Jump to content
Shake
Catalyst 5.4 Is Out
Recommended Posts
Lista zmian:
http://www2.ati.com/drivers/Catalyst_54_release_notes.html
Wersja z CCC:
http://www.ati.com/home/online/CatalystCCCdriver.html
Wersja z starym CP:
http://www.ati.com/home/online/CatalystXPdriver.html
Nowości:
The CATALYST™ Software Suite 5.4 introduces enhanced HDTV support. The HDTV user interface has been significantly modified, making it much easier to select and configure the correct resolution for your HDTV when using the Component Video or DVI connection. The Displays Manager wizard has also been updated to assist users in setting up and configuring Component Video HDTV for the optimal viewing experience.
Share this post
Link to post
Share on other sites
NGO ATI Optimized v2.4
The NGO ATI Optimized Driver is a tweaked version of the ATI Catalyst driver. The main purpose is to satisfy the users with a better performance and better image quality.The Driver has support for all Radeon cards. (even Mobility and FireGL cards)
Changes:
• Updated to Catalyst 5.4
• OpenGL Driver Switcher has been updated
• Added support for more X800/X850 cards.
Notes:
• The author is not responsible for any damage.
• This driver is not supported by ATI Corporation.
• Always Uninstall the current driver before installing a new one
Included Utilities:
• ATI Tray Tools - Control Panel,Tweaker,Overclocker.
• Windows XP Universal Tweaker v0.3 - This small wizard utility capable to perform cleanup and to Tweak: Windows Memory management, Connection and MTU Settings and perform DNS cleanup, Tweak NTFS Partitions, Windows boot-time boost.
• OpenGL Driver Switcher - Switch between the old and the new OpenGL drivers on the fly.
Big Thanks to Ray Adams the Author of ATI Tray Tools.
Edited by baka
Share this post
Link to post
powiedcie mi mi ktore z modov sterownikow sa najlepsze - oprocz omeg ktore zasmiecaja troche system ( tak slyszalem od wiekszosci osob )
1376905[/snapback]
A ja słyszałem, że małże są ochydne. Zjedłem i mi posmakowały. No więc jak to jest?
A co do sterów, to uważam, że najbardziej dopracowane są omegi, choć teraz z przyczyn finansowych ich autora, wychodzą rzadziej.
Share this post
Link to post
używam catalystów
ale nie chce mi sie testowac co miesiac nowych
wiec sie zapytuje
jak sie mają nowe catalysty do o/c?
1384701[/snapback]
Mi na tych 5.4 podkręcalnośc podskoczyła z 410/530 na 420/540 co w sumie nie dało dużo ale zawsze wynik troszke większy.Na wszystkich innych przy 420/540 zawsze był zwis w 3d marku
POZDRO
Share this post
Link to post
A mi te stery dosc znacznie obnizyly wydajnosc np w Need for Speed Underground 2.. (dosc duze spadki fps + przycinanie). Co do O/C to żadnych zmian nie widze.
Share this post
Link to post
Mi na tych 5.4 podkręcalnośc podskoczyła z 410/530 na 420/540(...)
1385127[/snapback]
A mi te stery dosc znacznie obnizyly wydajnosc np w Need for Speed Underground 2.. (dosc duze spadki fps + przycinanie). (...)
1385218[/snapback]
i bądź tu mądry i pisz wiersze ;)
krótko mówiąc
zainstalować i sprawdzić ;)
dzięki za odp
Share this post
Link to post
krótko mówiąc
dzięki za odp
1385732[/snapback]
hehe zgadza sie :)
Share this post
Link to post
Qrde... coś nie tak... po zainstalowaniu Catalyst 5.4 nawet 3DSmark nie chce się uruchomić... marudzi coś o tym że sprzęt nie wspiera 3D???
próbowałem parę razy i nie dało rady... ktoś ma jakiś pomysł?
Share this post
Link to post
1392343[/snapback]
Wyczysc dokladnie system ze starych sterownikow. Reszta powinna juz pojsc gladko. U mnie zadnych problemow. Jednak wciaz uzywam 4.12, sa moim zdaniem najlepsze.
Share this post
Link to post
dzięki :)
a poprzednie sterowniki (chyba 4.10) mam jakoś specjalnie odinstalowywać czy nadpisać 4.12 na stare?
1393313[/snapback]
Uruchom kompa w trybie awaryjnym>Odinstaluj stery>Usun resztki Driver Cleanerem>Uruchom ponownie kompa> Zainstaluj nowe stery.
Krok z Driver Cleanerem mozesz pominac, jednak jesli to zrobisz, to pozostana jakies tam resztki starych sterow w systemie.
Share this post
Link to post
Wgrałem sobie te 5.4 i jestem serio zadowolony ( wcześniej jechalem na zabytkowych 3.2 :wink: ) w smarku 03 wzrost o ponad 150 a w 01 o 50 czyli jak najbardziej ok. jeszcze niegdy nowe stery nie podniosły mi wydajności karty , a tu prosze , no i niemam tych glupich artefaktów których na 3.2 bylo pelno . Po za tym w grach również ciut lepiej .Jedno slowe dobre stery , jak dla mnie najlepsze z tych co są :D
Share this post
Link to post
Pojawiły się omegi na cat 5.4
What's New in Omega Drivers?
v2.6.25
* Based on the Catalyst 5.4 Official drivers.
* Updated a lot of the internal tweaks for Mobility 9200 cards.
* Updated some other tweaks for all cards.
* Removed some redundant files from package.
* Added new option to installer: now you can select between installing with or without Radlinker, in case some of you can't use Radlinker for some reason or use another 3rd party tweaker.
What's new for RadLinker?
v2.034
* Removed support for Windows 98 and ME (holding me back).
* Rewritten driver.
* Cleaned up user interface.
* Removed temporal FSAA threshold as it does not appear to be needed anymore.
* DirectX 8 or greater is now required.
Do ściągnięcia z:
http://www.omegadrivers.net/ati/win2k_xp.php
Share this post
Link to post
1396064[/snapback]
Jak dla mnie to 5.4 są lepsze od porpzedniczek, karta sie dobrze reci i wydajność lepsza. A tak na marginesie to @_Ran'dall_ nieładnie robić plagiat - kopiując avatara od _Vip_'a !! :-P
Pozdro
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
Aktualności
Artykuły
  • Create New...
Important Information
