demek
Ddr2 - Wszystko O Kosciach Micron D9
Kiedys:
GoodRam 667 zwykly - D9 lub inne kosci
GoodRam 800 PRO - D9 zarowno w 1GB jak i 512MB (pakowane x2 Dual)
Jak jest teraz nei wiem, sadze,z e w GR PRO powinny jeszcze byc. Ale wszyscy sie pytaja, bo kazdy boi sie kupic ;D
lista Fatbody D9, wszystkie dane przekopiowane na chama z http://www.xtremesystems.org/forums/showthread.php?t=77442
podziękowania dla V I P E R za dobrze wykonaną pracę :)
2x512MB kit list
Corsair
Corsair XMS2 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 1000 (PC2 8000) System Memoryl
Model #: TWIN2X1024-8000UL
Corsair XMS2 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Model #: TWIN2X1024A-6400
Corsair XMS2 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 675 (PC2 5400) Dual Channel Kit System Memory
Model #: TWIN2X1024A-5400UL
Corsair CM2X512A-5400UL v1.1 (3-2-2-8 )
Corsair TwinX kit 1GB 5400UL v1.2 = Micron "D9" MT47H64M8BT-37E (rev. A)
Mushkin
Mushkin eXtreme Performance 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) System Memory - Retail
Model #: 991472
PDP Patriot
Patriot 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 700 (PC2 5600) Dual Channel Kit System Memory
Model #: PDC21G5600+XBLK
**Patriot PDC21G8000ELK 1GB Kit DDR2-1000 PC2-8000 Dual Channel Memory Kit
**Patriot 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Model #: PDC21G6400LLK
Crucial
Crucial Ballistix 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 1000 (PC2 8000) Dual Channel Kit System Memory
Model #: BL2KIT6464AA1005
Crucial Ballistix 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Model #: BL2KIT6464AA804
Crucial Ballistix 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 667 (PC2 5300) Dual Channel kit System Memory - Retail
Model #: BL2KIT6464AA663
OCZ
OCZ Platinum Series with Enhanced Bandwidth technology (EB) Dual Channel Kits 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) System Memory
Model #: OCZ28001024EBDCPE-K
**OCZ EB DDR2 PC2-5400 Titanium Dual Channel
1GB Dual Channel Kit P/N-OCZ26671024EBDCTE-K
**OCZ DDR2 PC2-8000 Platinum Enhanced Latency Dual Channel
1GB Dual Channel Kit P/N - OCZ210001024ELDCPE-K
**OCZ DDR2 PC2-5400 Platinum Enhanced Bandwidth Dual Channel
1GB (2x512) D/C Kit PN – OCZ26671024EBDCPE-K
**OCZ DDR2 PC2-4200 Platinum Enhanced Bandwidth Ltd. Revision 2 Dual Channel
1GB (2X512) D/C Kit PN - OCZ25331024EBDCPER2-K
2x1Gb kit list
Corsair
Corsair TWIN2X1024-8000UL 2GB Kit DDR2-1000 XMS2-8000 Xtreme Performance Memory
Corsair TWIN2X1024-6400 2GB Kit DDR2-800 XMS2-6400 Xtreme Performance Memory
Corsair TWIN2X1024A-5400UL v1.1 (3-2-2-8 )
PDP Patriot
Patriot PDC22G5600+XBLK2GB Kit DDR2-700 PC2-5600 Dual Channel Memory Kit
Mushkin
Mushkin eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) System Memory
Model #: 991473
Mushkin eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Dual Channel kit System Memory
Model #: 991382
Crucial
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 1000 (PC2 8000) Dual Channel Kit System Memoryl
Model #: BL2KIT12864AA1005
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Model #: BL2KIT12864AA804
OCZ
2GB Dual Channel Kit P/N-OCZ26672048EBDCTE-K
2GB (2X1024) D/C Kit PN - OCZ25332048EBDCPER2-K
2GB (2x1024) D/C Kit PN – OCZ26672048EBDCPE-K
