zeus0
Komp Na Gwarancji ,winxpsp2,restart
Od grudnia 2004 (zainstalowałem nagrywarkę DVD) komp okazyjnie się restartuje . Po instalacji nagrywarki sytem się uruchamiał ale nie gasła dioda twardego dysku . Ściągnąłem firmware i zainstalowałem , problemik z diodą znikł . Oto opis minidumpa :
Microsoft ® Windows Debugger Version 6.4.0007.2
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\OKNA\Minidump\Mini030605-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
Debug session time: Sun Mar 6 07:26:04.296 2005 (GMT+1)
System Uptime: 0 days 4:44:23.865
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
Unable to load image NDIS.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for NDIS.sys
*** ERROR: Module load completed but symbols could not be loaded for NDIS.sys
Unable to load image fetnd5.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for fetnd5.sys
*** ERROR: Module load completed but symbols could not be loaded for fetnd5.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 100000D1, {0, 2, 0, f83c4c49}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Probably caused by : fetnd5.sys ( fetnd5+22f7 )
Followup: MachineOwner
kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: f83c4c49, address which referenced memory
Debugging Details:
MODULE_NAME: fetnd5
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 3b5818a8
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
unable to get nt!MiSessionPoolStart
unable to get nt!MiSessionPoolEnd
00000000
CURRENT_IRQL: 2
FAULTING_IP:
NDIS+22c49
f83c4c49 f60001 test byte ptr [eax],0x1
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
LAST_CONTROL_TRANSFER: from f88102f7 to f83c4c49
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
f89511e4 f88102f7 0028eed8 f8951b04 00000001 NDIS+0x22c49
f8951fa0 f8810053 81f8f000 f8951fd0 00000000 fetnd5+0x22f7
81f984b8 00000000 00000000 00000000 00000000 fetnd5+0x2053
FOLLOWUP_IP:
fetnd5+22f7
f88102f7 ?? ???
SYMBOL_STACK_INDEX: 1
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: fetnd5+22f7
IMAGE_NAME: fetnd5.sys
STACK_COMMAND: kb
BUCKET_ID: WRONG_SYMBOLS
lub tak :
Loading Dump File [C:\OKNA\Minidump\Mini030405-01.dmp]
Debug session time: Fri Mar 4 18:00:38.921 2005 (GMT+1)
System Uptime: 0 days 0:24:52.484
BugCheck 10000050, {ffffffd8, 0, 80573d30, 0}
kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: ffffffd8, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 80573d30, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000000, (reserved)
Debugging Details:
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 41108004
ffffffd8
FAULTING_IP:
nt+9cd30
80573d30 ff75d8 push dword ptr [ebp-0x28]
MM_INTERNAL_CODE: 0
BUGCHECK_STR: 0x50
LAST_CONTROL_TRANSFER: from 804df06b to 80573d30
STACK_TEXT:
f4f02d34 804df06b 000000e4 ffffffff 00cbeca8 nt+0x9cd30
f4f02d64 7c90eb94 badb0d00 00cbec14 00000000 nt+0x806b
00cbec9c 7c864800 00cbecd8 00000000 00000728 0x7c90eb94
00cbeccc 0046fcb3 00000002 000000e4 00a2e19c 0x7c864800
00000000 00000000 00000000 00000000 00000000 0x46fcb3
STACK_COMMAND: .bugcheck ; kb
Komputer był w lutym dwa razy ( po pięć) dni w serwisie Vobis-u i nic nie stwierdzono . Co teraz ? Pomocy...
Edytowane przez zeus0
Odszukaj co to za plik  fetnd5.sys  i zobacz co za program z niego korzysta. Sproboj go wtedy odinstalowac i zobaczyc co i jak
1313257[/snapback]
sterownik do karty sieciowej , ściągnąłem juz nowy pod winxpsp2 , zobaczymy.....
miałem to samo
żadne sterowniki nie pomogły - instalowałem najnowsze, najstarsze, ze strony producenta m,obo, ze strony nvidiii do chipsetu(...cokowlwiek wymyślisz to przerabiałem...)
karta była wspawana na mobo
wyłączyłem w biosie, zakupiłem nową na PCI i jak ręką odjął
