Shake Napisano 11 Stycznia 2007 Zgłoś Napisano 11 Stycznia 2007 (edytowane) Lista zmian: http://www2.ati.com/relnotes/catalyst_71_release_notes.html Najważniejsze zmiany: New Features This release of the ATI Catalyst™ Software Suite includes Crossfire™ enhancements that enable the Alternate Frame Rendering (AFR) Crossfire rendering mode by default so that users will see significant performance benefits across all AFR compatible applications immediately (including newly released applications, so users do not have to wait for a future ATI Catalyst™ release to add Crossfire™ support for newly released titles). Future ATI Catalyst™ releases will add further Crossfire™ performance gains once new applications have been profiled specifically for Crossfire™. Download: http://ati.amd.com/support/driver.html Wersja z Control Panel by NGOHQ: http://www.ngohq.com/home.php?page=Files&a...p;dwn_cat_id=18 Omega Drivers 3.8.330 (Catalyst 7.1) - http://www.ngohq.com/home.php?page=Files&a...p;dwn_cat_id=14 Zmiany: What's New in Omega Drivers? v3.8.330 [*] Based on the Catalyst 7.1 Official drivers. [+] Added support for some new chipsets. [*] Clarified some options in the installer. Known Issues: 1) From Cat 6.6 and up ATI removed driver-level support for the following series of cards (including Mobility models): 7000, 7200, 7500, 8500, 9000, 9200, 9250. Since the Omega Drivers use ATI drivers as a base, that means they will also not include support for these chipsets, they may install, but the PC may give you a BSOD or a black screen upon boot. People that need to install Omega Drivers on these cards should use v3.8.252 or older, you can get these on the Archive section of my site. Edytowane 14 Stycznia 2007 przez Shake Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Adyan Napisano 11 Stycznia 2007 Zgłoś Napisano 11 Stycznia 2007 Próbował ktoś te stery na Radeonie 9800Pro. Są jakieś zmiany wydajnościowe na lepsze czy nic nie wnoszą dla tej karty ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Bemx2k Napisano 11 Stycznia 2007 Zgłoś Napisano 11 Stycznia 2007 Zainstalowalem , zero problemow minimalna poprawa framerate 2-3% w demku ATI Assassin i TOY Shop oraz demku : DX9 Real-Time High-Dynamic Range Image-Based Lighting widac cos poprawili w shaderach w grach narazie nie bylo czasu przetestowac Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Gregor1230 Napisano 17 Stycznia 2007 Zgłoś Napisano 17 Stycznia 2007 Zaobserwowałem mniejsze OC na 7,1 , ale za to więcej fpsów np w csiku. Tak jakby sterowniki bardziej obciążały gpu i trzeba troszkę zniżyc takty. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Jabar83 Napisano 17 Stycznia 2007 Zgłoś Napisano 17 Stycznia 2007 Zaobserwowałem mniejsze OC na 7,1 , ale za to więcej fpsów np w csiku. Tak jakby sterowniki bardziej obciążały gpu i trzeba troszkę zniżyc takty. Słuszna uwaga. Widać to w grach że proc jest mniej obciążony ,a bardziej GPU co jest jak najbardziej OK ;) Przyrost w CS: 131,6 (6.12), 135.2 więc jednak przyrost jest. Dalej nie testowałem ;) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Sysak Napisano 18 Stycznia 2007 Zgłoś Napisano 18 Stycznia 2007 Na tych omegach Rayman Raving Rabbids mi nie działał. Mruga czrny ekran i gra się nie włącza. Przy XG WarCat 6.11 problem nie występuje. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Astro Napisano 18 Stycznia 2007 Zgłoś Napisano 18 Stycznia 2007 Mialem male problemy z instalka , ale juz jest git , duzej poprawy w wydajnosci nie zauwazylem ,aczkolwiek niewielka jest. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 19 Stycznia 2007 Zgłoś Napisano 19 Stycznia 2007 Te sterwniki to dno. Wynik w 3dmarku 06 spadl z 4,5 tys. do 4tys. :blink: Karta nie krecona. Chyba sobie jaj robia. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kicha Napisano 19 Stycznia 2007 Zgłoś Napisano 19 Stycznia 2007 Hheheh gratulacje dla tego pana co gra w 3dsmarka :D. Powiem ci tak sa sterowniki na ktorych w 3dmarku uzyskasz masakryczne wyniki a w grach bedzie :mur: , a tez sa takie w ktorych jest odwrotnie. Wiec najpierw wez i odpal jakas gre i sprawdz ile masz FPS'ow czy mnie jczy wiecej a nie sugerujesz sie jakimis 3dsmarkami. Wiem co mowie bo kiedys gdy bylem glupi tez sie podniecalem 3dmarkami do czasu kiedy to wlasnie sie sam przekonalem na wlasnej skorze ,ze nie ma co sie sugerowac 3dmarkiem. Sterowniki sie testuje w grach a nie w tej aplikacji. