Szymon
problem z AGP INIT!!! :) POMOCY!! BLAGAM ZAJZYJCIE!! :]
*** Found kernel module build environment, generating kernel module now.
ATI module generator V 2.0
probing for VMA API version...
cleaning...
rmdir: `patch/drivers/char/drm': Katalog nie jest pusty
rmdir: `patch/drivers/char': Katalog nie jest pusty
rmdir: `patch/drivers': Katalog nie jest pusty
patching 'highmem.h'...
skipping patch for 'drmP.h', not needed
compiling 'agpgart_be.c'...
compiling 'agp3.c'...
compiling 'i7505-agp.c'...
compiling 'nvidia-agp.c'...
compiling 'firegl_public.c'...
linking of fglrx kernel module...
duplicating results into driver repository...
done.
- creating symlink
- recreating module dependency list
- trying a sample load of the kernel module
Warning: loading /lib/modules/2.4.20/kernel/drivers/char/drm/fglrx.o will taint the kernel: non-GPL license - Proprietary. © 2002 - ATI Technologies, Starnberg, GERMANY
See http://www.tux.org/lkml/#export-tainted for information about tainted modules
/lib/modules/2.4.20/kernel/drivers/char/drm/fglrx.o: init_module: Operation not permitted
/lib/modules/2.4.20/kernel/drivers/char/drm/fglrx.o: Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
You may find more information in syslog or the output from dmesg
/lib/modules/2.4.20/kernel/drivers/char/drm/fglrx.o: insmod /lib/modules/2.4.20/kernel/drivers/char/drm/fglrx.o failed
/lib/modules/2.4.20/kernel/drivers/char/drm/fglrx.o: insmod fglrx failed
failed.
Installed: qt3 (gcc 3.2) based control panel application
ATI display drivers successfully installed
please run 'fglrxconfig' now
prosze :) ta drtuga polowka :]. Za cholere nie wiem co ejst grane, wyczytalem na innym forum zeby wywalic z pameici ten modul jaki obecnie jest zlaadowany do grafiki. Korzystam z "radeon". Wiec wszedlem do konsoli, pisze
modprobe -r radeon
nic nie wyswietlil myslalem ze cos zrobil.
Ale to samo... rmmod radeon
nie ma atkego modulu.
Itd itd....czy ktos moze mi pomoc? :( bo juz meisiac probuje urucvhomic ta karte grafiki.
moje distro to slack 9.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:2:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0xe08c0000
(II) fglrx(0): [drm] mapped SAREA 0xe08c0000 to 0x40211000
(II) fglrx(0): [drm] framebuffer handle = 0xd8000000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 3.2.0
(II) fglrx(0): Date: Jul 10 2003
(II) fglrx(0): Desc: ATI Fire GL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0): Build-Kernel UTS_RELEASE: 2.4.20
(II) fglrx(0): Build-Kernel MODVERSIONS: yes
(II) fglrx(0): Build-Kernel __SMP__: yes
(II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
(II) fglrx(0): [drm] register handle = 0xe0020000
(EE) fglrx(0): [agp] unable to acquire AGP, error "xf86_ENOMEM"
(EE) fglrx(0): cannot init AGP
*** If unresolved symbols were reported above, they might not
*** be the reason for the server aborting.
Fatal server error:
Caught signal 11. Server aborting
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to xfree86@xfree86.org.
Wczesniejszy problem rozwlazaelm :) chodzilo o to ze sobie wczesniej wkompilowalem modul radeon w kernela. Dlatego nie mgolem go wyrzucic, teraz przekompilowalem kernela no i fglrx ladnei sie zaladowalo. ALe teraz mam takie cos :-/ POMOCY!! :))