te ** to nie są pewniaki :-|
następna zerżnięta bez skrupułów ;) lista pamiątek na Micron D9
podziękowania dla GoriLLakoS i Sentential z forum www.xtremesystems.org za dobrze wykonaną robotę
TEAM XTREEM
TEAM XTREEM DDR2 512/1024/2X512/2X1024 PC2-5300 1.95 - 2.3V 667@3-3-3-8 HS=Auminum D9GMH chips
Corsair
Corsair DDR2 TWINX 2x1024 UL -5400 667@3-3-2-8-1T HS=Black XMS2 D9DQT / Micron BT-3
Corsair DDR2 TWINX 2x512 C4 -5400 667@4-4-4-12 HS=Black XMS2 Naya chips Rev 5.2 uses D9DQW or MT47H64M8BT-37E
Corsair DDR2 TWINX 2x1024 UL -8000 1000@5-4-4-9 HS=Black XMS2 D9DQT / Micron BT-3
Corsair DDR2 TWINX 2x1024 UL -8500 1100@5-5-5-15 D9GMH
Corsair DDR2 TWINX 2X512 UL-5400 667@3-3-2-8-1T HS=Black XMS2 D9DQT / Micron BT-3
Corsair DDR2 TWINX 2X512 UL -8000 1000@5-4-4-9 HS=Black XMS2 D9DQT / Micron BT-3
Mushkin
Mushkin DDR2 XP2 2X1024 -8000 1000@4-5-4-112.2-2.3V Micron D9GMH chips HS=Black
Mushkin PC2-6400 XP 2x512 D9DQT / Micron BT-3
Mushkin PC2-6400 XP 2x1024 D9DQT / Micron BT-3
G.SKILL
G.SKILL DDR2 F2-8000PHU1/2HX 1024/2X1024-8000 1000@4-4-4-52.2~2.3V D9GKX chipsHS=Black
OCZ
OCZ EB DDR2 PC2-5400 Titanium 2.1V 667@4-2-2-8 D9DQT / Micron BT-3
OCZ DDR2 PC2-5400 Platinum Enhanced Bandwidth 2.1V 667@4-2-2-8 D9DQT / Micron BT-3
OCZ DDR2 PC2-6400 Platinum Enhanced Bandwidth 2.1V D9DQT / Micron BT-3
SUPER TALENT
SUPER TALENT DDR2 1024/2X1024 - 6400 800@4-3-4-8???V D9DQT/Micron BT-3 chips/HS=Silver ---> D9GKX
SUPER TALENT DDR2 1024/2X1024 - 8000 1000@5-5-5-15???V D9DQT/Micron BT-3 chips/New Rev is D9GKX chips HS=Silver
PATRIOT
PATRIOT DDR2 512/1024/2X512/2X1024 - 6400LL 800@4-4-4-12*2.1V Micron D9DQT - Micron BT-3 chips HS=RED
PATRIOT DDR2 512/2X512 - 8000LL 1000@5-5-5-152.3+VMicron D9DQT/Micron BT-3 chips HS=RED
BALLISTIX
BALLISTIX DDR2 512/1024/2X512/2X1024 - 6400 800@4-4-4-12 2.2V Micron BT-37E--->Micron B6-37E Some 2 x 1024 uses Micron B6-25F Some 2 x 512 uses Micron D9GMH HS=YELLOW
BALLISTIX DDR2 512/1024/2X512/2X1024 - 8000 1000@5-5-5-15 2.2V Fatbody D9/Micron BT-3 chips--->Micron B6-3 HS=YELLOW
BUFFALO
BUFFALO DDR2 256/512/1024 PC2-4200 V? 533@4-?-?-? D9DCN chips
Kingston
Kingston 512MB PC2-4200 CL4 240-Pin DIMM KVR533D2N4/512 1.8V D9DCN
i oczywiście nasz rodzimy produkt GoodRAM PRO (dzięki vojt, wisnia666)
Dołączona grafika
Dołączona grafika
jak rozpoznać czy pamięć jest na kościach Micron D9
Dołączona grafika
Dołączona grafika
Dołączona grafika
jak widzimy powyżej każda z kostek ma charakterystyczną ciąg znaków rozpoczynający się od D9DQT, D9GKX oraz D9DQV i właśnie te D9 oznacza czy kości są przesławnymi D9, charakterystyczna dla tych pamięci jest również "kropka" na każdej z kostek :-P
Czasami trzeba przypatrywać się trochę bardziej :)
Dołączona grafika
Dołączona grafika
edit
dzielniki :)
Dołączona grafika
Edytowane przez cavarr
Ładnie to wszytsko zebrałeś! wkoncu nie 3ba sie blakac po xs zeby sprawdzic co jest na d9:)
W gruncie rzeczy wszystkie pamieci PCR8000 powinny być na D9 (oraz takie, na które producent daje możliwość dania napiecia rzędu 2.3-2.4V), ale z PC 6400 to już nie jest takie pewne. Postaram się dodac jeszcze kilka modułów, gdzie występowanie D9 jest prawdopodobne, ale nie na 100%. Edytowane przez mach82
jak sprawdzić czy pamięci są "fatbody" czy "normal" D9 ??