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 19 Stycznia 2007 Zgłoś Napisano 19 Stycznia 2007 (edytowane) Wiesz co moze zle odczytalem( :blink: ), a moze to wina innego systemu(z sp2) badz jeszcze czegos? Jakby nie bylo w takim FEAR tak czy srak w tescie mam mniej fps'ow. ps. rowniez na smarki az tak nie patrze, ale takie roznice sa zawsze zastanawiajace. Edytowane 19 Stycznia 2007 przez luki2 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Zajdzik Napisano 20 Stycznia 2007 Zgłoś Napisano 20 Stycznia 2007 a mnie tam najlepiej się sprawuje właśnie 7.1 zarówno w grach jak i smarkach. teraz muszę tylko luknąć na te nowe omegi bo może one będą jeszcze leprze Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Kicha Napisano 20 Stycznia 2007 Zgłoś Napisano 20 Stycznia 2007 No to jesli masz mniej fps'ow luki2 to ZWRACAM CI HONOR buc moze u ciebie zle sie spisuja te stery. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Bemx2k Napisano 20 Stycznia 2007 Zgłoś Napisano 20 Stycznia 2007 Co do mozliwosci OC u mnie bez zmian , Ati Tray Tools i wszystko jak w podpisie moze wy krecicie swoje karty bez podniesienia napiecia ?? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
toman Napisano 20 Stycznia 2007 Zgłoś Napisano 20 Stycznia 2007 WarCat'y 7.1 :arrow: http://www.tweaksrus.com/index.php?option=...&Itemid=41/ Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
DrKleiner Napisano 20 Stycznia 2007 Zgłoś Napisano 20 Stycznia 2007 A jakie modowane sterowniki są najlepsze dla ATI? :) Próbował już ktoś te WarCat'y Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Jabar83 Napisano 20 Stycznia 2007 Zgłoś Napisano 20 Stycznia 2007 Do gier właśnie WarCat'y są dobre. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
kiltel Napisano 24 Stycznia 2007 Zgłoś Napisano 24 Stycznia 2007 (edytowane) Przed chwila testowałem te najnowsze OMEGI są normalnie rewelacyjne w 3dmarku03 na moim radku dają o 1000 pkt więcej. Teraz na defaultowych zegarach mój radeon9800 pro wyciaga w 3dmark03 - 7011 pkt :razz: 3dmark05 - 3120 pkt :razz: Zaznaczam na standardowych ustawieniach zeby nie było watpliwości. W grach te jest lepiej np. w Carbonie średnio o jakies 3- 4 fps wiecej. Edytowane 24 Stycznia 2007 przez kiltel Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 24 Stycznia 2007 Zgłoś Napisano 24 Stycznia 2007 (edytowane) Przed chwila testowałem te najnowsze OMEGI są normalnie rewelacyjne w 3dmarku03 na moim radku dają o 1000 pkt więcej. Teraz na defaultowych zegarach mój radeon9800 pro wyciaga w 3dmark03 - 7011 pkt :razz: 3dmark05 - 3120 pkt :razz: Zaznaczam na standardowych ustawieniach zeby nie było watpliwości. W grach te jest lepiej np. w Carbonie średnio o jakies 3- 4 fps wiecej. Jaasssssssssne :lol: Mi daj 3 miliony puntkow wiecej. Edytowane 24 Stycznia 2007 przez luki2 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Pawelek69 Napisano 24 Stycznia 2007 Zgłoś Napisano 24 Stycznia 2007 (edytowane) Przed chwila testowałem te najnowsze OMEGI są normalnie rewelacyjne w 3dmarku03 na moim radku dają o 1000 pkt więcej. Teraz na defaultowych zegarach mój radeon9800 pro wyciaga w 3dmark03 - 7011 pkt :razz: 3dmark05 - 3120 pkt :razz: Zaznaczam na standardowych ustawieniach zeby nie było watpliwości. W grach te jest lepiej np. w Carbonie średnio o jakies 3- 4 fps wiecej. POTWIERDZAM!!! Używam normalnych Catalystów. Też mam 9800 PRO i mam 500 punktów więcej w marku03 i około 100 w 05 niż na poprzednich wersjach! 3DMark01 - 12160 3DMark03 - 6124 3DMark05 - 2951 Edytowane 24 Stycznia 2007 przez Pawelek69 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Gość 7600gs Napisano 24 Stycznia 2007 Zgłoś Napisano 24 Stycznia 2007 Jaasssssssssne :lol: Mi daj 3 miliony puntkow wiecej. A uwierzył byś w 5800 smarków 03 i 2700 w 05 dla 9500pro ? To nie wierz :D poszukaj sobie orbów :mrgreen: Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 (edytowane) A uwierzył byś w 5800 smarków 03 i 2700 w 05 dla 9500pro ? To nie wierz :D poszukaj sobie orbów :mrgreen: Zaraz sprawdze, tylko jak chce widziec skok wydajnosci w grach, a nie w glupich smarkach. Masz 10% przyrost wydajnosci w grach?? A co do twoich punktow to pwnie, ze uwierzylbym, bo pewnie masz zmodowana wersje 9500pro. Edytowane 25 Stycznia 2007 przez luki2 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Gość 7600gs Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 Zaraz sprawdze, tylko jak chce widziec skok wydajnosci w grach, a nie w glupich