soska66 Opublikowano 4 Maja 2005 Zgłoś Opublikowano 4 Maja 2005 (edytowane) Nowy problem. tym razem w pliku servera. program ma wysylac wiadomosc z klienta do serwera i spowrotem. to pierwsze juz dziala. teraz bawie sie kierunkiem serwer-klient public class Server implements ActionListener,Runnable { ServerSocket serversocket; public Server(int port){ try{ serversocket=new ServerSocket(port,64000); }catch(Exception e){System.out.println("Server socket not created...");} new Thread(this).start(); } public void run(){ while(true){ System.out.println("Waiting for incoming connection..\n"); try{ Socket socket=serversocket.accept(); new SingleThread(socket); }catch(Exception e){System.out.println("An error occured...\n");} } } public static void main(String args[]){ Frame f=new Frame(); TextField t=new TextField(); f.setBounds(0,0,400,200); f.setLayout(new GridBagLayout()); t=new TextField("Tu wpisz tresc wiadomosci..."); t.setColumns(40); f.add(t); Button button=new Button("Send"); button.addActionListener(this); f.add(button); f.show(); int port=0; if(args.length>0){ try{ port=new Integer(args[0]).intValue(); }catch(Exception e){port=7000;} new Server(port); }else{ System.out.println("Usage: java Server por \nExample: java Server 7001\n"); } } public void actionPerformed(ActionEvent evt) { Button b= (Button)evt.getSource(); }}class SingleThread implements Runnable{ DataInputStream in; DataOutputStream out; public SingleThread(Socket socket){ try{ in=new DataInputStream(socket.getInputStream()); out=new DataOutputStream(socket.getOutputStream()); }catch(Exception e){System.out.println("Streams not initialized...");} new Thread(this,"in").start(); new Thread(this,"out").start(); } public void run(){ if(Thread.currentThread().getName().equals("in")){ while(true) try{ String object=(String)in.readUTF(); System.out.println("Otrzymales:"+object); }catch(Exception e){System.out.println("Object had not been read...");} } if(Thread.currentThread().getName().equals("out")){ try{ out.writeUTF("Hello from Pawel Steblinski..."); }catch(Exception e){System.out.println("Object had not been read...");} } }}class MyObject implements Serializable{ String message; public MyObject(String str){ this.message=str; }} Mam powyzszy kod. w funkcji main probuje dodac Frame z buttonem i TextField. Ale w momencie dodania ActionListenera do Button'a button.addActionListener(this); - kompilator wyrzuca mi blad: non-static variable this cannot be referenced from a static context i wskazuje na wyraz THIS w nawiasie O co chodzi?? pytam na forum bo nie mam czasu zeby wczytywac sie teraz w Jave. A jestem dopiero raczkujacym uzytkownikiem tej platformy. Na jutro musze zrobic program (a dokladnie dopisac pare rzeczy do gotowego szkieletu). prosze o pomoc w powyzej opisanej kwestii Edytowane 4 Maja 2005 przez soska66 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
spicum Opublikowano 5 Maja 2005 Zgłoś Opublikowano 5 Maja 2005 a zastanowiles sie co to 'this' znaczy ? Probujesz w metodzie statyczej (mozliwej do odpalenia bez tworzenia instancji klasy) dobrac sie przez this do takiej instancji - co jest oczywiscie bez sensu. utworz sobie objekt klasy Server i zamiast this przekaz instancje tego objektu. czyli button.addActionListener(this);zamieniasz na Server server = new Server(11111); button.addActionListener(server); gdzie 11111 to jakis port ktory sobie wylosowalem - patrz konstruktor klasy Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
soska66 Opublikowano 5 Maja 2005 Zgłoś Opublikowano 5 Maja 2005 mam teraz tak public class Server implements ActionListener,Runnable { ServerSocket serversocket; String sendstring; TextField t; public Server(int port){ try{ serversocket=new ServerSocket(port,64000); }catch(Exception e){System.out.println("Server socket not created...");} new Thread(this).start(); } public void run(){ while(true){ System.out.println("Waiting for incoming connection..\n"); try{ Socket socket=serversocket.accept(); new SingleThread(socket); }catch(Exception e){System.out.println("An error occured...\n");} } } public static void main(String args[]){ Server server = new Server(64000); Frame f=new Frame(); TextField t=new TextField(); f.setBounds(0,0,400,200); f.setLayout(new GridBagLayout()); t=new TextField("Tu wpisz tresc wiadomosci..."); t.setColumns(40); f.add(t); Button button=new Button("Send"); button.addActionListener(server); f.add(button); f.show(); int port=0; if(args.length>0){ try{ port=new Integer(args[0]).intValue(); }catch(Exception e){port=7000;} new Server(port); }else{ System.out.println("Usage: java Server por \nExample: java Server 7001\n"); } } public void actionPerformed(ActionEvent evt) { Button b= (Button)evt.getSource(); if(b.getLabel()=="Send") { String sendstring=new String("dbehfbue"); } }class SingleThread implements Runnable{ DataInputStream in; DataOutputStream out; public SingleThread(Socket socket){ try{ in=new DataInputStream(socket.getInputStream()); out=new DataOutputStream(socket.getOutputStream()); }catch(Exception e){System.out.println("Streams not initialized...");} new Thread(this,"in").start(); new Thread(this,"out").start(); } public void run(){ if(Thread.currentThread().getName().equals("in")){ while(true) try{ String object=(String)in.readUTF(); System.out.println("Otrzymales:"+object); }catch(Exception e){System.out.println("Object had not been read...");} } if(Thread.currentThread().getName().equals("out")){ try{ out.writeUTF(new String(sendstring)); }catch(Exception e){System.out.println("Object had not been read...");} } }}}class MyObject implements Serializable{ String message; public MyObject(String str){ this.message=str; }} przerzucilem klase SingleThread do wnetrza klasy glownej Server. Tworze String sendstring. Jesli nadam mu wartosc na samym poczatku to elegancko dziala i funkcja run() w klasie SingleThread widzi wartosc tego Stringa. Ale gdybym chcial dokonac zmiany wartosci Stringa sendstring w funkcji nacisniecia buttona (actionPerformed), nie nadajac wartosci na poczatku............to tej zmiany funckcja run() w SingleThread juz nie widzi???? na czym polega moj blad?? co porawic Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
spicum Opublikowano 6 Maja 2005 Zgłoś Opublikowano 6 Maja 2005 gdy robisz public void actionPerformed(ActionEvent evt) { Button b= (Button)evt.getSource(); if(b.getLabel()=="Send") { String sendstring=new String("dbehfbue"); } } to String sendstring=new String("dbehfbue");tworzy lokalny w obrebie tego ifa objekt. jesli chesz dopisac sie pod globalna zmienna sendstring to sendstring=new String("dbehfbue");lub this.sendstring=new String("dbehfbue"); dalej kodu nie czytalem wiec nie daje gwarancji ze tylko to jest zwalone Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
