..::SNAP::..
Grafa made in ECS !!
http://www.tbreak.com/mira/imageview.php?image=357
looknijcie na pamieci :) Etrontech :wink:
cytacik: :D
GPU:
Xabre 400 AGP8X 256-bit graphic accelerator
Built-in programmable 24-bit ture-color RAMDAC, up to 375MHz pixel clock
AGP Interface: Supports AGP 3.0 compliant configuration setting.
Supports AGP 8X with 16 stages pipeline full side band function
Memory: Built-in eight 4Mx16 DDR onboard, total 64MB memory (optional 128MB)
3D Engine Features: Supports Direct 3D version 8.1 pixel shader version 1.3
Supports AGP 8X for texture/vertex fetch
Built-in 32-bit floating point VLIW Geometry Transform/Lighting (T/L) and triangle setup engine
Built-in 4 pixel programmable rendering pipelines and 8 texture units (4P8T)
Supports up to 2048x2048 texture size
Built-in hardware stereo auto rendering engine
Supports 2X/4X full scene anti-aliasing
Up to 250MHz 3D engine/memory clock
3D Performance: Supports up to 4 pixels with 2 textures within single cycle
Peak polygon rate: 25M polygon/sec @ 1 pixel/polygon with gouraud shaded, point-sampled, linear and bilinear texture mapping
Peak fill rate: 800M pixel/sec, 1600M texture/sec @ 10,000 pixel/polygon with Gouraud shaded, two bilinear textured
2D Engine Features: Built-in Hardware Command Queue
Built-in Direct Draw Accelerator
Built-in an 1T 128-bit BITBLT graphics engine
Supports memory-mapped, zero wait-state, burst engine write
Built-in 64x64x2 bit-mapped hardware cursor
Built-in 64x64x16 bit-mapped color hardware cursor
64MB (optional 128MB) frame buffer with linear addressing
Video Accelerator: MPEG-2 MP@ML standards compliant
Built-in motion compensation logic
Supports up to 20Mbit/sec bit rate decoding
Direct DVD to TV playback
Supports single video windows with overlay function
Supports YUV-to-RGB color space conversion
Supports graphics and video overlay function
Supports RGB555, RGB565, YUV422 and YUV420 video capture and playback format
Supports down scaling function and scaling vector as 1/2, 1/4
Supports de-interlaced and 1/2 down scaling function
Supports DVD sub-picture playback overlay
Built-in independent Gamma correction RAM
Supports Direct Draw Drivers
TV Out: SiS® 301 chip onboard
Built-in complete NTSC/PAL video encoder
Support NTSC/PAL interlaced display by dependent frame rate in 640x480x60Hz, 800x600x60Hz for NTSC, 640x480x50Hz and 800x600x50Hz for PAL
Support NTSC/PAL interlaced display by independent frame rate in 640x480, 800x600 and 1024x768modes for NTSC and PAL under 8, 16, 32bpp color modes
Supports Composite Video and S-Video TV-Out
Resolution: Supports VESA standards super high resolution graphics modes, up to 2048x1536x32 bpp @85Hz NI
Supports virtual screen up to 4096x4096
I/O Interface 1 VGA connector
1 S-Video and 1 composite connector for TV-OUT
1 3D VR glasses connector
wlasciwie to tylko jedna karte :P ale wedlug testuw wypada bardzo dobrze
Heh... w 3D MARK 2001 - default ( 1024/768/32bit ) moj Radek 7500 (jakis PowerMagic) wyciagnal 3406 - i to na slabszym sprzecie! - a ta karta ECS 3396... wiec zadna rewela :)
Zdajesz sobie sprawę, że ta karta jest celowana w typowy low-end? Cena tej karty jest napewno niska więc w sam raz do tanich zestawów.
hmm... na moje oko bedzie kosztować z 240-280 zł co za taką wydajność cena jest wprost rewelacyjna (mogę się mylić) ale chyba nie bo gdyby kosztowała ok. 300zł to poprostu była by zadroga Radeony 7500 DDR (te z niszszej pułki) są średnio po 350zł
Mogę jeszcze dodać że sis315 kosztuje teraz około 180zł a moim zdaniem jest lebszy od MX400
Karta ma super parametry jak na kategorie low-end. Jednak wydajność tak jak nieco podkręcony GF2 PRO - 3400 w 3d marku 2001...przynajmniej cena spox!
