epikur
GeForce 4 MX 440 with AGP8x : )
Całą karta (bodajze na DDR) czyli WSZYSTKO Z NIA GRA ??
NVIDIA GeForce4 MX 440 with AGP8X Driver 4.5.2.3
Description NVIDIA GeForce4 MX 440 with AGP8X
Manufacturer NVIDIA
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 64 MB
Driver File nv4_disp.dll
Driver Version 4.5.2.3
Driver Date 7-28-2003
Driver WHQL Certified true
Max Texture Width 2048 px
Max Texture Height 2048 px
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 2
Vertex Shader Version 1.1
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 265.5 MHz
VGA Core Clock 249.8 MHz
PCI
Name NVIDIA GeForce4 MX 440 with AGP8X
Vendor ID 0x10de
Device ID 0x0181
SubSystem ID 0x00000000
Revision ID 0xa2
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Point Primitive Support, DXT Compressed Textures, Mipmapped Cube Textures, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0b
Long Version 4.09.00.0902
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
AC3Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
AVI_PASS
BDA MPEG2 Transport Information Filter
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Default DirectSound Device
Default MidiOut Device
DivX Decoder Filter
DivXAntiFreeze
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Fraunhofer Video Decoder
IVF source filter
Indeo audio software
Indeo video 4.4 Decompression Filter
Indeo video 5.10 Decompression Filter
Internal Script Command Renderer
Ligos MPEG Splitter
Ligos MPEG Video Decoder
Line 21 Decoder
Line 21 Decoder 2
Lyric Parser
MIDI Parser
MJPEG Decompressor
MJPEG Decompressor AL/BS
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Ogg Multiplexer
Ogg Splitter
Overlay Mixer2
Pinnacle Colorspace Converter
Pinnacle MPADecoder
Pinnacle MPEG Video Decoder
Pinnacle MPEG Video Decoder (DWSource)
Pinnacle PushPull (Async.)
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
Vorbis Decoder
WM ASF Reader
WM ASF Writer
WMplug
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Pad VU Data Grabber
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XLDecompress
XML Playlist
Xing VideoCD Navigator
XviD MPEG-4 Video Decoder
AGP jes tpo to, żeby był pretekst do wypuszczenia zmienionej wersji. dali lepsze taktowanie GPU i sporo lepsze pamięci. MX440 miał 270/400 a tu jest 275/513 do daje na prawdę sporą różnicę bo można podkręcić do 650 MHz pamięci i rdzeń np. do 325 i jest synchro :) fajna karta, cena bardzo niska, wydajność FX5200 a czasem wyższa tylko że DX niższy.
wiec jakie 513??
jak to mozna sprawdzic??
wytłumaczę jak dziecku bo widzę że nikt się nie domyśli najbardziej oczywistej rzeczy pod słońcem.
memmory clock 265.5, a jako, że to DDR (double data rate) to 2*265.5 to daje 533 MHz czyli nawet lepiej niż 513, któro jest w specyfikacji nVidii dla MX440 z AGPx8.
tylk odziwi mnie ten zegar GPU : 250 to było w MX440SE AGPx4, w/g nVidii mx440 zgp x8 powinny mieć 275 MHz.
wielkie dzieki . a ? ide da sie z niej wycisnac ? by była agresywna do bólu ? wielkie dzieki . a ? ide da sie z niej wycisnac ? by była agresywna do bólu ?
Tzn. co ? Ile z niej wyciagniesz? Jesli tak to sam musisz sprawdzic , niestety nikt Ci tego nie powie.
