RaKLeZ
Spis Pamięci Na Kościach Winbond-a Bh-5/-6
Spis pamięci, które były/są produkowane na kościach winbonda BH-5, BH-6 i CH-5.
Myśle, że się przyda :)
Corsair
XMS-PC2700LL Rev1.1 Winbond BH-6
XMS-PC2700LL Rev1.2 Winbond CH-6
XMS-PC3200C2 Rev1.1 Winbond BH-6
XMS-PC3200C2 Rev1.2 Winbond CH-5
XMS-PC3200LL Rev1.1 Winbond BH-5
XMS-PC3200LL Rev1.2 Winbond CH-5
XMS-3200LLPT (2-2-2-6-1T) Winbond BH-5
XMS/TwinX-PC3200LL Rev1.1 (DualPack) Winbond BH-5
XMS/TwinX-PC3200LL Rev1.2 (DualPack) Winbond CH-5
XMS-PC3500C2 Rev1.1 Winbond BH-5
Kingston
HyperX PC2700 (2-2-2-5-1T) (KHX 2700) Winbond BH-6, CH-5 and also Samsung
HyperX PC3000 (2-2-2-6-1T) (KHX 3000) Mainly Winbond BH-5, some BH-6 and also some CH-5
HyperX PC 3200 (old revision, not A or AK2) (KHX 3200) Winbond BH-5
HyperX PC 3200K2 (2-2-2-6-1T) (KHX 3200K2) Winbond BH-5
HyperX PC 3200AK2 (2-3-2-6-1T) (KHX 3200AK2) Winbond CH-5
HyperX PC 3500 (rated 2-3-3-7 @ 433Mhz, 2-2-2-6 @ 400Mhz, old revision) (KHX 3500) Winbond BH-5
HyperX PC 3500K2 (2-3-3-7) (KHX 3500K2) Winbond CH-5
Kingston Ram w/remarked Chips as D328DW-45 Winbond CH-5
Kingston Ram w/remarked Chips as D328DW-5 Winbond BH-5
Value Ram 333Mhz (2,5-3-3-*) (KVR333X64C25) may or may not contain Winbond BH-6, look at the chips
Value Ram 400Mhz (2,5-3-3-*) (KVR400X64C25) may or may not contain Winbond BH-5, look at the chips
Twinmos
Twinmos/Winbond DDR400 (2,5-3-3-6) Could be Winbond BH-5, CH-5, look at the chips
Twinmos 3200 512MB kostki m.tec lub twinmos to przemarkowane winbondy UTT (w nr p/n musi być końcówka AA4T)
Link do fotki:
CLICK
Mushkin
PC3200 Level I Winbond CH-5
PC3200 Level II Mainly Winbond BH-5 but also some BH-6
PC3200 Special 2-2-2 Winbond BH-6
PC3500 Level I Winbond CH-5
PC3500 Level II Winbond BH-5
OCZ
EL DDR PC3200 Platinium Limited Edition (2-2-2-7) Winbond BH-6
EL DDR PC3500 Platinium Limited Edition (2-2-3-6) Winbond BH-5
Buffalo
PC3700 may or may not contain Winbond BH-5, look at the chips
Ultra
Extreme Memory PC3200 DDR 400MHZ (2-2-2-5-1T) Winbond BH-5
A-Data
PC3200 Winbond CH-5
PC3200 Special Edition Winbond BH-5
Edytowane przez RaKLeZ
A ja mam HyperX PC2700 1 x 512 na winbondach CH :/
ok zrobie update w spisie...
BTW mozna jeszcze kupic BH-5 w sklepie
http://www.proline.pl/shop.php?prodid=4f43...94e5f3258323536
ale cena..........:|
Ehe - i od razu je sobie darujmy ... na NF7 (2 egzemplarze) max @ 6-2-2-2 to 220 !! Nowe BH-5 i qpa (nowe - ostatnie z linii produkcyjnej)
No to ja mam KVR333X64C25. Problem w tym, ze nie wiem co to za kosci :(. Mozecie pomoc mi je ogarnac?
