Mardok 114 Report post Posted February 1, 2007 (edited) Abit AB9 QuadGT Bios: » Naciśnij aby pokazać/ukryć tekst oznaczony jako spoiler « - "Bios" BIOS ID:10 1. First release. 2. BIOS compiled date: 12/11/2006 BIOS ID:11 1. Enhanced overclocking ability. 2. Modify the Voltage adjusting function. 3. Fixed an issue that the system hangs during Vista installation, when using a Kentsfield CPU. 4. Fixed an issue where the system sometimes hangs on POST code 2A. 5. Fixed the JMB363 performance issue. 6. JMB363 now works as intended when enabling ICH8R RAID ROM. 7. The "EIST adjusting" function now works as intended. 8. BIOS compiled date: 3/27/2007 BIOS ID:13 1. Fixed the onboard Ethernet may disappeared after running mem86. 2. BIOS compiled date: 04/18/2007 BIOS ID:14 1. Support FSB1333 CPUs. 2. BIOS compiled date: 06/21/2007 BIOS ID:15 1. The ICH8R AHCI function now works as intended. 2. BIOS compiled date: 07/18/2007 BIOS ID:16 1. Support the pin definition of Front Audio adjusting function. 2. Enhanced the IEEE1394 performance. 3. BIOS compiled date: 08/16/2007 BIOS ID:17 1. Fixed the Wake Up by WAKE# of PCIe function abnormality. 2. Support FSB1333 CPU. 3. Fixed CPU multiplier setup abnormality. 4. Fixed AHCI function abnormality. 5. Fixed 45nm CPU compatibility and support CPU half multiplier. 6. Enhanced IEEE 1394 performance. 7. Fixed CPU multiplier abnormality when S3 return. 8. BIOS compiled date: 05/23/2008. Oficjalne FTP dla Abit AB9 QuadGT : Download ! Zestaw biosów dla Abit AB9 QuadGT : Download ! Specyfikacja: » Naciśnij aby pokazać/ukryć tekst oznaczony jako spoiler « - "Specyfikacja" CPU » Support Intel Core 2 Duo / Quad processors with1066/800MHz FSB » Support Intel Core 2 Quad/Duo(Extreme Edition) & Pentium, Dual Core & Pentium, Extreme Edition & Pentium, D & Pentium 4 Processors » Digital PWM Designation provide high quality and efficient power Chipset » Intel P965 / ICH8R Chipset Memory » 4 X 240-pin DIMM sockets support max. memory capacity 8GB » Supports Dual channel DDR2 800/667/533 Un-buffered Non-ECC memory LAN » On board PCI Gigabit LAN controller supports 10/100/1000M Ethernet Audio » On board 7.1 CH HD Audio CODEC Supports auto jack sensing and optical S/PDIF In/Out » HDMI ready header (SPDIF header) Expansion Slots » 1 x PCI-E X16, 1 x PCI-E X16 (x4 bandwidth), 1 x PCI-E X1, 2 x PCI Internal I/O » 1 x Floppy Port supports up to 2.88 MB » 1 x ATA 100/66/33 IDE connector » 7 x SATA 3Gb/s connector » 1 x IEEE1394, 3 x USB header (support 6 ports) » 1 x FP-Audio Back Panel I/O » 1 x PS/2 Keyboard, 1 x PS/2 Mouse » ABIT Silent OTESTM » 1 x S/P DIF In, 1 x S/P DIF Out » 1 x eSATA » 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround) » 4 x USB 2.0, 1 x RJ-45 LAN connector, 1 x 1394 » Clear CMOS Switch Serial ATA » 6 x SATA 3Gb/s offer by Intel ICH8R support Intel Matrix Storage Tech(AHCI & RAID0/1/5/10) » 2 x SATA 3Gb/s offer by JMicron JMB363 support up to 0,1,JBOD RAID function IEEE1394 Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate ABIT Engineered » ABIT uGuruTM Technology » ABIT Silent OTESTM Technology » 100% Low ESR and high ripple conductive polymer aluminum solid capacitor » 100% Japanese Capacitor » EZ for CCMOS » On board LED Lighting Form Factor » ATX form factor 305 x 245mm » PCB