bo szukałem i oczywistej odpowiedzi nie znalazłem :(
wiem że fatbody lubią wysokie napięcia (nawet 2.9V) i niskie timingi (3-2-2), zwykłe D9 zaś nie lubią tak extremalnych doznań :lol2:
ta kostka na bank jest fatbody :)
Dołączona grafika
czy fatbody oznacza wielkość kości pamięci ??
te są malutkie i nie są fatbody :cry:
Dołączona grafika
Jaka jest reguła, powtarzalność ??
Tak - chodzi o wielkość. Dodatkowo fatbody od dawien dawna nie są produkowane, więc nigdzie ich już nie znajdziesz. Co do zwykłych D9 - też łykaja napiecia rzędu 3V, co można zobaczyć chociażby na XS, chociaż PCB już musi być na wysokim poziomie.
poszukałem jeszcze trochę i doszedłem do wniosku że fatbody są tylko na kostkach D9DQT i D9DQW :] (Fatbody low speedbinds: D9CRZ), a najlepszymi dostępnymi teraz pamiątkami są D9Gxx
pozdro
Hmmm...
Ciekawe tylko ile przesyłka by kosztowała.
Czyli przy płycie na 975 kręcą się lepiej niż zwykłe(tzn. non-ecc) fat body? Baaardzo kuszące... :)
Dokladniej ujmujac:
There is benefit from overclocking ECC ram . You can clock higher because of the error correction . Articles in google say that there is a slow down when ECC tries to correct errors (2% approx) , but i haven't seen any slowdown myself .
I have 3 pairs of D9DQT (Fatbody) and all of them can clock about 15-20Mhz DDR2 higher when ECC is enabled . I run always with ECC enabled .
If i need the faster running memory (More Mhz) , i can have it without problems when enabling the error correction . Of course the benefit from clocking CPU higher is more than the "supposed" slow down of the ECC .
Jesli idzie o koszt przesylki - pewnie w granicach 10-25$ max.
Sam czekam na D9DQW, jak tylko skompletuje zestaw podziele sie wrazeniami.
A takie pytanie, czy wszystkie fat body podkręcają się rewelacyjnie? Bo chyba się skusze na te D9FJG :-P
A ten cytat to z XS zaczerpnięty? Możesz podać dokładny link?
Trudno stwierdzic bez dokladnych testow, na pewno kusi cena.
