID 10DE-1287 Revision A2 Subvendor Unknown (1642) Current Performance Level Level 0 Current GPU Clock 135 MHz Current Memory Clock 405 MHz Current Shader Clock 405 MHz Voltage 1.025 V Technology 28 nm Bus Interface PCI Express x8 Temperature 31 °C Driver version 30.0.14.7514 BIOS Version 80.28.92.00.1b Physical Memory 2047 MB Virtual Memory 2048 MB Count of performance levels : 3 Level 1 - "Perf Level 0" GPU Clock 135 MHz Shader Clock 405 MHz Level 2 - "Base" GPU Clock 901 MHz Shader Clock 900 MHz Level 3 - "Boost" GPU Clock 901 MHz Shader Clock 900 MHz z Gory dziekuje za pomoc Edytowane 20 godzin temu przez lukasz85ha Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
Kyle Opublikowano Poniedziałek o 12:39 Zgłoś Opublikowano Poniedziałek o 12:39 Najpierw się zorientuj, czy tam jest miejsce na lepsze chłodzenie i czy są standardowe otwory montażowe pod typowe chłodzenia. Dopiero wówczas można myśleć nad wsadzeniem lepszego CPU. Dołożenie drugiej kostki 8GB też wypadało by zrobić. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
Gerg7 Opublikowano Poniedziałek o 14:29 Zgłoś Opublikowano Poniedziałek o 14:29 (edytowane) Najlepiej to wypadałoby wymienić całe to PC . https://www.olx.pl/d/oferta/komputer-do-gier-ryzen-5-2600-radeon-rx570-8gb-CID99-ID1aoe0I.html?search_reason=search|organic Edytowane Poniedziałek o 15:10 przez Gerg7 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