Color: Blue RoHS » 100% lead-free process and RoHS Compliancy Accessory » Driver CD x1 » English Manual x1, Quick Installation Guide x1 » IEEE1394+USB2.0Bracket cable x 1, IDE cable x1, FDD cable x1, SATA cable x7 FAQ: » Naciśnij aby pokazać/ukryć tekst oznaczony jako spoiler « - "FAQ" Q: Czy ten Abit posiada profile z ustawieniami biosu tak jak na np. DFI ? A: Tak, używa się ich w następujący sposób aby zapisać profil w głównym menu biosu wciska się F6 a aby wyczytać F7, łącznie mamy do dyspozycji 5 profili które powinny w zupełności wystarczyć. Q: Czy da się wyłączyć te niebieskie diody na mobo ? A: Tak, opcja sterująca diodami znajduje się w biosie w zakładce uGuru Utility > Abit EQ > LED Effect Control i tu ustawiamy opcje All Off w tym momencie nie będzie już nic nam świecić ;) Q: Jak mogę zabootować z PenDrive ? A: Należy podłączyć PenDrive z plikami bootującymi do komputera włączyć komputer przejść do biosu a następnie w zakładce Advanced BIOS Features > Hard Disk Boot Priority za pomocą klawiszy PU/PD przesunąć nasz napęd na pierwszą pozycje, następnie zapisać zmiany i gotowe. Q: Mam nagrywarkę DVD i nie mogę z niej zainstalować systemu, dlaczego ? A: Należy w Biosie w zakładce Advanced BIOS Features > First Boot Device wybrać swój napęd po nazwie zazwyczaj jest to przed ostatnia opcja w tym menu. Q: Nie działa mi klawiatura/mysz na USB w biosie i/lub podczas instalacji systemu. A: Błąd został poprawiony w nowszych biosach od wersji B6R w górę, jak nie masz jak zmienić biosu w tym momencie będzie trzeba załatwić klawiaturę a PS/2 i na niej dokończyć proces instalacji. Q: Dlaczego nie mogę uruchomić macierzy RAID ? A: Na starszych biosach tej płyty występuje drobny feler powodujący lagi w pracy kontrolera RAID. Wgrywając najnowszy BIOS pozbywamy sie tego problemu i wszystko działa poprawnie. Q: Dlaczego używając kontrolera RAID nie mogę zbootowac z płyty DVD/CD? A: Oryginalnie wgrany bios posiada wadę, która uniemożliwia jednoczesne działanie kontrolera RAID oraz kontrolera JMicron, do którego masz podłączony DVD/CD - ROM. Rozwiązaniem jest wgranie nowego BIOS`u. Q: Jak pozbyć się "skaczącego" mnożnika pomiędzy IDLE a Stresem ? A: Aby pozbyć się tej opcji oszczędzania energii trzeba w biosie wyłączyć opcje odpowiedzialną za SpeedStep oraz C1E w tym celu przechodzimy do zakładki Advanced BIOS Features > CPU Feature a następnie znajdujące się tam opcje ustawiamy zgodnie ze schematem: Thermal Control (Enabled/Disabled) Limit CPUID MaxVal (Disabled) C1E Function (Disabled) Execute Disabled Bit (Enabled) Virtualization Technology (Enabled) EIST Functiont (Disabled) Ustawienie opcji Thermal Control to już sprawa indywidualna i zależna od tego jak computer zachowuje się po jej uaktywnieniu, osobiście zlecam zostawić na Enabled. Q: Zainstalowałem wszystkie sterownik a mimo to mam jedno nieznane urządzenie w menadżerze urządzeń, co to jest ? A: Jest to układ uGuru, aby zainstalować do niego sterowniki należy zainstalować aplikacje Abit uGuru. Linka do najnowszej wersji tej że aplikacji znajduje się w dziale download. Download: » Naciśnij aby pokazać/ukryć tekst oznaczony jako spoiler « - "Download" Przydatne program: CPU-Z – Program z informacjami na temat CPU/Ram/Mobo CoreTemp – Program monitorujący temperaturę każdego z rdzeni MemSet – Program do zmiany timingów pod Windowsem Orthos – Program do sprawdzania stabilności każdego z rdzeni Super PI – Wszystkim znany benchmark Programy do Flash'owania: WinFlash v1.90 (98/2000/XP/2003) AwdFlash v8.67 Manual: Manual AB9 QuadGT ENG v2.0 (2007-04-27) Sterowniki: Intel® Matrix Storage Manager v7.8.0.1012 Driver for All Windows (2007-12-15) INTEL Chipset Driver v8.3.1.1009 for 2000/XP/2003/64bit (2007-09-24) Intel ICH7R/8R Raid Installation Disk V1.03 for 2000/XP/2003/64bit JMicron Installation Disk V1.03 for 2000/XP/2003/64bit (2007-09-02) JMicron SATA Driver v1.17.32 for 2000/XP/2003/64bit (2008-03-04) Realtek 8110SC Gigabit Lan v5.673.1116 Driver for Win9x/Me/2000/XP/2003 (2007-11-21) Realtek 8110SC Gigabit Lan v6.200.1219 Driver for Vista 32bit/Vista 64bit (2007-12-20) Realtek High Audio Definition R190 Driver for 2000/XP/2003/64bit (2007-03-31) Realtek High Audio Definition R190 Driver for Vista 32bit/Vista 64bit (2007-03-31) Sil3132 RAID Installation Disk V1.01 for Win2000/XP/2003/64bit Sil3132 RAID Installation Disk V1.02 for 64bit Abit AirPace Wi-Fi Card Driver V1.0.116.20 for XP / 2003 / 64bit Abit AirPace Wi-Fi Card Driver V1.0.116.20 for Vista 32bit / Vista 64bit Narzędzia: Abit uGuru v3.107 for 2000/XP/2003/Vista/64bit (2007-12-10) Komendy Postu: » Naciśnij aby pokazać/ukryć tekst oznaczony jako spoiler « - "Komendy Post" Sekwencja Power ON: 8.1. : Start sekwencji Power ON 8.2. : Włączenie zasilacza ATX 8.3. : Zasilacz ATX gotowy 8.4. : Gotowe napięcie DDR 8.5. : Ustawianie PWM dla CPU VCore 8.6. : Potwierdzenie PWM dla CPU VCore 8.7. : Sprawdzenie napięcia VCore 8.8. : Gotowe napięcie CPU VCore 8.9. : Uruchomienie Clock Generator IC 8.A. : Gotowe napięcie North Bridge Chipset 8.B. : Gotowe napięcie PCI-E 8.C. : Gotowe napięcie 3VDUAL 8.D. : Gotowe napięcie VDDA 2.5V 8.D. : Gotowe napięcie GMCHVTT 8.E. : Sprawdzanie obrotów CPU Fan 8.F. : Potwierdzenie iż wszystkie napięcia są gotowe 9.0. : Zakończony proces uGURU, BOOT’owanie przejmuje AwardBIOS Sekwencja Power OFF: 9.1. : Start sekwencji Power OFF 9.2. : De-Assert All Power 9.3. : De-Assert Power On 9.4. : De-Assert LDT Bus Power 9.5. : De-Assert PWM for CPU Core Voltage 9.6. : De-Assert CPU Core Voltage 9.7. : Sprawdzenie napięcia VCore 9.8. : Wyłączenie zasilacza ATX 9.9. : Zakończenie sekwencji Power OFF Inne : C.C. : Kasowanie biosu za pomocą EZ-CMOS1 F.0. : Przycisk Reset F.1. : Programowy Restart F.2. : Czas sekwencji Power On upłynął F.3. : Czas sekwencji Power Off upłynął Mody i Punkty Odczytu Napięć » Naciśnij aby pokazać/ukryć tekst oznaczony jako spoiler « - "Mody i Odczyty" Read Point: VCore Read Point VDimm DDR2 Read Point FVS Read Point MCH and VTT Read Point NB Read Point NB I/O Read Point SB Read Point Mod's: VDroop Mod VCore Mod VDimm DDR2 Mod MCH Mod ICH and VTT Mod Podziękowania za pomoc dla : Zulusman Last UpDate : 24 czerwiec 2008 Edited June 24, 2008 by Mardok Quote Share this post Link to post Share on other sites
rork 0 Report post Posted February 1, 2007 Użytkownikiem nie jestem :) ale znalazłem na AnandTech krótką recenzję. Quote Share this post Link to post Share on other sites
