Sajo
Problem z Mandrake 9.2 i WineX
szukałem już wszędzie ale nie zanalazłem .Mam problem z konfiguracją winex . Ściągnełem wersje " winex3.2.1.i586.rpm " i po instlce mam normalnie w pasku zakładke emulator > winex . I niestety nie potrafie tego skonfigurować :(
A o to mój config może coś źle zrobiłem
[Drive A]
"Path" = "/mnt/floppy"
"Type" = "floppy"
"Label" = "Floppy"
"Device" = "/dev/floppy/0"
[Drive C]
"Path" = "/mnt/win_c"
"Type" = "hd"
"Label" = "/mnt/win_c"
"Device" = "/dev/hda1"
"Filesystem" = "win95"
[Drive D]
"Path" = "/mnt/win_d"
"Type" = "hd"
"Label" = "/mnt/win_d"
"Device" = "/dev/hda5"
[Drive E]
"Path" = "/mnt/windows"
"Type" = "hd"
"Label" = "/mnt/windows"
"Device" = "/dev/hdd6"
[Drive F]
"Path" = "/mnt/cdrom"
"Type" = "cdrom"
"Label" = "/mnt/cdrom"
"Device" = "/dev/scsi/host0/bus0/target0/lun0/cd"
[Drive X]
"Path" = "/tmp"
"Type" = "hd"
"Label" = "Tmp Drive"
[Drive Y]
"Path" = "${HOME}"
"Type" = "network"
"Label" = "Home"
[Drive Z]
"Path" = "/"
"Type" = "hd"
"Label" = "Root"
[wine]
"Windows" = "C:\\windows"
"System" = "C:\\windows\\system"
"Temp" = "X:\\"
"Path" = "C:\\windows;C:\\windows\\system;X:\\;X:\\test;Y:\\"
"GraphicsDriver" = "x11drv"
; Wine doesn't pass directory symlinks to Windows programs by default.
; Enabling this may crash some programs that do recursive lookups of a whole
; subdir tree in case of a symlink pointing back to itself.
;"ShowDirSymlinks" = "1"
;"ShowDotFiles" = "1"
"ShellLinker" = "wineshelllink"
# [wineconf]
"Profile" = "c:\\Documents and settings\\sajo"
[Version]
; Windows version to imitate (win95,win98,winme,nt351,nt40,win2k,winxp,win2k3,win20,win30,win31)
"Windows" = "win98"
; DOS version to imitate
;"DOS" = "6.22"
; Be careful here, wrong DllOverrides settings have the potential
; to pretty much kill your setup.
[DllOverrides]
; some dlls you may want to change
"oleaut32" = "builtin, native"
"ole32" = "builtin, native"
"commdlg" = "builtin, native"
"comdlg32" = "builtin, native"
"shell" = "builtin, native"
"shell32" = "builtin, native"
"shfolder" = "builtin, native"
"shlwapi" = "builtin, native"
"shdocvw" = "builtin, native"
"advapi32" = "builtin, native"
"msvcrt" = "native, builtin"
"mciavi.drv" = "native, builtin"
"mcianim.drv" = "native, builtin"
"msi" = "native, builtin"
; you can specify applications too
; this one will apply for all notepad.exe
;"*notepad.exe" = "native, builtin"
; this one will apply only for a particular file
;"C:\\windows\\regedit.exe" = "native, builtin"
; default for all other dlls
"*" = "builtin, native"
[x11drv]
; Number of colors to allocate from the system palette
"AllocSystemColors" = "100"
; Use a private color map
"PrivateColorMap" = "N"
; Favor correctness over speed in some graphics operations
"PerfectGraphics" = "N"
; Color depth to use on multi-depth screens
;;"ScreenDepth" = "16"
; Name of X11 display to use
;;"Display" = ":0.0"
; Allow the window manager to manage created windows
"Managed" = "Y"
; Use a desktop window of 640x480 for Wine
;"Desktop" = "640x480"
; Use XFree86 DGA extension if present
; (make sure /dev/mem is accessible by you !)
