ryjeq Opublikowano 9 Stycznia 2006 Zgłoś Opublikowano 9 Stycznia 2006 Instalacja mojej neostrady przebiega następująco: Please type your VPI VCI numbers (eg, 0 38 for UK)0 35Please enter your ISP Login ID (eg another@hg1.btinternet.com)xxxxx@neostrada.plPlease enter your ISP PasswordxxxxxSettings: VPI / VCI : 0 / 35 Login : xxxxxx@neostrada.pl Password : xxxxxxAre these correct? (Y/N)yNo further user interaction is required.Configuring SpeedTouch Driver...Software Configuration - SUCCESSBuilding SpeedTouch Driver...Software Build - SUCCESSInstalling SpeedTouch Driver...Software Installation - SUCCESSCreating ppp files in /etc/pppYou can ignore any insmod hints here... *** Configuration finished. Starting the connection ***pon sty 9 16:03:35 CET 2006The modem lights should start flashing for approx. 60 seconds...You might see some messages about USBDEVFS_BULK failed - you can ignore this.pon sty 9 16:04:12 CET 2006The lights should both be solid green now.Running : /usr/sbin/pppd call adslCalled pppd - you should see some messages about IP addresses now...Jan 9 16:04:22 localhost pppd[12324]: pppd 2.4.3 started by root, uid 0Jan 9 16:04:22 localhost pppd[12324]: Using interface ppp0Jan 9 16:04:22 localhost pppd[12324]: Connect: ppp0 <--> /dev/pts/1Jan 9 16:04:26 localhost pppd[12324]: CHAP authentication succeededJan 9 16:04:26 localhost pppd[12324]: local IP address 83.30.53.42Jan 9 16:04:26 localhost pppd[12324]: remote IP address 213.25.2.199Jan 9 16:04:26 localhost pppd[12324]: primary DNS address 194.204.152.34Jan 9 16:04:26 localhost pppd[12324]: secondary DNS address 217.98.63.164 inet addr:83.30.53.42 P-t-P:213.25.2.199 Mask:255.255.255.255Looks like we're online...Hey look, I can see the Net from here!Configuration finished.Any potential problems are listed below:To automatically dial-in when the PC boots up :update-rc.d speedtouch start 90 2 3 4 5 . stop 10 0 1 6 .Do you want to set this up now? (Yes / No)y System startup links for /etc/init.d/speedtouch already exist.init command succeededYou are now connected. There is no need to run thisspeedtouchconf.sh script again.Congratulations. Jak po restarcie probuje nawizac recznie polaczenie (speedtouch start) to wyskakuje mi takie cos : Napisz `grep --help' żeby dowiedzieć się więcej.Usage: /sbin/modprobe [-v] [-V] [-C config-file] [-n] [-i] [-q] [-o <modname>] <modname> [parameters...]/sbin/modprobe -r [-n] [-i] [-v] <modulename> .../sbin/modprobe -l -t <dirname> [ -a <modulename> ...] * Robie wg tego opisu: http://asseq.pl/modules/articles/article.php?id=37 (paczka z marca) Działa, ale po ponownym uruchomieniu komputera już nie. Jak to zrobic żeby działało? (musze za kazdym wlaczeniem kompa instalowac od nowa) PS. za każdym razem jak robie sudo apt-get install update to wszystko, przedtem często widze komunikat że "Nie udało się wykonać operacji stat na liście pakietów źródłowych...". Mimo że przed restartem ściągam wszystko Obie lampki na modemie nawet po restarcie świecą się stałym, zielonym światłem Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
lofix Opublikowano 10 Stycznia 2006 Zgłoś Opublikowano 10 Stycznia 2006 widzisz...skucha wczoraj moj gronostaj zbil mi krysztalowa kule..nie wiem np jakiego distro uzywasz.. (a moze to livecd?) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
MeHow Opublikowano 10 Stycznia 2006 Zgłoś Opublikowano 10 Stycznia 2006 lofix, bankowo jest to Ubuntu. A teraz jedna rzecz... Do you want to set this up now? (Yes / No)y wpisz tam yes, zamiast y. Juz parokrotnie widzialem, ze tylko yes potwierdzalo, a wszystko inne zaprzeczalo. Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
