Jacka
Problem Z Installshield
Symptoms
When installing, the progress bar stops at 0%, and the installation freezes. This usually happens only on specific machines and is not a project-specific issue.
Cause
This can be caused by any of the following:
1)The user does not have their DCOM permissions set correctly.
2)Virtual memory is low on the machine.
3)TEMP and TMP directories are full.
4)Other (usually silent) applications are running in the background (Gozilla, for example).
Resolution
To resolve this:
1)Set DCOM permissions correctly to user by assigning Everyone Full Access using DCOMCNFG.
2)Increase the amount of virtual memory on the machine.
3)Clean out TEMP and TMP directories.
4)Stop any other applications that may be taking up machine resources.
Pamiec wirtualna jest ok.
Temp wyczyszczone.
Wszystkie aplikacje pozamykane.
Pozostaje to :
Moze mi ktos objasnic szerzej jak to zrobic?
