Pietia(lania) Opublikowano 4 Września 2012 Zgłoś Opublikowano 4 Września 2012 Panowie jest sobie serwer z owym programem do robienia backapu no i wywala blad : buffer (writer): write of data failed: No space left on devicebytes to write=10240, bytes written=-1, total written 26715910Kafio: "-" [offset 26099m+804k+0]: Fatal error:afio: "-": Broken pipeERROR: non-zero exit from:buffer -m 10m -p 75 -s 10k -t -u 100 -B -o /dev/nst0afio -o -z -1 mC -b 10k - blee czyli brakuje mu miejsca na tasiemce :/ konfig flexa wyglada tak : # -*-Mode: perl-*-# ----------------------------------------------------------------------# Flexbackup configuration file# check "flexbackup -help" for usage information# ----------------------------------------------------------------------# General configuration section# Archive type? afio, dump, tar, cpio, star, pax, zip, lha, ar, shar# 'copy' or 'rsync' are extra options if running in archive-to-disk mode.# 'filelist' dumps a list of files in your cwd - for debugging setup/exclusion$type = 'afio';# Configure backup "sets".# Not needed if you use "-dir <dir>" to backup one tree at a time.# Each set is a simple space-separated list of filesystems# Remote filesystems should denoted as 'host:dir'# You can use anything (other than 'all') as set names## Example:# $set{'set1'} = "/home /usr";# $set{'set2'} = "/dir3 machine2:/dir4 machine3:/dir5";## "-set all" will back up all defined sets. If you are doing a full backup# using tapes, each "set" will go onto a different tape and you will be# prompted for tape change in between.#$set{'backup'} = "/opt/backup/sod /opt/backup/kk";$set{'test'} = "/etc";# Subtree pruning# A space-separated list of directories to prune from each backup.# Key is a filesystem or host:dir spec as outlined above# regular exp[b][/b]ressions allowed (not shell-type wildcards!)$prune{'/'} = "tmp proc sys" ;# Compression$compress = 'false'; # one of false/gzip/bzip2/lzop/zip/compress/hardware$compr_level = '4'; # compression level (1-9) (for gzip/bzip2/lzop/zip)# Buffering program - to help streaming$buffer = 'buffer'; # one of false/buffer/mbuffer$buffer_megs = '10'; # buffer memory size (in megabytes)$buffer_fill_pct = '75'; # start writing when buffer this percent full$buffer_pause_usec = '100'; # pause after write (tape devices only)# Device to backup to. -->> non-rewinding version, please! <<--## Examples:# Linux SCSI: /dev/nst0 Linux IDE: /dev/nht0# Linux ftape: /dev/nqft0 FreeBSD SCSI: /dev/nrsa0 (4.x compat device node)# FreeBSD SCSI: /dev/nsa0 (5.x)## If a directory, will archive to files in that directory rather than a device# If "host:/dev/tapedevice", will use remote tape drive via rsh/ssh#$device = '/dev/nst0';# Block size (in kilobytes!) to use for archive programs and dd. Default is# 10 for most things. Some tape drives need 32 or 64. Set to '0' to# disable all blocking$blksize = '10';# Block size (in bytes!) to use for the tape device, with "mt setblk" or# equivalent. If set to 0, will use "variable" block size for the tape# device (which is recommended). Comment out or set to "$blksize * 1024" to# have it be the same as the archiver block size above.$mt_blksize = "0";# Padding. True to pad blocks to blocksize# (devices only, not used when archiving to files)$pad_blocks = 'true';# Other global flags$remoteshell = 'ssh'; # command for remote shell (rsh/ssh/ssh2)$remoteuser = ''; # if non-null, secondary username for remote shells$label = 'true'; # somehow store identifying label in archive?$verbose = 'true'; # echo each file?$sparse = 'true'; # handle sparse files?$indexes = 'true'; # false to turn off all table-of-contents support# If backing up to files, use static filenames - no date stamp# (same level backup of same directory will overwrite old backups)$staticfiles = 'false';# True to try and preserve file access times during backup, if the selected# archive program can do so. Note that if this is true, -cnewer checks (file# permission/status changes only, not content) are turned off when deciding# which files to archive on the local system.