"UseDGA" = "Y"
; Use XVidMode extension if present
"UseXVidMode" = "Y"
; Use XRandR extension if present
"UseXRandR" = "Y"
; Use the take focus protocol
"UseTakeFocus" = "Y"
; Enable DirectX mouse grab
"DXGrab" = "N"
; Create the desktop window with a double-buffered visual
; (useful to play OpenGL games)
"DesktopDoubleBuffered" = "Y"
; Run in synchronous mode (useful for debugging X11 problems)
;;"Synchronous" = "Y"
; Use the Render extension to render client side fonts (default "Y")
;;"ClientSideWithRender" = "Y"
; Fallback on X core requests to render client side fonts (default "Y")
;;"ClientSideWithCore" = "Y"
; Set both of the previous two to "N" in order to force X11 server side fonts
; Anti-alias fonts if using the Render extension (default "Y")
;;"ClientSideAntiAliasWithRender" = "Y"
; Anti-alias fonts if using core requests fallback (default "Y")
;;"ClientSideAntiAliasWithCore" = "Y"
[fonts]
;Read the Fonts topic in the Wine User Guide before adding aliases
;See a couple of examples for russian users below
"Resolution" = "96"
"Default" = "-adobe-helvetica-"
"DefaultFixed" = "fixed"
"DefaultSerif" = "-adobe-times-"
"DefaultSansSerif" = "-adobe-helvetica-"
;; default TrueType fonts with russian koi8-r encoding
;"Default" = "-monotype-arial-*-*-*--*-*-*-*-*-*-koi8-r"
;"DefaultFixed" = "-monotype-courier new-*-*-*--*-*-*-*-*-*-koi8-r"
;"DefaultSerif" = "-monotype-times new roman-*-*-*--*-*-*-*-*-*-koi8-r"
;"DefaultSansSerif" = "-monotype-arial-*-*-*--*-*-*-*-*-*-koi8-r"
;; default cyrillic bitmap X fonts
;"Default" = "-cronyx-helvetica-"
;"DefaultFixed" = "fixed"
;"DefaultSerif" = "-cronyx-times-"
;"DefaultSansSerif" = "-cronyx-helvetica-"
; the TrueType font dirs you want to make accessible to wine
[FontDirs]
;"dir1" = "/usr/X11R6/lib/X11/fonts/TrueType"
;"dir2" = "/usr/share/fonts/truetype"
;"dir3" = "/usr/X11R6/lib/X11/fonts/TT"
;"dir4" = "/usr/share/fonts/TT"
[serialports]
"Com1" = "/dev/ttyS0"
"Com2" = "/dev/ttyS1"
"Com3" = "/dev/ttyS2"
"Com4" = "/dev/modem"
[parallelports]
"Lpt1" = "/dev/lp0"
[ppdev]
;; key: io-base of the emulated port
;; value : parport-device{,timeout}
;; timeout for auto closing an open device ( not yet implemented)
;"378" = "/dev/parport0"
;"278" = "/dev/parport1"
;"3bc" = "/dev/parport2"
[spooler]
"FILE:" = "tmp.ps"
"LPT1:" = "|lpr"
"LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
"LPT3:" = "/dev/lp3"
[ports]
;"read" = "0x779,0x379,0x280-0x2a0"
;"write" = "0x779,0x379,0x280-0x2a0"
[Debug]
;"RelayExclude" = "RtlEnterCriticalSection;RtlLeaveCriticalSection"
;"RelayInclude" = "user32.CreateWindowA"
;"RelayFromExclude" = "user32;x11drv"
;"RelayFromInclude" = "sol.exe"
;"SnoopExclude" = "RtlEnterCriticalSection;RtlLeaveCriticalSection"
;"SpyExclude" = "WM_SIZE;WM_TIMER;"
[registry]
;These are all booleans. Y/y/T/t/1 are true, N/n/F/f/0 are false.
;Defaults are read all, write to Home
; Where to find the global registries
;"GlobalRegistryDir" = "/etc";
; Global registries (stored in /etc)
"LoadGlobalRegistryFiles" = "Y"
; Home registries (stored in ~user/.wine/)
"LoadHomeRegistryFiles" = "Y"
; Load Windows registries from the Windows directory
"LoadWindowsRegistryFiles" = "Y"
; TRY to write all changes to home registries
"WritetoHomeRegistryFiles" = "Y"
; Registry periodic save timeout in seconds
; "PeriodicSave" = "600"
; Save only modified keys
"SaveOnlyUpdatedKeys" = "Y"
[Tweak.Layout]
;; supported styles are 'Win31'(default), 'Win95', 'Win98'
;; this has *nothing* to do with the windows version Wine returns:
;; set the "Windows" value in the [Version] section if you want that.
"WineLook" = "Win98"
[Clipboard]
"ClearAllSelections" = "0"
"PersistentSelection" = "1"
; List of all directories directly contain .AFM files
[afmdirs]
"1" = "/usr/share/ghostscript/fonts"
"2" = "/usr/share/a2ps/afm"
"3" = "/usr/share/enscript"
"4" = "/usr/X11R6/lib/X11/fonts/Type1"
[WinMM]
; Uncomment the "Drivers" line matching your sound setting.