hesus 0 Report post Posted February 1, 2007 jak narazie ciężko płytke dostać, w ofercie widziałem ją jedynie w apollo.pl, 760zł, chociaż nie mają jej obecnie na stanie. zapowiada sie całkiem interesująco, więc trzeba poczekać chyba az bedzie bardziej dostępna. Quote Share this post Link to post Share on other sites
piterq1991 0 Report post Posted February 1, 2007 Tutaj też już jest, tyle ze drozej Quote Share this post Link to post Share on other sites
Bartolomius 35 Report post Posted February 18, 2007 Także Komputronik wrzucił ją do cennika, choć na razie nie jest dostępna. I jeszcze opis na forum.hexus.net. Quote Share this post Link to post Share on other sites
Hipo 0 Report post Posted February 18, 2007 (edited) A moze ktoś coś wie o słabszym bracie IB9 ? bo w zasadzie całkiem podobne są Edited February 18, 2007 by Hipo Quote Share this post Link to post Share on other sites
ent 2 Report post Posted February 18, 2007 IB9 dobija z tego so slyszalem do 400 z lekka gorka (410), reszta w porzadku, ale wybitmy ocer to z niej nie jest. Quote Share this post Link to post Share on other sites
Bartolomius 35 Report post Posted February 18, 2007 A moze ktoś coś wie o słabszym bracie IB9 ? bo w zasadzie całkiem podobne sąTeż jestem ciekaw, dlatego założyłem temat - może będzie z tego przyzwoita płytka. Quote Share this post Link to post Share on other sites
miki 0 Report post Posted February 19, 2007 Witam Wczoraj właśnie zakupiłem tego Abita, w środe powinna do mnie trafić, już sie nie mogę doczekać stabilnej pracy na tym imo. Jak przyjdzie porobie pare zdjęć oraz wyprobuje jej możliwości wstępne. pzdr Quote Share this post Link to post Share on other sites
Michaelius 161 Report post Posted February 19, 2007 W sumie to nie bardzo widze sens kupowania tego mobo za 750 zeta. W podobnej cenie mozna miec juz jakiegos full wypasionego asusa na 975 czy 680i. Jedyna zaleta to fsb 500 na dobrym strapie , ale poza kilkoma osobami pragnacymi pobic rekord to raczej przerost formy nad trescia. IMHO kolo 600 zeta warto byloby ja kupic. Quote Share this post Link to post Share on other sites
Guest Report post Posted February 19, 2007 ale poza kilkoma osobami pragnacymi pobic rekordWłaśnie dlatego warto :) Quote Share this post Link to post Share on other sites
Banzai 8 Report post Posted February 19, 2007 spoko Abit QuadGT kosztuje 660zł :D więc nie tak źle, wydaje mi sie ze to lepsza płyta od grzejacej sie P5N32e Sli, do tego jakis 4300 i mozna krecic... Quote Share this post Link to post Share on other sites
miki 0 Report post Posted February 20, 2007 spoko Abit QuadGT kosztuje 660zł :D więc nie tak źle, wydaje mi sie ze to lepsza płyta od grzejacej sie P5N32e Sli, do tego jakis 4300 i mozna krecic...gdzie ta płyta jest za 660zł?? Quote Share this post Link to post Share on other sites
Madness 0 Report post Posted February 20, 2007 660zł ale chyba netto ;) Quote Share this post Link to post Share on other sites
Michaelius 161 Report post Posted February 20, 2007 (edited) A nie jednak brutto ;) Ale to chyba blad w cenniku http://www.pcprojekt.pl/?/p__katalog_produ...QuadGT_Lga775_/ A szkoda bo to by bylo sensowna cena dla niej. Edited February 20, 2007 by Michaelius Quote Share this post Link to post Share on other sites
