srekal34 Posted April 21, 2015 Report post Posted April 21, 2015 Orientujecie się czy jak wezme save'y od kolegi to będą działać na moim koncie? Quote Share this post Link to post Share on other sites More sharing options...
kelcior Posted April 21, 2015 Report post Posted April 21, 2015 (edited) A Afterburnera to ja korzystam, ale w nim jakos inaczej to sie wyswietla :| No nic, dzieki. Przecie to trzeba sobie skonfigurowac, co ma byc na OSD w ustawieniach Afterburnera a kolor czcionka rozmiar pozycja itp w RTSS. Edited April 21, 2015 by kelcior 1 Quote Share this post Link to post Share on other sites More sharing options...
mmmaaarr Posted April 21, 2015 Report post Posted April 21, 2015 Jest jakiś sposób żeby mieć szybko zmiane "maska pojazdu w pierwszej osobie" nie wchodząc za każdym razem do opcji kamery? Quote Share this post Link to post Share on other sites More sharing options...
epoxer Posted April 21, 2015 Report post Posted April 21, 2015 Nowy patch przed chwilą wyszedł. Podobno przybyło parę klatek. GTAV PC Patch 335.1 Notes Players can no longer purchase more vehicles than their properties can store. Players can now launch a video card benchmark test from the main menu. Fixed an issue where facial features would not save correctly when transferring a character from Xbox 360 or PS3 and changing genders while editing the character's appearance. Fixed an issue where players could become stuck in the clouds when voting to quick restart the Humane Labs Heist. Fixed an issue where markers in the Rockstar Editor could not be deleted with the mouse. Fixed various audio recording issues with Rockstar Editor clips. Fixed an issue where the Yacht would not appear in some recorded Rockstar Editor clips. Fixed a rare issue where some Rockstar Editor clips could not be opened for editing. Fixed an issue where the GTAV Launcher would not display the correct amount of time remaining for file downloads. The Steam overlay has been moved to prevent it from covering up Launcher buttons. Fixed an issue where the game would not save your settings when restarting in some instances. Fixed a rare issue where the Steam version of the game would crash right after launching. Windows Media Player is no longer required to install GTAV. Instead, Windows Media Foundation will be required. Fixed an issue where the game would show the pause menu without player input. Fixed an issue where the max frame rate would be incorrectly low in rare cases. Quote Share this post Link to post Share on other sites More sharing options...
mmmaaarr Posted April 21, 2015 Report post Posted April 21, 2015 Widze, że nie tylko ja mam problem z takim ustrojstwem: ERR_GFX_D3D_INIT Wywala mi na pulpit czasami :-( Quote Share this post Link to post Share on other sites More sharing options...
grzechuk Posted April 22, 2015 Report post Posted April 22, 2015 pytanie, czy na złomie z sygnatury mi pójdzie Quote Share this post Link to post Share on other sites More sharing options...
KaszaWspraju Posted April 22, 2015 Report post Posted April 22, 2015 (edited) Fajny "heist" Prison Break, trzeba się wykazać w ostatniej misji. Zrobiliśmy też jeden "napad" od Trweora i dla samej finalnej scenki warto go zrobić, plus epicka akcja zaparkowania cysterny w ostatniej sekundzie. Nie wiem czemu voice czat mi szwankował po podłączeniu mikrofonu, nikogo nie słyszałem, więc jak coś nawaliłem to sorki. Edited April 22, 2015 by KaszaWspraju Quote Share this post Link to post Share on other sites More sharing options...
straszny4 Posted April 22, 2015 Report post Posted April 22, 2015 (edited) Widze, że nie tylko ja mam problem z takim ustrojstwem: ERR_GFX_D3D_INIT Wywala mi na pulpit czasami :-( Mam/miałem podobnie, do tego dochodził błąd ERR_GEN_ZLIB_2 - gra wywalała się po 10 - 20 minutach. Nie wiem czy próbowałeś tego sposobu, ale wczoraj trafiłem na stronę http://extreme.pcgameshardware.de/gta-grand-theft-auto/385030-gta-5-file-checker-v3-sha-1-pruefung.html . Pobierasz plik GTA5FileCheck_v3.zip - uruchamiasz w folderze z grą. Program sprawdza poprawność plików, u mnie znalazł dwa uszkodzone (x64f.rpf i x64q.rpf), pliki skasowałem (na wszelki wypadek zrobiłem też kopie). Po uruchomieniu gry Launcher pobrał te dwa pliki ponownie (około 5GB), dla sprawdzenia przeskanowałem pliki jeszcze raz, tym razem wynik bez błędu. Efekt jest taki że gra działała mi wczoraj ponad 1,5 godziny bez błędu, dzisiaj jeszcze potestuję, ale mam nadzieję ze problem rozwiązany. Edited April 22, 2015 by straszny4 Quote Share this post Link to post Share on other sites More sharing options...