$atime_preserve = 'false';# Span across filesytems? ("dump" will ignore this option)# Set to "false" (don't) , "local" (all but nfs/smbfs), or "all" (everything)$traverse_fs = 'false';# Exclude files that match these *regular exp[b][/b]ressions* (not shell wildcards)# from the backups (no affect on 'dump' archives). You can list more than one,# just keep incrementing the index in the brackets for each. Also, strip off# leading directories (the filesystem specs above or the "-dir" flag).# Matches paths, not filenames, so put .* on the front/back as needed.# Comment these out to exclude nothing.$exclude_expr[0] = '.*/[Cc]ache/.*';$exclude_expr[1] = '.*~$';# If true (default), and using a tape device, level zero "set" backups# assume you want to erase and use a new tape for each set. If false, level# zero "set" backups append to tapes. To force an erase for any backup,# use "-erase" on the commandline.$erase_tape_set_level_zero = 'true';# Set this to "true" to make erase operations just call "mt rewind" - not# "mt rewind' followed by "mt erase". (For some tape drives, erase takes# hours rather than seconds or is otherwise undesirable)$erase_rewind_only = 'true';# ----------------------------------------------------------------------# Log/stamp files, path for temporary files$logdir = '/var/log/flexbackup'; # directory for log files$comp_log = 'gzip'; # compress log? false/gzip/bzip2/lzop/compress/zip$staticlogs = 'false'; # static log filenames w/ no date stamp$prefix = ''; # log files will start with this prefix$tmpdir = '/tmp'; # used for temporary refdate files, etc$stampdir = '/var/lib/flexbackup'; # directory for backup timestamps$index = '/var/lib/flexbackup/index'; # DB filename for tape indexes$keyfile = '00-index-key'; # filename for keyfile if archiving to dir$sprefix = ''; # stamp files will start with this prefix# ----------------------------------------------------------------------# Parameters for 'afio' only# File extensions that should not be compressed (seperate with spaces)$afio_nocompress_types = 'mp3 MP3 Z z gz gif zip ZIP lha jpeg jpg JPG taz tgz deb rpm bz2 lzo';# True to show block numbers$afio_echo_block = 'false';# Files less than this size (kilobytes) won't be compressed$afio_compress_threshold = '3';# Maximum amount of memory (megabytes) to use for temporary storage of# compression results. If a compressed file is bigger than this, compression# will have to run twice on the file (see manpage).$afio_compress_cache_size = '64';# ----------------------------------------------------------------------# Parameters for 'tar' only# True to show record numbers$tar_echo_record_num = 'false';# ----------------------------------------------------------------------# Parameters for 'cpio' only# Format of cpio archive$cpio_format = 'newc';# ----------------------------------------------------------------------# Parameters for 'dump' only# Estimated tape size (in kilobytes). This number doesn't really do much# but help 'dump' get size estimates if set to zero uses 'dump -a'$dump_length = '0';# True to use /etc/dumpdates (could mess things up if you dump subdirectories# of mount points). False to use flexbackup's timestamps.$dump_use_dumpdates = 'false';# ----------------------------------------------------------------------# Parameters for 'star' only# Use fifo (buffering)? (you probably want to set $buffer=false above if so)$star_fifo = 'true';# Handle ACLs?$star_acl = 'true';# Format of star archive$star_format = 'exustar';# True to show block numbers$star_echo_block_num = 'false';# ----------------------------------------------------------------------# Parameters for 'pax' only# Format of pax archive$pax_format = 'ustar';# ----------------------------------------------------------------------# Parameters for 'zip' only# File extensions that should not be compressed (seperate with spaces)$zip_nocompress_types = 'mp3 MP3 Z z gz gif zip ZIP lha jpeg jpg JPG taz tgz deb rpm bz2 lzo';# ----------------------------------------------------------------------# Parameters for 'package delta' backups# Archive a list of all installed packages in the top level of each backup?