Niestety jedyne zdjecie jakie mam jest takie:
Dołączona grafika
Niewiele widac, ale mam tez zapisane co tam jest - odpowiednio wierszami:
1) 0323 (pewnie data produkcji) 1-1
2) MT (takie logo - moze od MTEC?) 46V32MB
3) TG -6TC
Teraz chodza na 225Mhz 3-3-3-11 @2,9V i sa to najnizsze timingi i najwyzsze FSB jakie udalo mi sie uzyskac.
Thx za pomoc.
3)         TG                          -6TC
Micron 6ns
czy panmieci na kostkach ch-5 sa tak dobre jak bh-5
bo z opisu wynika ze nie
jesli tak to jaka roznica pamieci ch-5 miedzy "zwyklakami" a bh-5
CH-5 nie lubią samych dwójek idą np 6-3-2-2 a nie specjalnie 6-2-2-2 (w każdym razie różnica >>10MHz fsb)
Po drugie CH-5 na ciasnych timingach potrzebują >3,10V (przynajmniej u mnie tak było) ...
BH-5 latają 6-2-2-2 a Voltaż pomaga im osiągnąć wysokie częstotliwości ...
dzieki za info
tak sie zastanawialem zeby sobie kupic i akurat mnie napadlo w okresie ktorym pamieci sa bardzo drogie
moje kingston 256mb 400mhz cl3 chodza na 440mhz i 2,5-3-2-7
zastanawiam sie czy:
- lepiej dokupic zwykle kingston 256mb 400mhz :?:
- sprzedac swoja kostke, poszukac i kupic 512mb na bh-5 :?:
- sprzedac swoja i kupic zwykla kingston 512mb 400mhz :?: (czy jest roznica miedzy cl2,5 i cl3 bo mi sie wydaje ze roznia sie tylko naklejka nawet sprzedaja za ta sama cene)
oczywiscie nie przeznacze na ten cel wiecej niz 200zl (nie koniecznie nowe) wiec pewnie bedzie ciezko cos w miare dobrego za ta cenepo
za 470zl mam od reki kingston 2x256mb 400mhz na ch-5 (szkoda ze w dwuch kosciach)
pozdrawiam wszystkich
ale wydaje mi sie ze z jedna koscia byloby 2x mniej problemow niz z dwoma jesli mialyby sie jakiekolwiek pojawic :idea:
i chyba nie beda szly na tak dobrych timingach co jedna kosc
nie wiem ale przy dual-u az tak bardzo nie wzrasta wydajnosc
tzn. wobrazam sobie to tak ze wydajnosc bedzie podobna a wolalbym w jednej kosci (to tylko moj osobisty problem)
jesli nie jest tak jak pisze to czy wiedzialby ktos i mogl sie podzielic takimi informacjami ile wzroslaby wydajnosc pomiedzy tymi ukladami
za swoje bym dostal max 230zl i tu sie pojawia problem dlatego nie wiem czy je chce
aha i napiecie powyzej 2,9v dostepne po jakims modzie :?:
jesli pisze totalne bzdury to prosilbym o usuniecie tego posta bo czasami mam bujna wyobraznie :!:
Corsair
XMS-PC2700LL Winbond BH-6
A te :
Właściwości modułu pamięci
Nazwa modułu Corsair CMX256A-2700C2
Rozmiar modułu 256 MB (1 rows, 4 banks)
Typ modułu Unbuffered
Typ pamięci DDR SDRAM
Szybkość pamięci PC2700 (166 MHz)
Szerokość modułu 64 bit
Napięcie modułu SSTL 2.5
Szybkość odświeżania Zredukowana (7.8 us), Self-Refresh
Najwyższe opóźnienie CAS 2.5 (6.0 ns @ 166 MHz)
Następne najwyższe opóźnienie CAS 2.0 (6.0 ns @ 166 MHz)
Corsair
A te :
z tego co wiem sa 2 rewizje (1.1 i 1.3)....jedna jest prawdopodonie na CH-6, ale nie jestem pewny :? :) ....mozna zapytac na forum corsaira...
http://www.houseofhelp.com/forums/forumdis...php?forumid=128
powinni wiedziec :)
poprawka do XMS 2700LL rev.1.1 BH-6/rev.1.2 CH-6
Kingston
Dwa tygodnie temu miał koleś takie do sprzedania na Warszwskiej Giełdzie Komputerowej. 1 x 512MB, chciał 660zł, może ze dwie dychy taniej by poszły... Trochę drogo, nawet jak na BH-5, no ale przy ostatnich cenach, gdzie na komputroniku KHX3200A/512 CL2 kosztuje 703zł... :? Jak ktoś wierzy w cuda i ma kaskę, to niech na najbliższej giełdzie się przejdzie - a nuż się uchowały...