Cytat pochodzi z tego watka - post #31
ja mam parke 2x256 nie spisałem dokładnych oznaczeń ale micron oem- na 420 już sopi prelizyły-będe maił czs to pokatuje goldem ile leća.. na 2.3v bo tyle moge max dać na p5wd2..chyba ze sie za mody wezme :wink:
LISTA PAMIĄTEK NA KTÓRYCH MOŻNA ZNALEŹĆ D9'tki:
CORSAIR
XMS2 DDR2 TWIN2X MATCHED MEMORY PAIRS SERIES
CORSAIR DDR2 TWINX 2x1024 UL -5400 667@3-3-2-8-1T HS=Black XMS2 D9DQT - Micron BT-3 chips
CORSAIR DDR2 TWINX 2x512 C4 -5400 667@4-4-4-12 HS=Black XMS2 Naya chips Rev 5.2 D9DQW ou MT47H64M8BT-37E
CORSAIR DDR2 TWINX 2x1024 UL -8000 1000@5-4-4-9 HS=Black XMS2 D9DQT - Micron BT-3 chips
CORSAIR DDR2 TWINX 2x1024 UL -8500 1100@5-5-5-15 HS=Platinum XMS2 D9GMH
XMS2 DDR2 XTREME PERFORMANCE SERIES
CORSAIR DDR2 TWINX 2X512 UL-5400 667@3-3-2-8-1T HS=Black XMS2 D9DQT - Micron BT-3 chips
CORSAIR DDR2 TWINX 2X1024 -6400 667@5-5-5-12 HS=Black XMS2 Micron BT-37E
CORSAIR DDR2 TWINX 2X512 UL -8000 1000@5-4-4-9 HS=Black XMS2 D9DQT - Micron BT-3 chips
CRUCIAL
BALLISTIX SERIES
BALLISTIX DDR2 512/1024/2X512/2X1024 - 5300 667@3-3-3-12 2.2V D9DQT - Micron BT-3--->Micron B6-3 HS=YELLOW
BALLISTIX DDR2 512/1024/2X512/2X1024 - 6400 800@4-4-4-12 2.2V Micron BT-37E--->Micron B6-37E HS=YELLOW
PATRIOT
EXTREME PERFORMANCE SERIES
PATRIOT DDR2 512/1024/2X512/2X1024 - 6400LL 800@4-4-4-12 2.1V Micron D9DQT - Micron BT-3 chips HS=RED
PATRIOT DDR2 512/2X512 - 8000LL 1000@5-5-5-152.3+VMicron D9DQT - Micron BT-3 chips HS=RED
XBL SERIES
PATRIOT DDR2 512/1024/2x512/2X1024 - 4200XBL 667@3-2-2-4 Micron BT-37E chips HS=RED
PATRIOT DDR2 512/1024/2X512/2X1024 - 5600XBL 700@4-3-3-12 Micron BT-37E chips--->New modules are elpida and B6-3 HS=RED
GOODRAM
GOODRAM PRO
DDR2 512MB PC-800 Goodram Pro CL 5 5-5-15 Micron D9GMH, D9GCT? chips
DDR2 1024MB PC-800 Goodram Pro CL 5 5-5-15 Micron D9GMH, D9GCT? chips
DDR2 2x512MB PC-800 Goodram Pro CL 5 5-5-15 Micron D9GMH, D9GCT chips
DDR2 2x10241024MB PC-800 Goodram Pro CL 5 5-5-15 Micron D9GMH, D9GCT? chips
OCZ
TITANIUM SERIES
OCZ EB DDR2 PC2-5400 Titanium 2.1V 667@4-2-2-8 MicronBT-3 chips
PLATINUM SERIES
OCZ DDR2 PC2-4200 Platinum Enhanced Bandwidth Revision 2Limited Edition 2.0V 533@3-2-2-8 Micron BT-37Echips
OCZ DDR2 PC2-5400 Platinum Enhanced Bandwidth 2.1V 667@4-2-2-8 Micron BT-3
OCZ DDR2 PC2-6400 Platinum Enhanced Bandwidth 2.1V 800@4-3-3-8 Micron BT-3
MUSHKIN
MUSHKIN DDR2 XP2 2X1024 -8000 1000@4-5-4-112.2-2.3V Micron D9GMH chips
HS=Black
jakby ktos cos mial to prosze pw to dopisze...
Edytowane przez wspac
Z tego co cavarr pisze te http://www.allegro.pl/item115782517_markow...b_ddr2_cl4.html i te http://www.allegro.pl/item115786849_markow...b_ddr2_cl4.html moga byc na fat body... ze taka okazja przepuscilem, sa prawie identyczne jak te cruciale ze zdjec cavarra.. Chłopie nie mogłes tego napisac ze 2 tyg temu ;/
Edytowane przez wisnia666
NIE sa na fatbody. No chyba, ze to jakies fatbody co nie umieja 4-4-4 800mhz.
