ppawlo Opublikowano 5 Grudnia 2003 Zgłoś Opublikowano 5 Grudnia 2003 Problem z shaperdem!! Gdzie mogę znaleźć dokładny opis jego wszystkich opcji ?? Bo mam taki problem. Mam internet 100Mbitowy i diwe karty w linuxie. Normalne transfery na karcie wewnętrznej to 5000kbitów. Jeżeli uruchomię shaperda - to transfer spada do 100kb. (mierzę to programem iptraf). Dlaczego tak moze być - przyznam się , że plik kofiguracyjny robiłem na szybko, ale może mi pomożecie?? Oto mój konfig ------------------------------------------------------------------------------ # timeout of tcp connection on masquerade # for kernel 2.2.x (in seconds) # default: # timeout_ipchains_22=3600 # for kernel 2.4.x and ipchains (in minutes) # default: # timeout_ipchains_24=7200 # for kernel 2.4.x and iptables (in seconds) # default: # timeout_iptables_24=432000 # older connection on masquerade will be ignored (in seconds) # default: # timeout_global=300 # experimental - yes - turn on alternative nat tracking connection. # Work only with nomasq=no # default: # alt_natstat=yes # if yes - new user will get as high speed as possible # default: # high_start_speed=yes # if yes - don't recreate speed allocation every cycle but only change it # default: # continuous_control=yes # if yes - turn on even division # default: # even_division=no # measure total of assigned bandwidth # default: # check_sum_of_bandwidth=yes # in percent of total bandwidth speed # default: # check_download_factor=50 # check_upload_factor=50 check_download_factor=30 check_upload_factor=30 # on how many cycles shaperd have control if real speed is great than assigned # 0 - on every cycle # don't use 0 for CBQ classes! # default: # check_download_factor_cnt=5 # check_upload_factor_cnt=5 check_download_factor_cnt=10 check_upload_factor_cnt=10 # (EXPERIMENTAL) if some class crash and will do not control bandwidth then # shaperd will remove it when check_(down/up)load_factor_cnt=0 # and create again in next cycle. # default: # remove_dead_class=no remove_dead_class=yes # no - will turn off "Can't control bandwidth ..." message # default: # control_mesg=yes # if yes - shaperd will cooperate with TOS patched squid # default: # squid_support=no squid_support=yes # squid port # default: squid_port=8080 #squid_port=8192 # if yes - divide upload traffic # default: # divide_upload=no divide_upload=yes # yes - turning on TOS mangling for every user # default: # extended_queue=no extended_queue=yes # for iptables and large ip_conntrack table or slow servers with a lot of # users set it to yes # default: # nomasq=yes # type of download limiting class # default: # class_type=cbq class_type=htb # type of upload limiting class # default: # upload_class_type=cbq upload_class_type=htb # for HTB only - in percent of assigned bandwidth # default: # ceil_download=0 # ceil_upload=0 ceil_download=50 ceil_upload=50 # for HTB only - in KB # default: # burst_download=100 # burst_upload=100 ceil_download=240 ceil_upload=60 # extension of speed # default: #speed_ext=bit speed_ext=Kbit # speed increasing multipler # default: # jump_type=0 jump_type=5 # if allocation is used less than this percentage factor - shaperd will # decrease allocation # default: # nop_factor=50 nop_factor=60 # if allocation is used more than this percentage factor - shaperd will # increase allocation # default: # add_factor=75 add_factor=80 debug=0 # default: # debug_output=/dev/null #debug_output=/tmp/shaperd.debug # delay between cycles # default: # delay=10 # no - turn off info messages in log if delay is change # default: # delay_mesq=yes delay_mesg=no # no - turn off "Can't find mask for IP" message # default: # mask_mesg=yes mask_mesg=yes # default: # write_delay=0 write_delay=1 # interface definitions inter_int=eth0;8;102400;2;0;auto;1 local_int=eth1;102400;192.168.62.0/24;192.168.62.0/24;2 mainip=10.150.1.1 internet_iface=eth0 high_start_speed=1 even_division=0 #1 - ustawia dla wszystkich rowny transfer check_always=1 ------------------------------------------------- Dzięki za wszystkie rady!! Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
Bonk Opublikowano 6 Grudnia 2003 Zgłoś Opublikowano 6 Grudnia 2003 Czemu shaperd a nie po prostu HTB ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
ppawlo Opublikowano 8 Grudnia 2003 Zgłoś Opublikowano 8 Grudnia 2003 Czemu shaperd a nie po prostu HTB ? z skąd to pobiorę?? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
Bonk Opublikowano 8 Grudnia 2003 Zgłoś Opublikowano 8 Grudnia 2003 Poczytaj o skrypcie Prisma www.rc-htb.prv.pl a o reszte info odsylam Cie do ... www.google.pl :D Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