smarkach. Masz 10% przyrost wydajnosci w grach?? A co do twoich punktow to pwnie, ze uwierzylbym, bo pewnie masz zmodowana wersje 9500pro. Obecnie gram tylko w TrueCombatElite (mod ET) dosyć wymagający - w newralgicznych miejscach minimalny fps z 30 na 40 (bylo niefajnie a jest prawie dobrze w 1024*768 max detale AF*16 - gra wtedy potrafi zjeść 1,2 GB ramu xD ). Myślę że to można nazwać skokiem :mrgreen: ET to silnik Quake 3 wiec Open GL w Direct 3d nie sprawdzalem - nie chce mi sie fira instalować (poza tym Combat'a przez przypadek skasowałem) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 Obecnie gram tylko w TrueCombatElite (mod ET) dosyć wymagający - w newralgicznych miejscach minimalny fps z 30 na 40 (bylo niefajnie a jest prawie dobrze w 1024*768 max detale AF*16 - gra wtedy potrafi zjeść 1,2 GB ramu xD ). Myślę że to można nazwać skokiem :mrgreen: ET to silnik Quake 3 wiec Open GL w Direct 3d nie sprawdzalem - nie chce mi sie fira instalować (poza tym Combat'a przez przypadek skasowałem) Spoko ja juz feara instaluje do tego nowe stery i zobaczymy jaki bedzie skok z oficjalnych 6.12. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Gość 7600gs Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 (edytowane) A co do twoich punktow to pwnie, ze uwierzylbym, bo pewnie masz zmodowana wersje 9500pro.Hehe nie zauważyłem od razu tego txt'u :] Jak niby miałbym zmodować 9500 pro ? To jest karta 8-potokowa i 128-bitowa i nic się w niej zmodować ani odblokować nie da - można jedynie zmienić chłodzenie i kręcić :] Edytowane 25 Stycznia 2007 przez 7600gs Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Jabar83 Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 Przed chwila testowałem te najnowsze OMEGI są normalnie rewelacyjne w 3dmarku03 na moim radku dają o 1000 pkt więcej. Teraz na defaultowych zegarach mój radeon9800 pro wyciaga w 3dmark03 - 7011 pkt :razz: 3dmark05 - 3120 pkt :razz: Zaznaczam na standardowych ustawieniach zeby nie było watpliwości. W grach te jest lepiej np. w Carbonie średnio o jakies 3- 4 fps wiecej. Hmm 1000 pkt w 2k3. Zaraz się przekonam. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 (edytowane) Hehe nie zauważyłem od razu tego txt'u :] Jak niby miałbym zmodować 9500 pro ? To jest karta 8-potokowa i 128-bitowa i nic się w niej zmodować ani odblokować nie da - można jedynie zmienić chłodzenie i kręcić :] Sluchaj nie wiem, ale nie wierze w takie cuda, a tak poza tym to sprawdzilem feara i przyrost jest zerowy Przeciez juz ludzie mieli kosmiczny wzrost wydajnosci na omegach sprzed roku, ale jak tego nigdy cos nie moglem uswiadczyc... :lol: Z logicznego punktu widzenia taki przyrost jest niemozliwymy, bo nagle wszytkie rekordy swiata musialyby sie pozmieniac :lol2: Oczywiscie nie twierdze, ze piszesz nie prawde, bo przyrost pewnie jest, ale tylko na tych slabych/starych kartach. A i tak nie uswidaczysz 10% przyrostu wydajnosc w grach... ps. zaraz puszczam smara 05 @Devil bedziesz mial taki przyrost, ze ze szczescia sie posikasz :wink: Edytowane 25 Stycznia 2007 przez luki2 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Gość 7600gs Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 feara czy test z feara ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
luki2 Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 feara czy test z feara ? Narazie test, bo reszty mi sie odechcialo, ale i tak bedzie to samo :-| Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
Jabar83 Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 Niestety ale muszę potwierdzić. 3Dmark03 i 05 wyniki są zbliżone. Wynik w CS:S też podobny. Różnica 2 FPS może . Także przyrost jest zerowy. Zostawiam jednak na razie OMEGI. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
kiltel Napisano 25 Stycznia 2007 Zgłoś Napisano 25 Stycznia 2007 (edytowane) Niestety ale muszę potwierdzić. 3Dmark03 i 05 wyniki są zbliżone. Wynik w CS:S też podobny. Różnica 2 FPS może . Także przyrost jest zerowy. Zostawiam jednak na razie OMEGI. Masz nowa karte to moze dlatego ale na starszych radeonach klasy 9500-9800 przyrost jest widoczny. Sam myślałem że spadne z krzesła jak zobaczyłem 7011 pkt w 3dmark03 na moim radku 9800pro zdziwienie było nie małe, żeby rozwiać watpliwości zapusciłem 3dmark05 i tu rowniez jest wzrost na ekranie pojawiło sie 3120 pkt. :-P Edytowane 25 Stycznia 2007 przez kiltel Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach More sharing options...
