LordFury Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ Asus P5WDG2 WS Professional Strona producenta: ASUS CPU LGA775 socket for Intel® Pentium Processor Extreme Edition / Pentium D / Pentium 4 / Celeron CPU Support Intel 65nm, Core™2 Extreme / Core™2 Duo Support Intel next generation Mulit-Core CPU Compatible with Intel 06B, 05B/ 05A and 04B/04A processors Intel EM64T and Hyper-Threading Technology ready Chipset North Bridge: Intel 975X (support ATi CrossFire dual Gfx technology) South Bridge: Intel ICH7R PCI-X Bridge: Intel 6702 PXH Front Side Bus: 1066/800 MHz Memory 4 x DIMM, max. 8GB, DDR2 667/533, ECC and non-ECC un-buffered memory Dual channel architecture Native DDR2 800 Support Expansion Slots 2 x PCI-E x 16 slots 2 x PCI-X 2 x PCI 2.2 Storage Intel ICH7R controller supports: - 4 x SATA 3.0Gb/s (RAID 0,1,10,5) - 1 x UltraDMA 133/100 Marvell 88SE614x supports: - 4 x SATA 3.0Gb/s Audio ADI 1988B 8-channel High Definition Audio CODEC Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking Coaxial, Optical S/PDIF out on back I/O port LAN Marvell 88E8052 + 88E8001PCI-E Dual Gb LAN controller Support Teaming function USB 8 x USB 2.0 ports Advanced Thermal Design 8-Phase Power Design Stack Cool 2 Q-Fan 2 ASUS Heat-pipe thermal solution Testy / recenzje / przydatne linki: http://www.xtremesystems.org/forums/showthread.php?t=108011 (Ogólnie o płycie) http://overclock.pl/index.php/artykul,,79,...plyta_doskonala (Recenzja by Kas) (under construction) @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ Asus P5W64 WS Professional (aka The Wall Street Quartet) Strona producenta: ASUS CPU LGA775 socket for Intel® Pentium Processor Extreme Edition / Pentium D / Pentium 4 / Celeron CPU Support Intel 65nm, Core™2 Extreme / Core™2 Duo Support Intel next generation Mulit-Core CPU Compatible with Intel 06B, 05B/ 05A and 04B/04A processors Intel EM64T and Hyper-Threading Technology ready Chipset North Bridge: Intel 975X (support ATi CrossFire dual Gfx technology) South Bridge: Intel ICH7R PCIe Switch: IDT 89HA0324 Front Side Bus: 1066/800 MHz Memory 4 x DIMM, max. 8GB, DDR2 667/533, ECC and non-ECC un-buffered memory Dual channel architecture Native DDR2 800 Support Expansion Slots 4 x PCI-E x 16 slots 2 x PCI 2.2 Storage Intel ICH7R controller supports: - 4 x SATA 3.0Gb/s (RAID 0,1,10,5) - 1 x UltraDMA 133/100 Marvell 88SE6145 supports: - 3 x SATA 3.0Gb/s (RAID 0,1,10) - 1 x eSATA 3.0Gb/s Audio ADI 1988B 8-channel High Definition Audio CODEC Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking Coaxial, Optical S/PDIF out on back I/O port LAN Marvell 88E8052 + 88E8001PCI-E Dual Gb LAN controller Support Teaming function USB 8 x USB 2.0 ports Advanced Thermal Design 8-Phase Power Design Stack Cool 2 Q-Fan 2 ASUS Heat-pipe thermal solution Testy / recenzje / przydatne linki: http://www.hexus.net/content/item.php?item=6635 (Recenzja) http://www.xtremesystems.org/forums/showthread.php?t=115842 (Ogólnie o płycie) Bios 209 - dodaje zmianę mnożnika i kilka ustawień timingów (under construction) @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ Zapraszam do dyskusji. Mamy już obecnie kilku posiadaczy tych płyt na forum, kilku kolejnych przybędzie wkrótce, więc warto wymienić się spostrzeżeniami i pochwalić osiągami. Pierwszy post będzie stopniowo uzupelniany o co ważniejsze informacje oraz linki. Pozdr. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ Edytowane 24 Października 2006 przez LordFury Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) Uwagi cierpiacego na brak czasu usera tej plytki ;) Po instalacji scythe ninja pierwszy z zlotych slotow na ram jes wylaczony z uzytku, po instalacji coolera strasznie utrudniony jest dostep do wtyczki zasilajacej 8pin. Jezeli dodatkowo posiadacie Tagana musicie troszke przyciac plastikowa wtyczke. Chipset strasznie sie grzeje (bez O/C procka), wrecz parzy, a w obudowie mam b.dobry przeplyw powietrza. Na testy O/C plytki narazie brak czasu :/ Edytowane 18 Września 2006 przez Kas Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Raptor Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 czekam na więcej info :) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Sulaco Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 Po instalacji scythe ninja pierwszy z zlotych slotow na ram jes wylaczony z uzytku, po instalacji coolera strasznie utrudniony jest dostep do wtyczki zasilajacej 8pin. Jezeli dodatkowo posiadacie Tagana musicie troszke przyciac plastikowa wtyczke.daj jakies fotki bo chyba nie o tej plycie piszesz ;) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 krotki test Asus P5W64 WS Professional: osiagnal fsb 460 z E6300 i LLK6400, ktorych cos mobo nie polubilo, bo memki musialy isc na 3:2 a na p5b chodzily do 500. screena dam pozniej, bo musze linka odszukac Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