Może ktoś zarzucić tutaj linka do testu o którym mówicie?
Dlaczego nie? Samsung robi kiepskie HDD ale za to super pamięci. Może ECS będzie robił super karty...
Czy sugerujesz ze mobo od ECS'a jest tak dupiate jak hdd od samsunga?? A powiedz mi panie specjalisto jak często pracowałeś na mobo od ECS'a i czy miałeśmoze styczność z tym co ja mam w opisie albo z tym ECS'em na Sisie? JAK NIE... TO NIE PISZ PIERDÓŁ!! A pozatym to ja jestem pełen nadziei ze ta karta bedzie pierwszym krokiem do wejścia ECS'a na rynek kart graficznych... a później ECS zacznie robić HiEndowy sprzet...
Ja tesh nikomu nie życze źle. Fakt jest faktem (wiem z doświaczenia), że płyty ECS`a nie były udane - wyjątkiem jest K7S5A na SIS`ie 735 - jak coś było na niej nie tak to wystarczyła aktualizacja biosu.
Gr00bY Mazur"]Zdajesz sobie sprawę, że ta karta jest celowana w typowy low-end? Cena tej karty jest napewno niska więc w sam raz do tanich zestawów.
No... jesli cena jest niska, to co innego :) To wtedy zaczne zalowac, zem sie szarpnal na ATi :roll:
co low end to low end i tyle................
Athlon XP 1575MHz
256 RAM
MSI Geforce 4 Ti 4400 128MB DDR ( 310MHz/650MHz ) VIVO
11000 3dmarkow na 3Dmarku 2001 ver. 330 i wszystkie najnowsze gry w aa X4 .................... jeszce dlugo obejde sie obez modyfikacji i wymian a kupujac xabre za rok jestem zmuszony do wymiany taka prawde a do dooma 3 xabre odpada i to na tyle
De4@poczta.onet.pl
MAttX
ECS - jest *** wart- wiem to z własnego doświadczenia.. na sis735- było tak super,ze dzieki tej fajnej ,jak nie którzy twierdza , płycie kompa uruchamioało sie nawet przez 30 min - ładuje sie ładuje i [gluteus maximus]..
to doświadczenie mnie skutecznie zniecheciło do ECS pod wszelką postacią i to na długo
echhhhhh wiesz co ja mialem juz 4 ECS-y i jakos mi wszystkie chodzily dobrze wiec raczej trafiles zwalony model
co wy mi tu piep...cie o dyskach samsunga! widzieliscie cdromy? qwa ja ma juz chba 7go, a wszystko dlatego ze wymieniaja mi za froko tylko na samsungi!!!!!!!!!!!!!!!!!!!!!!!!! :cry:  :cry:  :cry:
Ta.. Ja miałem kiedyś 4 rzeczy od Samsung'a w kompie. Ehhh - dawne czasy - głupi byłem :wink: CD-ROM 24x - wytrzymał 2 tyg - potem serwis, dysk 17 miesięcy - 4 MB badów - siotra używa :lol: - głośniki - lewy zaczął cicho grać - polutowałem/przerobiłem po swojemu działają - monitor 2 lata - zaczął się "żółcić" tzn. wszystko wygląda jakby patrzeć przez żółte okulary 8O
Więc nie mów mi NIC o samsungu - no chyba że o pamięciach :P
Jak się nie umie skonfigórować windy albo instaluje się jakieś dziwne programy to potem startuje 30 min bo ja wiem że płyta jest super i jestem z niej happy  :D  i pewnie nasępna też będzie z ECS a teraz mysle o karcie Xaber
zgodze sie z toba w 100% mi tez moja MOBO chodzi zajebiscie jdyny minus to kiepskie mozliwosci podkrecania
