uff...AR Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 wydawalo mi sie ze kiedys bylo, ale nie moge znalezc. chce zmienic mac dla sieciowki. pod winda to nie problem a tu nie wiem jak. niestety chyba nie wiem jak to zrobic. robie tak: [root@shoofar root]# ifconfigeth0 Link encap:Ethernet HWaddr 00:04:61:00:02:44 inet addr:10.5.13.19 Bcast:10.255.255.255 Mask:255.0.0.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:789 errors:0 dropped:0 overruns:0 frame:0 TX packets:76 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:74757 (73.0 Kb) TX bytes:4142 (4.0 Kb) Interrupt:11lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:10 errors:0 dropped:0 overruns:0 frame:0 TX packets:10 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:700 (700.0 b) TX bytes:700 (700.0 b)[root@shoofar root]# ping 10.5.13.15PING 10.5.13.15 (10.5.13.15) from 10.5.13.19 : 56(84) bytes of data.64 bytes from 10.5.13.15: icmp_seq=1 ttl=128 time=0.851 ms64 bytes from 10.5.13.15: icmp_seq=2 ttl=128 time=0.219 ms64 bytes from 10.5.13.15: icmp_seq=3 ttl=128 time=0.405 ms--- 10.5.13.15 ping statistics ---3 packets transmitted, 3 received, 0% loss, time 1998msrtt min/avg/max/mdev = 0.219/0.491/0.851/0.266 ms[root@shoofar root]# ifconfig eth0 down[root@shoofar root]# ifcifcfg ifconfig[root@shoofar root]# ifconfig eth0 hw ether 00:02:44:2C:28:BF[root@shoofar root]# ifconfig eth0 up[root@shoofar root]# ifconfigeth0 Link encap:Ethernet HWaddr 00:02:44:2C:28:BF inet addr:10.5.13.19 Bcast:10.255.255.255 Mask:255.0.0.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:55 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:104783 (102.3 Kb) TX bytes:4562 (4.4 Kb) Interrupt:11lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:10 errors:0 dropped:0 overruns:0 frame:0 TX packets:10 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:700 (700.0 b) TX bytes:700 (700.0 b)[root@shoofar root]# ping 10.5.13.15PING 10.5.13.15 (10.5.13.15) from 10.5.13.19 : 56(84) bytes of data.From 10.5.13.19 icmp_seq=1 Destination Host UnreachableFrom 10.5.13.19 icmp_seq=2 Destination Host UnreachableFrom 10.5.13.19 icmp_seq=3 Destination Host Unreachable--- 10.5.13.15 ping statistics ---6 packets transmitted, 0 received, +3 errors, 100% loss, time 4999ms, pipe 3[root@shoofar root]# co jest nie tak. :arrow: czemu przestaje widziec kolesia. zmieniam bo chce wykorzystac zintegrowana sieciowke na plycie. :arrow: jak zmienic to na stale? :arrow: moge w biosie zmienic mac, ale miejsca na wpisanie jest mniej niz te 12 cyferek. jakis inny format? da sie to zmienic? prosze o pomoc i wyrozumialosc. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
ParanoiK Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 1) Nie masz przypadkiem adresu ip powiązanego na stałe (np. przez dhcp) z MAC adresem karty? 2) Skrypty inicjalizacyjne? 3) A na ile? Adres MAC składa się z 48 bitów (6 bajtów). Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
uff...AR Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 1) ip mam statyczny 10.5.13.19. tamten mac jest z karty jaka dostalem do sieci osiedlowej i zeby serverek nie odrzucal musi byc, ale czemu po zmianie przestaje widziec kolesia z bloku. jak zmienie pod winda to odrazu net zaczyna dzialac (server przestaje odrzucac pakiety) 2) jak bys byl tak mily i powiedzial jakie pliczki mam edytowac to by mi oszczedzilo czasu bo bez neta pod linuxem to musze restartowac kompa i do windy wejsc zeby cos przeczytac i pozniej znowu zeby zobaczyc czy dziala. 3) ok rozumiem ze to sie zapisac na 8 bajtach ale w biosie mam 6 miejsc do wpisania. wydaje mi sie ze do zapisania maca szesnastkowo potrzebnych jest 12 miejsc. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
ParanoiK Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 No to po kolei: 1) statyczny, czyli sam sobie przypisujesz czy serwer dhcp ci przypisuje? 2) Zależy jaka dystrybucja 3) na 6 bajtach. A w manualu nic nie masz na ten temat? Może tylko część MAC'a możesz zmienić... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
uff...AR Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 1) z tego co mi wiadomo to statyczny czyli niezmienny w przeciwienstwie do przydzielanego dynamicznie czyli np przez dhcp. mam staly i sam wpisuje. 2) mandrake9 3) niestety wlasnie obczailem. m0ge zmienic ostatnie 3 bajty. nadal pozostaje pytanie jak zmienic ten mac. help! Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
