(D)jur(on)
Fault outside of MS-DOS Extender!!!POMOCY!!!
No dobra, ale leń z ciebie straszny...
oto prawdopodobne przyczyny tego błędu:
HIMEM.SYS is unable to control the A20 line.
DOS=HIGH is not functioning properly (related to HIMEM.SYS control).
The RAM, static RAM (SRAM), single in-line memory module (SIMM), or dynamic RAM (DRAM) chips are not functioning properly.
You are running DR DOS.
The third-party memory manager is not configured correctly.
The EMM386.EXE NOEMS x=A000-EFFF line is missing from the Config.sys file.
You have an old, out-of-date ROM BIOS.
Your CMOS settings are incorrect.
Your Windows files are old or corrupted. To test this, create a new directory on the hard drive, and install Windows in that directory.
Your disks are corrupted.
Your system is infected with the Form, Forms, Noint, or Yankee Doodle virus.
a pełny artykuł jest tu: http://support.microsoft.com/default.aspx?...kb;en-us;Q87239
Po coś w końcu JEST mICROSOFT kNOWLEDGE bASE....oops caps...