miki 0 Report post Posted February 20, 2007 A nie jednak brutto ;) Ale to chyba blad w cenniku http://www.pcprojekt.pl/?/p__katalog_produ...QuadGT_Lga775_/ A szkoda bo to by bylo sensowna cena dla niej. tylko czemu gw, jest na 24m ??podobno abit dal na nia 36??może dlatego taka cena??ja kupiłem ja wraz z kurierem za 715zł, jutro ma być Quote Share this post Link to post Share on other sites
05_03_1992 0 Report post Posted February 20, 2007 czekamy na relacje z ocowania ;] z wyglądu jest to pierwszy abit od czasow nf7 który przyciąga mój wzrok ;) Quote Share this post Link to post Share on other sites
Banzai 8 Report post Posted February 20, 2007 nie wiem czy zauwazyliscie ale wszedzie jest 24 miesiace gwarancji oprocz Komputronika, przynajmniej do tej pory, bo nie wszedzie plyta jeszcze jest. Quote Share this post Link to post Share on other sites
miki 0 Report post Posted February 20, 2007 nie wiem czy zauwazyliscie ale wszedzie jest 24 miesiace gwarancji oprocz Komputronika, przynajmniej do tej pory, bo nie wszedzie plyta jeszcze jest. nie tylko komputronik bo jest tez tutaj http://www.bachcomp.pl/ na 36 m. Quote Share this post Link to post Share on other sites
Bartolomius 35 Report post Posted February 20, 2007 A nie jednak brutto ;) Ale to chyba blad w cenniku http://www.pcprojekt.pl/?/p__katalog_produ...QuadGT_Lga775_/ A szkoda bo to by bylo sensowna cena dla niej. PC Projekt - i wszystko jasne... Kumpel ściągał ostatnio kilka płytek z hurtowni i tylko Abit miał 24 miesiące gwarancji, pozostałe (Asus, Gb) 36. Quote Share this post Link to post Share on other sites
Monaro 5 Report post Posted February 20, 2007 Kumpell ściągał ostatnio kilka płytek z hurtowni i tylko Abit miał 24 miesiące gwarancji, pozostałe (Asus, Gb) 36. Abit Polska oglosil, ze od wrzesnia 2006 roku okres gwarancji na plyty wynosi w Polsce 3 lata. Gdy jest inaczej to juz kwestia woli sprzedawcy....Pisalem kiedys w tej sprawie do MSI Polska, gdy dostalem gware tylko 2 lata, to odpisali mi, ze oni nic nie moga zrobic i skoro dostalem 2 lata to tyle mam a nie 3....w tym kraju wszystko po chinsku jest....Wracajac do Abita to dobra firma, ale u nas malo kto sprzedaje ja, bo tu cytat "....sa duze problemy z reklamacja". Pozostawiam bez komentarza... Quote Share this post Link to post Share on other sites
Bartolomius 35 Report post Posted February 20, 2007 Wracajac do Abita to dobra firma, ale u nas malo kto sprzedaje ja, bo tu cytat "....sa duze problemy z reklamacja". Pozostawiam bez komentarza...Do tego z pewnością dochodzi słaba opinia, na jaką zapracowały sobie ostatnie modele tej firmy (nie mówię o serii AW9D)... Quote Share this post Link to post Share on other sites
hesus 0 Report post Posted February 21, 2007 (edited) no ja dzisiaj odebrałem tę płytke. pierwsze wrażenie: total wypas :D wszystko ładnie zaskoczyło, system bez niczego wystartował za 1 razem. na chwile obecną tylko jedna rzecz by mnie cieszyła do tego: coś ala asus connector, bo podpinanie tych pojedynczych kabelkow jest wysoce frustrujące:) no a kolo soboty myśle wrzuce jakieś szersze wrażenia (OC tylko bedzie mi kuleć ze wzgledu na ramy :( ) Edited February 21, 2007 by hesus Quote Share this post Link to post Share on other sites
Hipo 0 Report post Posted February 26, 2007 Panowie i co taka cisza nastała ? nikt się nie pochwali jak sprzęt smiga ? Quote Share this post Link to post Share on other sites
