sideband Opublikowano 13 Grudnia 2005 Zgłoś Opublikowano 13 Grudnia 2005 Yes the DHzer0point 0.8195 Release is here, we sent this set through extensive testing due to Nvidia's changing code base and a need to rewrite our tweaks for best performance, IQ and stability after all our beta testing though I'm glad to release the set to the public. Big thanks to SFOSOK and Scooper for their help with the 7xxx series and SLI, as well as all the rest of the beta testers for the hard work. DHzer0point 0.8195 Released! What's new? Dual core/Hyperthreading optimizations from Nvidia Rewritten tweak base, Improving high end pixel shading performance UT2004 and older early DX9/8 improvements Compatibility tweaks still included Fixed Resolutions bug All SLI options, rendering AA/AF, Overclocking options should be available Full Mobility support Hardcoded PCI Latency to BIOS defaults VMR option available and enabled by default tutaj Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