jonathan Posted April 22, 2015 Report post Posted April 22, 2015 Fajny "heist" Prison Break, trzeba się wykazać w ostatniej misji. Zrobiliśmy też jeden "napad" od Trweora i dla samej finalnej scenki warto go zrobić, plus epicka akcja zaparkowania cysterny w ostatniej sekundzie. Nie wiem czemu voice czat mi szwankował po podłączeniu mikrofonu, nikogo nie słyszałem, więc jak coś nawaliłem to sorki. Jasiu niemowa ;] Moze dzisiaj cos kolo 22?? Quote Share this post Link to post Share on other sites More sharing options...
KaszaWspraju Posted April 22, 2015 Report post Posted April 22, 2015 (edited) O 22 idę spać, bo 3 dzień spania po 3h mnie wykończy, wstaję o 4 rano.... no max pogram do 23h. Opłaca się zainwestować w jakieś droższe mieszkanie, czy to tylko kosmetyka? Na razie czekam aż odblokują się jakieś posiadłości. Edited April 22, 2015 by KaszaWspraju Quote Share this post Link to post Share on other sites More sharing options...
zaodrze244 Posted April 22, 2015 Report post Posted April 22, 2015 (edited) Grand Theft Auto V PC Graphics & Performance Guide po południu u siebie ustawię tak te opcje: Anisotropic Filtering 16x Distance Scaling 100% lub 50% Extended Distance Scaling 50% Extended Shadow Distance 50% Grass Quality HIGH Reflection Quality VeryHIGH reszta na maxa z FXAA. Edited April 22, 2015 by zaodrze244 1 Quote Share this post Link to post Share on other sites More sharing options...
jonathan Posted April 22, 2015 Report post Posted April 22, 2015 O 22 idę spać, bo 3 dzień spania po 3h mnie wykończy, wstaję o 4 rano.... no max pogram do 23h. Opłaca się zainwestować w jakieś droższe mieszkanie, czy to tylko kosmetyka? Na razie czekam aż odblokują się jakiś posiadłości. Zalezy jakie masz teraz. W luksusowych masz pokoj w ktorym planuje sie operacje. A takowe mozna kupic za 200K czyli tyle co wczoraj zgarnelismy za napady Quote Share this post Link to post Share on other sites More sharing options...
epoxer Posted April 22, 2015 Report post Posted April 22, 2015 Grand Theft Auto V PC Graphics & Performance Guide Dobry poradnik, się zoptymalizowałem ... ustawienia jak poniżej, szybka jazda nocą przez miasto i po autostradzie i trzyma się 60FPS, raz spadło do 54FPS. Anti-aliasing: OFF Texture quality: Very High Shader quality: Very High Shadow quality: High Reflection quality: Very High Reflection MSAA: OFF Water quality: Very High Particles quality: Very High Grass quality: High Soft shadows options: softest Post FX options: Ultra Motion blur strength: 0 In-game depth of field effects: ON Anisotropic filtering: x16 Ambient occlusion: High Tesellation: Very High suwaki ludność, przechodnie, dystans: MAX opcje zaawansowane: rozszerzone skalowanie: około 25%, detail streaming ON, wszystkie opcje cieni wyłączone. Quote Share this post Link to post Share on other sites More sharing options...
leven Posted April 22, 2015 Report post Posted April 22, 2015 Epoxer jak u Ciebie wygląda obciążenie CPU w czasie gry ? Daj parę fotek z monitoringiem Afterburnera OSD. Quote Share this post Link to post Share on other sites More sharing options...
