zamrozony Opublikowano 28 Sierpnia 2008 Zgłoś Opublikowano 28 Sierpnia 2008 Witam posiadam następujący problem po odpaleniu serwera Life For Speed z lapperem. Mój system to debian 32-bit, dodam że mono i wine zostało zainstalowane. login as: root root@91.199.22.32's password: Last login: Fri Aug 29 07:43:22 2008 from acmz163.neoplus.adsl.tpnet.pl Linux d125965.serwerydedykowane.pl 2.6.18-6-686 #1 SMP Tue Jun 17 21:31:27 UTC 2008 i686 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. madgame:~# mono LFSLapper.exe /cfg=LFSLapper.cfg Cannot open assembly LFSLapper.exe. madgame:~# cd gry/LifeForSpeed/ madgame:~/gry/LifeForSpeed# ls DediGUIcfg cfg.txt readme_DediGUIng.txt DediGUIng.exe data setup.cfg LFS.exe deb.log setup.cfg.save LFSLapper.cfg docs setup_trk.txt LFSLapper.exe host21000.txt setup_wel.txt README.txt interface_cfg.txt madgame:~/gry/LifeForSpeed# mono LFSLapper.exe /cfg=LFSLapper.cfg LFSLapper, Version=4.0.0.41811, Culture=neutral Copyright © 2005-2007 Janez Cufer LFSLapper comes with ABSOLUTELY NO WARRANTY This is free software, and you are welcome to redistribute it under certain conditions. Read LICENSE for details. The following error occurred: File not found. mscorlib at System.IO.StreamReader..ctor (System.String path, System.Text.Encoding encoding, Boolean detect_encoding_from_bytemarks, Int32 buffer_size) [0x00000] at System.IO.StreamReader..ctor (System.String path) [0x00000] at (wrapper remoting-invoke-with-check) System.IO.StreamReader:.ctor (string) at LFS.Configurator.Load (System.String filepath) [0x00000] at LFSLapper.LFSClient..ctor (System.String scriptfilename, Boolean debugmode) [0x00000] at LFSLapper.LFSLapper.Main (System.String[] Args) [0x00000] Void .ctor(String, Encoding, Boolean, Int32) ^AInt32 ReceiveFrom_nochecks(System.Byte[], Int32, Int32, SocketFlags, System.Net.EndPoint ByRef) Z góry dziękuje za pomoc Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