Kingston HyperX DDR 512MB PC-400 (KHX3200/512) CL2
model HyperX KHX3200/512, 184-pin, napięcie zasilania 2.5v, styki pokryte złotem, czas dostępu 5 ns, CL 2, 400 MHz Non-ECC; aluminiowy radiator rozpraszający ciepło    703,-
Kingston HyperX DDR 512MB PC-400 (KHX3200A/512) CL2
model HyperX KHX3200A/512, 184-pin, napięcie zasilania 2.5v, styki pokryte złotem, czas dostępu 5 ns, CL 2, 400 MHz Non-ECC; aluminiowy radiator rozpraszający ciepło    703,-
Czyżby jakieś pozostałości starych serii się trafiły, czy tylko "chłyt materkingowy" (Komputronik)?
Corsair
A te :
Reed >> Ty masz 2700C2, a to co innego niz 2700LL (w/g http://www.corsairmicro.com/corsair/xms.html ). Jesli chcesz sprawdzic czy to bh-5/bh-6 to po prostu max Vdimm magistralka ze 200-220 i probuj puscic je na 11-2-2-2, jak pojda to pewnie BH.
BTW: CH-5 tez nie sa do konca takie beznadziejne: http://www.xtremesystems.org/forums/showth...&threadid=34392 :D
Mushkin
To mówi samo za siebie. KHXy rev. "A" prędzej by z dymem poszły, niż coś takiego utrzymały...
No właśnie, też jestem ciekaw. Bo przy obecnych zaje...fajnych cenach pamięci, 1x512MB tych właśnie mogłem (i raczej nadal mogę) mieć za ok. 450-470zł. Jakby bezproblemowo chodziły na 220MHz (choć mocno wskazane 230) na minimalnych/bardzo zbliżonych do minimalnych timingach, to warto by się zastanowić nad ich kupnem. Bo wyższych osiągów w sumie mi nie trzeba...
Sławetne BH-4 ... tylko czy będa w ogóle w sprzedaży - a jeżeli tak czy będą lepsze od BH-5 ...
Pogloski chodzily ze 250MHz 2-2-2 /2,6V :wink: ....oby winbond sie nawrocil i wypuscil to cacko :)
Mushkin to Mushkin :wink:
nie badz taki slepo zapatrzony....
mialem w reku czterech muszkinow (pc3200 'special 222' (bh-6)) i powiem, ze nawet w takich pamieciach trzeba trafic na dobry egzemplarz.
poza tym level 1 to juz nie to samo - one sa na 2-3-2 i wcale nie musza chodzic na 2-2-2.
poza tym mozna czesto wsrod noname'ow wyszukac dobre sztuki - mam seiteca chodzacego na 234MHz 2-2-2 3V, v-date - 236MHz, mialem do niedawna v-date chodzaca na 229MHz 2-3-2 2.7V (teraz bawi sie nia Fumfel_20). no i mam kingstonika na bh-6 - 241MHz 2-2-2 3V - lepszy od najlepszego muszkina ktorego mialem.
poza tym mozna czesto wsrod noname'ow wyszukac dobre sztuki - mam seiteca chodzacego na 234MHz 2-2-2 3V, v-date - 236MHz, mialem do niedawna v-date chodzaca na 229MHz 2-3-2 2.7V. no i mam kingstonika na bh-6 - 241MHz 2-2-2 3V - lepszy od najlepszego muszkina ktorego mialem.
:D
Nie jestem slepo zapatrzony, tylko potwierdzam slowa LordFury (o tym ze np. KHX3200A raczej nie mialyby szans isc na 250 nawet).