Kilokush Posted April 22, 2015 Report post Posted April 22, 2015 Nvidia Inspector spróbuj. Quote Share this post Link to post Share on other sites More sharing options...
stranded Posted April 22, 2015 Report post Posted April 22, 2015 pytanie, czy na złomie z sygnatury mi pójdzie myśle, że spokojnie, na moim Lenovo z podpisu da się nawet grać, kwestia jaką masz tam rozdziałkę? u mnie na 1366x768 jest nawet grywalnie z geforcem 630 i i5 Quote Share this post Link to post Share on other sites More sharing options...
Havoc Posted April 22, 2015 Report post Posted April 22, 2015 Podczas zmiany otoczenia (wejście do apartamentu w ONLINE, wejście do misji, wyścigu itp.) gra sama zmienia rozdzielczość z 1440p (DSR) do 1080p natywnej dla monitora. Porady? #edit: pomogło dodanie commandline + usunięcie limitera na VRAM + nie minimalizowanie gry. Rozwiniesz temat? To tak jak w GTA IV? Jaki plik, jakie komendy ustawić? U mnie cały czas startuje w Windows Mode, ponoć wina jakichś innych programów. Może da się wymusić żeby nie klikać stale alt+enter? Quote Share this post Link to post Share on other sites More sharing options...
mmmaaarr Posted April 22, 2015 Report post Posted April 22, 2015 Mam/miałem podobnie, do tego dochodził błąd ERR_GEN_ZLIB_2 - gra wywalała się po 10 - 20 minutach. Nie wiem czy próbowałeś tego sposobu, ale wczoraj trafiłem na stronę http://extreme.pcgameshardware.de/gta-grand-theft-auto/385030-gta-5-file-checker-v3-sha-1-pruefung.html . Pobierasz plik GTA5FileCheck_v3.zip - uruchamiasz w folderze z grą. Program sprawdza poprawność plików, u mnie znalazł dwa uszkodzone (x64f.rpf i x64q.rpf), pliki skasowałem (na wszelki wypadek zrobiłem też kopie). Po uruchomieniu gry Launcher pobrał te dwa pliki ponownie (około 5GB), dla sprawdzenia przeskanowałem pliki jeszcze raz, tym razem wynik bez błędu. Efekt jest taki że gra działała mi wczoraj ponad 1,5 godziny bez błędu, dzisiaj jeszcze potestuję, ale mam nadzieję ze problem rozwiązany. U mnie aż tak źle nie jest. Wywala się może co 3h albo i rzadziej. Antwirus mi wywala jak chce ściągnąć ten pliczek do sprawdzania :-( Quote Share this post Link to post Share on other sites More sharing options...
epoxer Posted April 22, 2015 Report post Posted April 22, 2015 Epoxer jak u Ciebie wygląda obciążenie CPU w czasie gry ? Daj parę fotek z monitoringiem Afterburnera OSD. Pierwszy screen pokazuje trochę fizyki i obciążenie jest dość wysokie Trawka pomimo, że na High to wysokie obciążenie GPU, średnie CPU. Szybka jazda. Postój, długie światła. Nocne bieganie nad wodą. Stłuczka i wywołany nią motion blur 1 Quote Share this post Link to post Share on other sites More sharing options...
piet Posted April 22, 2015 Report post Posted April 22, 2015 Thx za zaproszenia ale w tym tygodniu tylko sp, online z ppc przekłądam do nastepnego tygodnia. Też wam nie działa cieniowanie PCSS na gtx 970? Obraz jest fatalny, w zasadzie jak zwykłe ustawienie medium. Stery 350.12 instalowane na czysto. Dobrze, że wydajność podskoczyła po ostatnim patchu w krytycznym miejscu poza miastem z 22 do 28fps. Widzę, że do online muszę zredukować ostro ustawienia. Quote Share this post Link to post Share on other sites More sharing options...
zaodrze244 Posted April 22, 2015 Report post Posted April 22, 2015 Thx za zaproszenia ale w tym tygodniu tylko sp, online z ppc przekłądam do nastepnego tygodnia. Też wam nie działa cieniowanie PCSS na gtx 970? Obraz jest fatalny, w zasadzie jak zwykłe ustawienie medium. Stery 350.12 instalowane na czysto. Dobrze, że wydajność podskoczyła po ostatnim patchu w krytycznym miejscu poza miastem z 22 do 28fps. Widzę, że do online muszę zredukować ostro ustawienia. ja wyłączyłem PCSS -> http://www.hardocp.com/article/2015/04/20/grand_theft_auto_v_video_card_performance_preview/7#.VTgSfSHtlBc na podstawie guida nvidii zmniejszyłem trawę, zresztą różnicy podczas grania nie widzę to nie skyrim oraz zmniejszyłem jakość odbić i mam teraz 60fps stałe. Quote Share this post Link to post Share on other sites More sharing options...
