dav4
Sprawdzenie statusu SMART, dysk tyka
Witam! Ostatnio raz na jakiś czas słyszę z laptopa takie tykanie którego wcześniej nie słyszałem, możliwe że to tylko wentylatorek, ale może być to też dysk. Nachodzi mnie zakup SSD, ale najpierw chciał bym dowiedzieć się mniej więcej ile mój obecny dysk jeszcze pożyje :D
Laptop to Thinkpad X201, pracuje pod Linuxem. HDAPS(akcelerometr) zostało zainstalowane i działa, parkuje głowice  ;)
  Cytat
dawid@thinkpadx201-dawid ~ $ sudo smartctl /dev/sda -a
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.11-2-amd64] (local build)
Copyright © 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Momentus 7200.4
Device Model:     ST9320423AS
Serial Number:    5VH5806G
LU WWN Device Id: 5 000c50 02eb873e0
Firmware Version: 0003LVM1
User Capacity:    320,072,933,376 bytes [320 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Mon Apr 14 15:25:48 2014 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (    0) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: (   1) minutes.
Extended self-test routine
recommended polling time: (  77) minutes.
Conveyance self-test routine
recommended polling time: (   2) minutes.
SCT capabilities:       (0x103b) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   117   099   034    Pre-fail  Always       -       143304191
  3 Spin_Up_Time            0x0003   100   098   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1953
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   082   060   030    Pre-fail  Always       -       198983121
  9 Power_On_Hours          0x0032   091   091   000    Old_age   Always       -       8542 (1 79 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   020    Old_age   Always       -       1545
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   064   053   045    Old_age   Always       -       36 (Min/Max 26/36)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       60
192 Power-Off_Retract_Count 0x0032   077   077   000    Old_age   Always       -       46379
193 Load_Cycle_Count        0x0032   048   048   000    Old_age   Always       -       105255
194 Temperature_Celsius     0x0022   036   047   000    Old_age   Always       -       36 (0 12 0 0 0)
195 Hardware_ECC_Recovered  0x001a   055   052   000    Old_age   Always       -       143304191
196 Reallocated_Event_Count 0x000f   092   092   030    Pre-fail  Always       -       7446 (60672 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
254 Free_Fall_Sensor        0x0032   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Vendor (0x50)       Completed without error       00%      8365         -
# 2  Short offline       Completed without error       00%      8365         -
# 3  Conveyance offline  Completed without error       00%      7843         -
# 4  Short offline       Completed without error       00%      7843         -
# 5  Vendor (0x50)       Completed without error       00%      7754         -
# 6  Short offline       Completed without error       00%      7754         -
# 7  Vendor (0x50)       Completed without error       00%      7269         -
# 8  Short offline       Completed without error       00%      7269         -
# 9  Vendor (0x50)       Completed without error       00%      5855         -
#10  Short offline       Completed without error       00%      5855         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Edytowane przez dav4