LordFury Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) Od siebie dodam coś dziś wieczorem. Probuję się właśnie dodzwonić do kuriera, o której mniej więcej będzie, ale w GLS chyba słuchawki wcale nie odkładają i graniczy to z cudem. Zobaczymy... Z tego co widziałem do tej pory, najczęściej płyta kończy się w okolicach 450MHz przy normalnych mnożnikach (8x). Przy 6x oczywiście wyżej, nawet 500MHz się pojawiło kilka razy, ale to raczej mało przydatne ustawienia :D. Osobiście będę baaardzo zadowolony, jesli będę miał 450MHz 1:1 z ramem :wink:. A nawet jeśli ciut niżej, to też się specjalnie nie pogniewam, za takie pieniądze :lol2: BTW. Jeśli macie jakieś linki warte uwagi, to podeślijcie na PW - dodam do pierwszego posta. Edytowane 18 Września 2006 przez LordFury Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) daj jakies fotki bo chyba nie o tej plycie piszesz ;)Dam jutro obecnie mam neta tylko w pracy. A nawet jeśli ciut niżej, to też się specjalnie nie pogniewam, za takie pieniądze :lol2:To ile w koncu kosztuje P5W64 ?? Edytowane 18 Września 2006 przez Kas Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 To ile w koncu kosztuje P5W64 ?? ~700pln Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
LordFury Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 Tylko aktualnie wszędzie na stanie pusto i towar niedostepny :-| Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 Cos nie tak z ta cena pewnie ja za porownywalna P5WDG2 placilem o 300 zl wiecej... Przynajmniej tak moge sie pocieszac :P Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 http://www.rad-an.com.pl/allegro/oc/asus_p5w64_ws_pro.jpg mam jedna mobo dostepna od reki za 700, bo druga jest juz sprzedana ;] Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
yotomeczek Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 krotki test Asus P5W64 WS Professional: osiagnal fsb 460 z E6300 i LLK6400, ktorych cos mobo nie polubilo, bo memki musialy isc na 3:2 a na p5b chodzily do 500. screena dam pozniej, bo musze linka odszukac To zdaje się ten screen :D Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 To zdaje się ten screen :D http://www.rad-an.com.pl/allegro/oc/asus_p5w64_ws_pro.jpg dokladnie, ten sam co post wyzej :P ;) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
LordFury Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) Już zacząlem wyzywać na kuriera, że sobie w organ męski leci, a tu niespodzianka - o dziwo przyjechał przed chwilą. Najwyraźniej trochę się nasze pojęcie "dnia roboczego" różniło :wink:. To teraz aparat w dłoń i sesja zdjęciowa... Testy niestety dopiero w weekend, gdy wrócę do siebie, gdzie czeka reszta gratów. Z ciekawości wpakuję też do niej D805. Nie spotkałem jeszcze takiej próby i oficjalnie płyta go nie obsługuje, ale skoro chodzą celiny na 533, to może też ruszy... Edytowane 18 Września 2006 przez LordFury Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Lizardus Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 http://www.forumdeluxx.de/forum/showthread.php?t=260043 9x451 no to chyba przyzwoicie jak na 975^^.... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