# Can be 'false', 'true' (save it for any backup), or# 'rootonly' (saves list only if the filesystem is '/')$pkgdelta_archive_list = 'rootonly';# Archive files not "owned" by packages?$pkgdelta_archive_unowned = 'true';# Archive any package-owned files which have been modified?$pkgdelta_archive_changed = 'true';# ----------------------------------------------------------------------# Paths to commands. Default will look for them in $PATH. Use this if# you want to set commands explicitly. You can use full paths or just# change command names.## Example: If GNU tar is called "gtar" on your system:# $path{'tar'} = 'gtar';## Or can be used to "sudo" certain commands. Examples:# $path{'find'} = 'sudo find';# $path{'dump'} = 'sudo dump';# $path{'afio'} = 'sudo -u nonrootuser afio';## ----------------------------------------------------------------------# mt operation overrides. Set if flexbackup doesn't know the right mt# command(s) for your OS/device, or you want to override things.## Example: use "mt status" instead of "mt tell"# $mt{'tell'} = 'status';######################################################################## $Id: flexbackup.conf,v 1.74 2003/09/21 22:59:58 edwinh Exp $# $Name: v1_2_1 $## Leave '1;' on the the next line - for perl 'require'1; natomiast conf zrobiony przez firme wyglada tak : autoconf # $Id: autobackup 22357 2012-01-08 21:56:24Z psztoch $# Copyright (C) 2007 FINN Sp. z o.o. Wszelkie prawa zastrzeżone.# Katalog docelowy do składowania paczek archiwalnych.# Pamiętaj aby na archiwa była wydzielona osobna partycja# i miała wielkość wystarczającą na przechowanie ustalonej# niżej liczby archiwów dziennych.FILE_TARGET=/opt/backup/sod/fileMYSQL_TARGET=/opt/backup/mysqlPGSQL_TARGET=/opt/backup/sod/pgsql# Liczba dni w przeciągu których przechowujemy kopie.# Starsze kopie są automatycznie kasowane.FILE_DAYS=1MYSQL_DAYS=1PGSQL_DAYS=1# Ścieżki jakie mają być archiwizowane. Można podać wiele ścieżek.FILE_PATHS="/etc"# Użytkownik i hasło dostępu do serwera z uprawnieniami administratora.# Przy odpowiednio skonfigurowanym serwerze hasło może byc opcjonalne.MYSQL_USER=mysql#MYSQL_PASSWD=PGSQL_USER=postgres#PGSQL_PASSWD=# Czy wykonywać archiwum automatycznie (cron.daily)?# Dozwolone wartości:# 1. yes, daily - archiwum jest wykonywane codziennie,# 2. weekly - archiwum jest wykonywane w niedziele,# 3. no - archiwum należy uruchomić ręcznie.FILE_CRON=yesSLAPD_CRON=noMYSQL_CRON=noPGSQL_CRON=yes# Czy automatycznie wysyłać archiwum do lokalizacji zdalnej?# Dozwolone wartości:# 1. yes, daily - archiwum jest przesyłane codziennie,# 2. weekly - archiwum jest przesyłane w niedziele,# 3. no - archiwum nie jest przesyłane.FILE_SEND=noSLAPD_SEND=noMYSQL_SEND=noPGSQL_SEND=no# Ewentualna maska na wysyłane archiwa (domyślnie wysyłane jest wszystko).#FILE_SEND_MASK=#MYSQL_SEND_MASK=# Bazy ktore maja byc pomijane przy archiwizacji i zdalnym skladowaniu.PGSQL_EXCLUDE=".*_old .*_old[0-9]"PGSQL_SEND_EXCLUDE=""# Bazy ktore maja byc pomijane przy dziennej archiwizacji od poniedzialku do soboty.#PGSQL_DAILY_EXCLUDE=".*_pliki"#PGSQL_DAILY_SEND_EXCLUDE=""# Mniejszy poziom kompresji backupów (znacząco zmniejsza czas tworzenia archiwum)PGSQL_ZLEVEL="-Z 2"# Opcjonalna zdalna lokalizacja do składowania archiwum.AUTOBACKUP_REMOTE=rsync://autobackup.finn.pl/autobackup/@HOSTNAME@NAME-@RANDOM/[/font][/size][/font][/color][color=#000000][font='Calibri'][size=3][font="Times New Roman"] dodam ze tasma i streamer to hp Streamer HP StorageWorks DAT 72i co mozna poprawic wywalic zeby mi sie te kopie miescily na tasmie :/ Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach Więcej opcji udostępniania...