miki 0 Report post Posted February 27, 2007 Witam Wczoraj składałem kompa z płyta jak w temacie, jednak po właczeniu kompa nawet do biosu nie dochodzi, jeden długi sygnał i 2 krutkie, na wyswietlaczu na płycie nr błędu okazuje 87, według instrukcji błąd brzmi : NET PC: Build SYSID Structure nie wiem o co chodzi, mam kosci jak w temacie, zmienialem rózne kombinacje, 4kosci-nic, 2 kosci-nic, 1 kość-nic, zmiana w bankach też nic, clear cmos zworka nic, przelacznikiem w tylnym panelu-nic, wyciagana bateria z plyty-nic, wszystko jest dobrze podłączone. pzdr :mur: :mur: :mur: Quote Share this post Link to post Share on other sites
Monaro 5 Report post Posted February 27, 2007 Wczoraj składałem kompa z płyta jak w temacie, jednak po właczeniu kompa nawet do biosu nie dochodzi, jeden długi sygnał i 2 krutkie, na wyswietlaczu na płycie nr błędu okazuje 87, według instrukcji błąd brzmi : NET PC: Build SYSID Structure nie wiem o co chodzi... Cytat z pewnej strony -"Fixed this by pluging in second 12v power cable from psu into mobo". Quote Share this post Link to post Share on other sites
hesus 0 Report post Posted February 27, 2007 ja mam takie pytanko. tak sie bawie w kręcenie troszke i zastanawia mnie odczyt napięcia przez cpu-z, core temp i inne programy. jakich wartości bym w biosie nie ustawił, to cpu-z zawsze pokazuje 1.213V, a coretemp standardowe 1.325. ( a obecnie 1.345 chyba mam ustawione) moge przyjąć ze ustawione przeze mnie wartości są poprawne, a to programy te mają problem z odczytem, czy coś moze przeoczyłem?? i druga sprawa: wiem ze na boxowym coolerze nie poszaleje, ale do jakich max temp moge dopuszczać??:] 65C to chyba jeszcze nie jest tragedia w stresie?? :D Quote Share this post Link to post Share on other sites
miki 0 Report post Posted February 28, 2007 Witam Jednak źle odczytałem błąd z książki nie zauważyłem jeszcze jednej strony z błędami, bo na wyświetlaczu mam dokładnie 8.7. czyli zbyt niskie napięcie na procku i o ten błąd chodzi tylko nie wiem w jaki sposob mam zmienic te V jesli nie moge w zaden sposob dostac sie do biosu?? :mur: :mur: :mur: Quote Share this post Link to post Share on other sites
Monaro 5 Report post Posted February 28, 2007 Jednak źle odczytałem błąd z książki nie zauważyłem jeszcze jednej strony z błędami, bo na wyświetlaczu mam dokładnie 8.7. czyli zbyt niskie napięcie na procku i o ten błąd chodzi tylko nie wiem w jaki sposob mam zmienic te V jesli nie moge w zaden sposob dostac sie do biosu?? :mur: :mur: :mur: Przyczyna- 12V 4 pin plug disconnected or power supply damage Co zrobic- Check 4 pin power plug or replace power supply http://www.abit-usa.com/faq/common_ques_pop3.php Nie wiem czy to pomoze, bo nie wierze zebys nie podlaczyl.... Jesli to nie pomoze to sprawdz na innym markowym zasilaczu. Quote Share this post Link to post Share on other sites
Firekage 2 Report post Posted February 28, 2007 Nie wiem czy to pomoze, bo nie wierze zebys nie podlaczyl.... Jesli to nie pomoze to sprawdz na innym markowym zasilaczu.Moze to durne ale kolega ma Tagana. Spotkalem sie na forach wlasnie z tym , ze Tagany nie chcialy na czesci plyt odpalac kompy. Wciskali na szybko jakies wynalazki i te szly. Moze to wina tego zasilacza. Wiem , ze to brzmi idiotycznie ale albo na IDG albo na Labie o tym czytalem. Quote Share this post Link to post Share on other sites
