Janekk
Ecs X58b-a Black Series
Firma ECS wprowadziła na rynek płytę główną X58B-A Black Series zbudowaną w oparciu o chipset Intel X58 Express. Urządzenie przeznaczone jest do współpracy z najnowszymi procesorami firmy Intel Core i7.
Dołączona grafika
Dołączona grafika
CPU
LGA1366 socket for latest Intel new Core i7 high-end desktop processors
QPI 4.80GT/s to 6.40GT/s
6 Phase Power Design with VRD 11.1 Compliant
CHIPSET
Intel® X58 & ICH10R
North Bridge: Intel® X58
South Bridge: Intel® ICH10R
MEMORY
Triple-channel DDR3 memory architecture
6 x 240-pin DDR3 DIMM socket support up to 24GB
Support DDR3 OC1600/1333/1066/800 DDR3 SDRAM
Supports Intel® Extreme Memory Profile (XMP)
EXPANSION SLOT
2 x PCI Express Gen 2.0 x16 slots (Support 2x16 ATI CrossFireXTM and NVIDIA SLITM feature)
1 x PCI Express x4 slot
2 x PCI Express x1 slots
1 x PCI slot
STORAGE
Support by Intel® ICH10R
6 x Serial ATAII devices
supports RAID0, 1, 5, 0+1
Support by JMicron® JMB362
2 x eSATAII 3.0Gb/s devices
AUDIO
Realtek ALC 888S-VC supports 8-channel HD audio
Heat Pipe
1 x ECS QooTechII Heat Pipe
Dual Giga LAN
Dual Realtek 8111C PCIe GigaLAN Controller
REAR PANEL I/O
1 x PS/2 keyboard & PS/2 mouse connectors
6 x USB ports
1 x Clear_CMOS button
2 x e-SATA ports
1 x IEEE 1394 port
2 x RJ45 LAN connectors
1 x Audio port (1Line in, 4x Line out, 1 Optical SPDIF Out)
INTERNAL I/O CONNECTORS & HEADERS
1 x 24-pin ATX Power Supply Connector & 8-pin 12V Connector
6 x Serial ATA connectors
3 x USB 2.0 headers support additional 6 USB ports
1 x Clear CMOS header
1 x Front panel header
1 x Front panel audio header
1 x 1394a header
CD in header
1 x 7S-LED Display
1 x Buzzer
4 x FAN Connectors (CPU_FAN/SYS_FAN/NB_FAN/PWR_FAN)
1 x SPDIF out header
1 x 4-pin power connector for VGA card
1X Power on LED (Green light)
1 x PWR button/ 1 x RST button
1X Stand by LED (Red Light)
1 x COM header
SYSTEM BIOS
AMI BIOS with 16Mb SPI ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Supports ACPI revision 1.0 specification
ECS M.I.B Support Over-Clocking:
CPU Voltage : Adjustable CPU voltage from 0.5V to1.6V
NB (IOH )Voltage: Adjustable NB (IOH) voltage from 0.011V to 0.693V
CPU VTT Voltage: Adjustable CPU VTT voltage from 0.013V to 0.481V
SB(ICH10R) Voltage: Adjustable SB (ICH10R) voltage from 0.05V to 0.15V
VDIMM : DRAM voltage control from 0.015V to 0.945V
Support PCI-E over-clocking function
Support CPU over-clocking function: Adjustable CPU Clock Multiplier
FORM FACTOR
ATX Size 305mm*244mm
Edytowane przez rmvbhd
Po czarnym kolorze PCB tego ECSa można wnioskować że jest to płyta high-endowa, jednak ja nie mam przekonania co do osiągów i jakości wykonania tej płyty. Jak ktoś będzie ją miał to napiszcie coś więcej na jej temat.