Kilokush Posted April 23, 2015 Report post Posted April 23, 2015 Ktoś korzysta z MFAA w tej grze? Bo u mnie nie widzę żeby włączenie MFAA w sterach dawało jakikolwiek efekt MSAAx2, FXAA on, MFAA on http://i.imgur.com/KS5k2k3.jpg MSAAx2, FXAA on, MFAA off http://i.imgur.com/9BjTtUE.jpg MSAAx4, FXAA on, MFAA off http://i.imgur.com/Dl3DKo6.jpg MSAAx4, FXAA on, MFAA on http://i.imgur.com/Lx1kXUX.jpg Quote Share this post Link to post Share on other sites More sharing options...
leven Posted April 23, 2015 Report post Posted April 23, 2015 /.../ Pięknie się karta zachowuje z tego co widzę, chociaż I5 3570K wykręcony potrafi dostać pełne obciążenie, a pisali, że GTA5 nie siedzi mocno na CPU Ustawienia wysokie ? Może b. wysokie ? Karta z 4GB pamięciami ? Co to za wartości dla monitoringu RAM ? Są dwa odczyty i to jakieś kosmicznie duże :P Pytam, bo kolega nie może się zdecydować co do zakupu GTX 960 4GB i muszę pokazać kogoś, kto ma taką kartę i pyka w GTA5 :P Dzięki i sry za kłopot. Quote Share this post Link to post Share on other sites More sharing options...
epoxer Posted April 23, 2015 Report post Posted April 23, 2015 leven, ustawienia grafiki http://forum.purepc.pl/topic/338306-grand-theft-auto-v/page-38?do=findComment&comment=3948834 Karta z 2GB RAMu. Monitoring RAMu pokazuje najpierw systemowy, potem plik wymiany. Gdy ustawiłem DSR na 1,5x, plik wymiany osiągnął 12100MB. Jestem właśnie na etapie sprawdzania jak z wydajnością DSR na 1,2x bo na 1,5x widać momentami utratę płynności pomimo > 50FPS. Quote Share this post Link to post Share on other sites More sharing options...
zaodrze244 Posted April 23, 2015 Report post Posted April 23, 2015 Quote Share this post Link to post Share on other sites More sharing options...
KaszaWspraju Posted April 24, 2015 Report post Posted April 24, 2015 (edited) Ale wczoraj był napad, ciężka misja The Pacific Standard Job. Łatwo coś s[ciach!]lić jak pierwszy raz ją robisz i nic nie wiesz, ale po wielkiej męczarni udało się. Dzisiaj mogę już posiedzieć dłużej, jak coś zapraszać. PS Nie ustawiajcie wyścigów z Makdufx, on zawsze ma TRY HARD mode. Nie zawaha się wjechać w wasz kuper. :-D Edited April 24, 2015 by KaszaWspraju Quote Share this post Link to post Share on other sites More sharing options...
Makduf Posted April 24, 2015 Report post Posted April 24, 2015 Nie prawda! Kiedy niby Ci w kuper wjechałem ?:D 1 Quote Share this post Link to post Share on other sites More sharing options...
jonathan Posted April 24, 2015 Report post Posted April 24, 2015 Fajne wczoraj byly te misje ;] Quote Share this post Link to post Share on other sites More sharing options...
logimen Posted April 24, 2015 Report post Posted April 24, 2015 Mnie jakos nie podchodzi ten caly GTA O :( Dluzej szukam sesji / laduje sie niz gram. Raptem 3 lvl mam przez ponad godzine gry. Jesli mozna nazwac to gra. Quote Share this post Link to post Share on other sites More sharing options...
jonathan Posted April 24, 2015 Report post Posted April 24, 2015 Dlatego najlepiej graz ze znajomymi, albo sprawdzonymi ekipami. Gra z randomami to jakas katorga Zanim zrobisz jakies zadanie to mina godziny 2 Quote Share this post Link to post Share on other sites More sharing options...