LordFury Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) Obiecana sesja zdjęciowa płyty. Pudło: Rock Solid, Heart Touching i miejmy nadzieję, że Ass Kicking też :lol2: Zestaw: Sporo tego: 7x SATA + zasilanie, 3 śledzie (USB, FireWire i COM), 2 taśmy, obszerna instrukcja ang., QuickStart (także polski), CD ze sterami/util., CD z oprogramowaniem multim., zaślepka, klocki do front-panelu i naklejka. No i sam główny bohater: Co cieszy, to takie drobne smaczki - idealny imho layout (nawet miejsca na dodatkowe wentyle są dokładnie rozplanowane), folia na poszczególnych radiatorkach itp. itd. Sorry za kiepską momentami jakość, ale gdy robiłem fotki, było już ciemno, a oświetlenie mam w pokoju marne... Edytowane 18 Września 2006 przez LordFury Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 ja moge powiedziec tylko, ze w srode mobo trafi w dobre rece ilicze, ze pokaze ta osoba na co mobo stac :) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Zulusman Napisano 18 Września 2006 Zgłoś Napisano 18 Września 2006 (edytowane) U mie max fsb przy x8 to zaledwie 445...po zmianie chlodzenia i 1.8 Vmch.. P5WDG2, E6400, Ninja.... Mostek chlodzony TT Extreme SilencerIII zdaje sie... + BGA ram freezer na mofy Aha: Aktualny wyglad mobo: nie modowana... Edytowane 18 Września 2006 przez Zulusman Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 Konflikt pierwszy slot ram vs ninja Niby drobnostka ale od plyty za taka kase wymaga sie perfekcji i lepszego rozplanowania elementow na PCB. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Zulusman Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 Ja mam obrocona ninje o 90 stopni prawda, nie mam budy, ale zawsze mozna dac wiatraka wyzej na mocowaniu, albo od strony chipsetu....wszystko da sie zrobic.... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 podnies wyzej wentyl na drucikach i nie bedzie problemu ;] Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
LordFury Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 Właśnie zauważyłem jeden drobiazg - nieco rozwinęli sekcje zasilania przy przejściu z p5wdg2 na p5w64. I nie chodzi mi o ten molex dla pci-e, ale o dodatkowy zestaw stabilizatorów na prawo od socketu, wzdłuż krawędzi płyty. dg2 jest juz tam "ucięta", a na w64 jest 5-6 dodatkowych fikuśników... Jak znam życie, to trzeba będzie o radiatorach pomysleć... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 podnies wyzej wentyl na drucikach i nie bedzie problemu ;]Nizej polozony wentyl owiewa heatshitowe chlodzenie na chipsecie, ktore i tak parzy. Zreszta zaraz niniji nie bedzie, az sie boje jakie problemy beda z infinity i tytulowa plyta ;) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 dojachala juz infinity?? wczesnie ;] Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
yotomeczek Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 Konflikt pierwszy slot ram vs ninja Niby drobnostka ale od plyty za taka kase wymaga sie perfekcji i lepszego rozplanowania elementow na PCB. i tu sie nie zgode ninja na wielu płytach ogranicza dostęp do ramów - i oskarżanie prod mobo to troche nie tak ... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 dojachala juz infinity?? wczesnie ;]A nie wiem nie widzisz ze pracuje :wink: A w dwoch miejscach na raz nie mozna byc B-) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Niemiec Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 (edytowane) A nie wiem nie widzisz ze pracuje :wink: A w dwoch miejscach na raz nie mozna byc B-) nie patrzylem czy pracujesz, bo jestem w pracy :lol: Edytowane 19 Września 2006 przez Niemiec Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kas Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 (edytowane) i tu sie nie zgode ninja na wielu płytach ogranicza dostęp do ramów - i oskarżanie prod mobo to troche nie tak ...Co nie zmienia faktu ze topowe plytki moglyby byc bardziej przemyslane. EDIT: Skasowane na prozbe pewnej ehmm pewnego pana ;) Edytowane 19 Września 2006 przez Kas Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Zulusman Napisano 19 Września 2006 Zgłoś Napisano 19 Września 2006 Nie wyobrazamsobie plyty ktora bedize pasowala do wszystkich wymyslnych mozliwych typow chlodzenia...bo to NIEMOZLIWE !!!!! wez popracuj nad swoim chlodzeniem a przestan jeczec nad plyta... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
max340 Napisano 20 Września 2006 Zgłoś Napisano 20 Września 2006 Płyte Asus P5W64 WS Pro, 975X, DualDDR2-800, SATA2, RAID, FW, 2xGBLAN, 4xPCI-E, ATX, CrossFire, Core można juz dostać w sklepach za 650 zł nawet trochę taniej a Asus P5B Deluxe to gdzieś wydatek 670 zł tylko chyba pod procka e6300 jest nadal lepsza P5B delux jak sadzicie kurde dziwne to jest płyta nowsza cenowo tańsza już <_< i pytanie takie do posiadaczy Asus P5W64 WS Pro, 975X osiągnie bez problemu 430 fsb hm? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