"Drivers" = "wineoss.drv" ; default for most common configurations
;"Drivers" = "winearts.drv" ; for KDE
;"Drivers" = "winealsa.drv" ; for ALSA users
;"Drivers" = "winejack.drv" ; for Jack sound server
;"Drivers" = "winenas.drv" ; for NAS sound system
;"Drivers" = "wineaudioio.drv" ; for Solaris machines
;"Drivers" = "" ; to disable sound
"WaveMapper" = "msacm.drv"
"MidiMapper" = "midimap.drv"
[dsound]
;; HEL only: Number of waveOut fragments ahead to mix in new buffers.
;"HELmargin" = "5"
;; HEL only: Number of waveOut fragments ahead to queue to driver.
;"HELqueue" = "5"
;; Max number of fragments to prebuffer
;"SndQueueMax" = "28"
;; Min number of fragments to prebuffer
;"SndQueueMin" = "12"
;; Forces emulation mode (using wave api)
;"HardwareAcceleration" = "Emulation"
;; Sets default playback device (0 - number of devices - 1)
;"DefaultPlayback" = "0" ; use first device (/dev/dsp)
;"DefaultPlayback" = "1" ; use second device (/dev/dsp1)
;"DefaultPlayback" = "2" ; use third device (/dev/dsp2)
;; Sets default capture device (0 - number of devices - 1)
;"DefaultCapture" = "0" ; use first device (/dev/dsp)
;"DefaultCapture" = "1" ; use second device (/dev/dsp1)
;"DefaultCapture" = "2" ; use third device (/dev/dsp2)
[Network]
;; Use the DNS (Unix) host name always as NetBIOS "ComputerName" (boolean, default "Y").
;; Set to N if you need a persistent NetBIOS ComputerName that possibly differs
;; from the Unix host name. You'll need to set ComputerName in
;; HKEY_LOCAL_MACHINESystemCurrentControlSetControlComputerNameComputerName, too.
;"UseDnsComputerName" = "N"
# Application dependent sections follow #
[AppDefaults\\iexplore.exe\\DllOverrides]
"shell" = "native, builtin"
"shell32" = "native, builtin"
"shfolder" = "native, builtin"
"shlwapi" = "native, builtin"
"comctl32" = "native, builtin"
"commctrl" = "native, builtin"
[AppDefaults\\notes.exe\\DllOverrides]
"shlwapi" = "native"
"msvcrt" = "native"
"crtdll" = "native"
"ole32" = "builtin"
"oleaut32" = "builtin"
"olepro32" = "builtin"
[AppDefaults\\nlnotes.exe\\DllOverrides]
"msvcrt" = "native"
"crtdll" = "native"
"ole32" = "builtin"
"netbios" = "builtin"
[AppDefaults\\nhldaemn.exe\\DllOverrides]
"msvcrt" = "native"
"crtdll" = "native"
"ole32" = "builtin"
[AppDefaults\\_INS5576._MP\\x11drv]
; Lotus Notes R5 installer
; I'm quite not sure this will run on some other machine than mine, but it
; can't hurt
"Managed" = "N"
"Desktop" = "N"
[AppDefaults\\nlnotes.exe\\x11drv]
"Desktop" = "800x600"
[AppDefaults\\explorer.exe\\x11drv]
# [/wineconf]
problem polega na tym że nic nie działa pojawia sie klepsydra na pasku i nic więcej nie ma .Ani komunikatu o błędzie nic.Znika i tyle .Jest zakładka emulator > winex > add > dodawanie i usówanie programów i też nie działa.Program w Rpm ma już takie gotowce jak np : notatnik windows lub calkulator i też nie działają .Pojawia siee tylko klepsydra i nic .Może jeszcze dodam na jakim sprzęcie stoji mandrake : Athlon 2000+,Ati Rodeon 9600Pro Herkules,DDR 512mb,Dźwięk AC97
Uruchom byle jaki terminal np. xterm czy co tam w MDK 9.2 jest dostepne i spróbuj załadować program poleceniem
winex nazwaprogramu. Jeżeli wystapią jakies błędy to zostaną one wyswietlone.
Problem z wine Rozwiązałem :) Dzięki Wielki .Ale mam teraz inny problem brak obsługi OpenGL i nie mam pojęcia jak to zrobić .Używałem opisu ze strony http://forum.mandrake.pl/viewtopic.php?t=596 i tamten sposób nie działa to znaczy umnie ale u kolesia działa więc coś nie tak .Podejżewam że problem polega na różnicy międzi źródłem a strownikiem ATI (kernel-source-2.4.22-10mdk.i586.rpm a sterownik fglrx-glc22-4.3.0-3.2.8.i586.rpm) i niby wszystko gra .Ale jak wchodze do gry to mam może 2 klatki :(