ParanoiK Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 1) e-e... dhcp może przydzielić statyczny lub dynamiczny. Ale już wiadomo o co chodzi. Udało mi się zasymulować problem i go rozgryzłem. Przy kładzeniu eth0 zostaje usunięta tablica routingu. Spróbuj zrobić route add default gw <gateway> metric 1 2) hmm... nie orientuję się zbytnio w skryptach SysV. W każdym razie powinno to się uruchamiać gdy wchodzisz w runlevel 3. 3) Wyguglałem coś takiego: A word on MAC addresses. They are six bytes long: the first three bytes "belongs" to a particular manufacturer. It is then the manufacturer's responsibility to allocate numbers from that block in such a way that a MAC address is a guaranteed globally unique identifier. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
uff...AR Napisano 17 Marca 2003 Zgłoś Napisano 17 Marca 2003 zaczne od jednej rzeczy. co ma brama (gateway) do tego ze po zmianie maca przestaje pingowac kolesia z bloku (10.5.13.15). teraz wkleje to co zepsulem. moze po dokladnym przeczytaniu wyjda jakies oczywiste bledy. [root@shoofar root]# routeKernel IP routing tableDestination Gateway Genmask Flags Metric Ref Use Iface10.0.0.0 * 255.0.0.0 U 0 0 0 eth0127.0.0.0 * 255.0.0.0 U 0 0 0 lodefault * 0.0.0.0 U 0 0 0 eth0[root@shoofar root]# ping 10.5.13.15PING 10.5.13.15 (10.5.13.15) from 10.5.13.19 : 56(84) bytes of data.64 bytes from 10.5.13.15: icmp_seq=1 ttl=128 time=0.698 ms64 bytes from 10.5.13.15: icmp_seq=2 ttl=128 time=1.31 ms64 bytes from 10.5.13.15: icmp_seq=3 ttl=128 time=0.530 ms--- 10.5.13.15 ping statistics ---3 packets transmitted, 3 received, 0% loss, time 2014msrtt min/avg/max/mdev = 0.530/0.848/1.317/0.339 ms[root@shoofar root]# ifconfig eth0 down[root@shoofar root]# ifconfig eth0 hw ether 00:02:44:2C:28:BF[root@shoofar root]# ifconfig eth0 up[root@shoofar root]# ifconfigeth0 Link encap:Ethernet HWaddr 00:02:44:2C:28:BF inet addr:10.5.13.19 Bcast:10.255.255.255 Mask:255.0.0.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:77 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:97434 (95.1 Kb) TX bytes:1142 (1.1 Kb) Interrupt:11lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:11 errors:0 dropped:0 overruns:0 frame:0 TX packets:11 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:756 (756.0 b) TX bytes:756 (756.0 b)[root@shoofar root]# routeKernel IP routing tableDestination Gateway Genmask Flags Metric Ref Use Iface10.0.0.0 * 255.0.0.0 U 0 0 0 eth0127.0.0.0 * 255.0.0.0 U 0 0 0 lo[root@shoofar root]# ping 10.5.13.15PING 10.5.13.15 (10.5.13.15) from 10.5.13.19 : 56(84) bytes of data.From 10.5.13.19 icmp_seq=1 Destination Host UnreachableFrom 10.5.13.19 icmp_seq=2 Destination Host UnreachableFrom 10.5.13.19 icmp_seq=3 Destination Host Unreachable--- 10.5.13.15 ping statistics ---5 packets transmitted, 0 received, +3 errors, 100% loss, time 4026ms, pipe 3[root@shoofar root]# routeroute routef routel[root@shoofar root]# route add default gw 10.10.10.1 metric 1[root@shoofar root]# routeKernel IP routing tableDestination Gateway Genmask Flags Metric Ref Use Iface10.0.0.0 * 255.0.0.0 U 0 0 0 eth0127.0.0.0 * 255.0.0.0 U 0 0 0 lotutaj nie wiem czemu jest ok 20 sekond przerwy i dopiero po tym czasie pojawia sie: default 10.10.10.1 0.0.0.0 UG 1 0 0 eth0[root@shoofar root]# ping 10.5.13.15PING 10.5.13.15 (10.5.13.15) from 10.5.13.19 : 56(84) bytes of data.--- 10.5.13.15 ping statistics ---3 packets transmitted, 0 received, 100% loss, time 2014ms moze tez dla zupelnej jasnosci podam wszystko (nawet to co niepotrzebne) co wiem o tym jak ma wygladac konfiguracja ip: 10.5.13.19 maska: 255.0.0.0 brama: 10.10.10.1 no i dns'y: 10.10.10.1 62.233.128.17 213.77.115.28 dodatkowo jest napisane (czego nie uzywam, bo w windzie nie jest to konieczne do dzialania czyli tu pewnie tez) ze host ma byc Komp201, a domena osiedle.md4.pl. nazwa i opis kompa: Komp 201. grupa robocza Osiedle. uff... moze teraz sie cos rozjasni bo mnie to juz zaczyna denerwowac. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
ParanoiK Napisano 18 Marca 2003 Zgłoś Napisano 18 Marca 2003 before: default * 0.0.0.0 U 0 0 0 eth0 after: default 10.10.10.1 0.0.0.0 UG 1 0 0 eth0 hint1: * == 0.0.0.0 hint2: Use the force Luke. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
uff...AR Napisano 18 Marca 2003 Zgłoś Napisano 18 Marca 2003 to zauwazylem. po zmianie nic. ale jest cos takiego jak ifcfg-eth0 i tam mozna wpisac HWADDR=<maczek> ale chyba w ktoryms skrypcie (albo czyms) wywolywanym przez ifup sa zle sciezki (i jakies inne bledy). to juz nie pierwszy raz jak mam do czynienia z jakimis niedorobkami w mandrake. jak bede mial czas to zmieniam na rh8. ew. moze cos innego sobie sciagne. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
ParanoiK Napisano 18 Marca 2003 Zgłoś Napisano 18 Marca 2003 Hmm... no to nie wiem... Ja zrobiłem tak jak podałem z zasymulowanym problemem i u mnie działa. Inną kwestią jest to, że używam slacka. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
